ListBox Multiselect value - Read only?
Multiselect enabled ListBox can not be initialized or set to user defined value. Is that only a read-only property?
Consider this small sample.
* HMG Hello World Demo
* (c) 2002-2004 Roberto Lopez <mail.box.hmg@gmail.com>
	DEFINE WINDOW Win1 ;
		WIDTH 400 ;
		HEIGHT 400 ;
		TITLE 'Hello World!' ;
		MAIN
		DEFINE LISTBOX LIST1
			ROW	10
			COL	10
			WIDTH	100
			HEIGHT	110
			ITEMS	{ '01','02','03','04','05','06','07','08','09','10' }
			multiselect .t.
		END LISTBOX
		define button click
		  row 10
		  col 120
		  width 50
		  caption "Click"
		  action 	Win1.LIST1.value := {1,2}
    end button
	ACTIVATE WINDOW Win1
I want to show the listbox with the first and second item, selected.
Re: ListBox Multiselect value - Read only?
rathinagiri wrote:Multiselect enabled ListBox can not be initialized or set to user defined value. Is that only a read-only property?
		WIDTH 400 ;
		HEIGHT 400 ;
		MAIN
			ROW	10
			COL	10
			WIDTH	100
			HEIGHT	110
			multiselect .t.
		END LISTBOX
		define button click
		  row 10
		  col 120
		  width 50
		  caption "Click"
    end button
I'll check it.
Thanks for reporting.
Hi Roberto,
Please be so kind to update the following C-function in the file c_listbox.c:
HB_FUNC( LISTBOXSETMULTISEL )
   PHB_ITEM wArray;
   HWND     hwnd = ( HWND ) hb_parnl( 1 );
   int      i;
   int      n;
   int      l;
   wArray = hb_param( 2, HB_IT_ARRAY );
   l = hb_parinfa( 2, 0 ) - 1;
   n = SendMessage( hwnd, LB_GETCOUNT, 0, 0 );
   // CLEAR CURRENT SELECTIONS
   for( i = 0; i < n; i++ )
      SendMessage( hwnd, LB_SETSEL, (WPARAM) (0), (LPARAM) i );
   // SET NEW SELECTIONS
   for( i = 0; i <= l; i++ )
      SendMessage( hwnd, LB_SETSEL, (WPARAM) (1), (LPARAM) (hb_arrayGetNI(wArray, i + 1)) - 1 );
Hope that helps 8-)
gfilatov wrote:Hi Roberto,
Thanks Grigory!!!
I've come here to inform Rathi that I'm sure that is a Harbour compatibility problem related with internal changes introduced in 2.0.
You saved me a lot of researching time...
Thanks again!!!
Attached is a fixed libhmg.a.
libhmg3034a.rar
(195.09 KiB) Downloaded 362 times
Thanks Roberto
Best regards
Thanks a lot Roberto for this quick fix. :)
Roberto Lopez wrote: Thanks Grigory!!!
Thanks again!!!
Hello Roberto,
I'm glad to help 8-)
Your time is very important for HMG community :D
Thanks again!!!
Hello Roberto,
Sadly I'll must spent some time now, trying to understand the true meaning of your answer ;)
