GRID control
Posted: Fri Mar 26, 2010 1:48 pm
Is it possible to determine the fields to diplay at runtime in a gridcontrol?
Exclusive forum for HMG, a Free / Open Source xBase WIN32/64 Bits / GUI Development System
http://mail.hmgforum.com/
SPANISH:t57042 wrote:Is it possible to determine the fields to diplay at runtime in a gridcontrol?
Aparentemente los campos de los grid con base de datos ( COLUMNFIELDS y otros) solo se pueden especificar en tiempo de diseño no en tiempo de ejecución.t57042 wrote:Is it possible to determine the fields to diplay at runtime in a gridcontrol?
* MiniGUI Virtual Grid Demo
* (c) 2009 Roberto Lopez
Local aValue := { Nil , Nil }
* Grid Column Controls Definitions
aCtrl_1 := {'TEXTBOX','NUMERIC','9999999999'}
aCtrl_2 := {'TEXTBOX','CHARACTER'}
aCtrl_3 := {'TEXTBOX','CHARACTER'}
aCtrl_4 := {'DATEPICKER','UPDOWN'}
aCtrl_5 := { 'CHECKBOX' , 'Yes' , 'No' }
aCtrl_6 := { 'EDITBOX' }
mat_HEADERS_todos :={'Column 1','Column 2','Column 3','Column 4','Column 5','Column 6'}
mat_WIDTHS_todos :={140,140,140,100,100,100}
mat_COLUMNCONTROLS_todos :={ aCtrl_1 , aCtrl_2 , aCtrl_3 , aCtrl_4 , aCtrl_5 , aCtrl_6 }
mat_COLUMNFIELDS_todos :={ 'Code' , 'First' , 'Last' , 'Birth' , 'Married' , 'Bio' }
mat_HEADERS := mat_HEADERS_todos
mat_WIDTHS := mat_WIDTHS_todos
mat_COLUMNCONTROLS := mat_COLUMNCONTROLS_todos
mat_COLUMNFIELDS := mat_COLUMNFIELDS_todos
WIDTH 800 ;
HEIGHT 510 ;
TITLE 'Hello World!' ;
DEFINE MAIN MENU
POPUP 'File'
ITEM 'Pack' ACTION Pack()
ITEM 'Append (Alt+A)' ACTION Form_1.Grid_1.Append
ITEM 'Set RecNo' ACTION Form_1.Grid_1.RecNo := val(InputBox('',''))
ITEM 'Get RecNo' ACTION MsgInfo( Str(Form_1.Grid_1.RecNo) )
ITEM 'Delete (Alt+D)' ACTION Form_1.Grid_1.Delete
ITEM 'Recall (Alt+R)' ACTION Form_1.Grid_1.Recall
ITEM 'Get Value' ACTION ( aValue := Form_1.Grid_1.Value , MsgInfo( Str( aValue [1] ) + ' , ' + Str( aValue [2] ) ) )
ITEM 'Set Value' ACTION ( aValue [ 1 ] := val(InputBox('New Row','Selected Cell (Value)')) , aValue [ 2 ] := val(InputBox('New Col','Selected Cell (Value)')) , Form_1.Grid_1.Value := { aValue [ 1 ] , aValue [ 2 ] } )
ITEM 'Save Pending Changes (Alt+S)' ACTION Form_1.Grid_1.Save
ITEM 'Clear Changes Buffer (Undo) (ALt+U)' ACTION Form_1.Grid_1.ClearBuffer
END POPUP
POPUP 'FIELDS'
ITEM 'Ver Todos' ACTION cambiar_field (1)
ITEM 'Ver FIELDS 1, 2 y 3' ACTION cambiar_field (2)
ITEM 'Ver FIELDS 4, 5 y 6' ACTION cambiar_field (3)
END POPUP
END MENU
USE TEST // SHARED
INDEX ON CODE TO CODE
*PACK
GO TOP
@ 10,10 GRID Grid_1 ;
WIDTH 770 ;
HEIGHT 440 ;
HEADERS mat_HEADERS;
WIDTHS mat_WIDTHS;
EDIT ;
VALUE { 1 , 1 } ;
COLUMNCONTROLS mat_COLUMNCONTROLS;
ROWSOURCE "Test" ;
COLUMNFIELDS mat_COLUMNFIELDS;
ALLOWAPPEND ;
ALLOWDELETE
CENTER WINDOW Form_1
Function pack
pack
Form_1.Grid_1.Refresh
procedure cambiar_field (n)
mat_HEADERS := {}
mat_WIDTHS := {}
mat_COLUMNCONTROLS := {}
mat_COLUMNFIELDS := {}
do case
case n = 1
case n = 2
for i = 1 to 3
aadd (mat_HEADERS, mat_HEADERS_todos [i])
aadd (mat_WIDTHS, mat_WIDTHS_todos [i])
aadd (mat_COLUMNCONTROLS, mat_COLUMNCONTROLS_todos [i])
aadd (mat_COLUMNFIELDS, mat_COLUMNFIELDS_todos[i])
next
case n = 3
for i = 4 to 6
next
endcase
reg := 1
IF IsControlDefined ( Grid_1 , Form_1 )
reg := Form_1.Grid_1.recno
Form_1.Grid_1.Release
@ 10,10 GRID Grid_1 OF Form_1;
WIDTH 770 ;
HEIGHT 440 ;
WIDTHS mat_WIDTHS;
EDIT ;
VALUE { reg , 1 } ;
ROWSOURCE "Test" ;
ALLOWAPPEND ;
ALLOWDELETE
return
Fantástico, esta alternativa me ayudó mucho. Muchas gracias Dr. Claudio !srvet_claudio wrote:Aparentemente los campos de los grid con base de datos ( COLUMNFIELDS y otros) solo se pueden especificar en tiempo de diseño no en tiempo de ejecución.
Una forma que se me ocurrió fue cada vez que necesites cambiar los campos en la visualizacion del grid, este se destruya (ventana.grid_1.release) y se vuelva a crear con los campos que necesites visualizar en ese momento.
A continuación te dejo un ejemplo que modifique de \SAMPLES\GRID.25 de HMG 3.0.26
