Page 7 of 11
Posted: Thu Jan 16, 2020 9:28 am
by huiyi_ch
Hi AUGE_OHR
Please add the following structure:
Begin ini xxx
END Ini
SWITCH expr
CASE value
[EXIT]
OTHERWISE
ENDSWITCH
WITH OBJECT expression
ENDWITH
CLASS xxx
ENDCLASS
Posted: Thu Jan 16, 2020 6:06 pm
by AUGE_OHR
huiyi_ch wrote: Thu Jan 16, 2020 9:28 am Hi AUGE_OHR
 Begin ini xxx
 END Ini
 SWITCH expr
        CASE value
          [EXIT]
        OTHERWISE
ENDSWITCH
ENDWITH
CLASS xxx
ENDCLASS
sorry, that is NOT Classy Syntax so it is not include in Clipper.
you have to re-write your Code to Classy Syntax than you can use CLASS Code with CLICK.
Posted: Fri Jan 17, 2020 2:50 am
by huiyi_ch
Hi AUGE_OHR
Can you add a choice to the main interface that supports HARBOUR extension syntax?This preserves both CLIPPER's classic syntax and HARBOUR's extended syntax.
Posted: Fri Jan 17, 2020 6:13 am
by AUGE_OHR
huiyi_ch wrote: Thu Jan 16, 2020 9:28 am Please add the following structure:
Begin ini xxx
END Ini
 SWITCH expr
        CASE value
          [EXIT]
        OTHERWISE
ENDSWITCH
i have try SWITCH Syntax
it fail when have this
STATIC FUNCTION MySmile( nType )
   IF HB_ISNUMERIC( nType )
      SWITCH nType
      CASE 1 ; RETURN ":)"
      CASE 2 ; RETURN ";)"
      CASE 3 ; RETURN "*SMILE*"
      ENDSWITCH
but it work when have this
      SWITCH nType
      CASE 1
 RETURN ":)"
      CASE 2
 RETURN ";)"
      CASE 3
 RETURN "*SMILE*"
      ENDSWITCH
result is not nice while i got this
      SWITCH nType
   CASE 1
      RETURN ":)"
   CASE 2
      RETURN ";)"
   CASE 3
      RETURN "*SMILE*"
      ENDSWITCH
you see that it don't intend CASE "1" ... but it does compile/link right and do not give Error when using CLICK
i have deeper look for SWITCH and it is different to DEFINE which have a 2nd "fix" Parameter.
same with "Begin ini xxx" and "END Ini" which must be "ENDIni" is to short with 3 Sign ... better 4 Sign
if we get SWITCH with "fix" Parameter like "NTYP","CTYP","NFOR" ... than we can use it with CLICK Logic
my 1st Try was to search "DO CASE" but i didn't find a Way to Indent CASE "1" when using SWITCH
my Advice : if you want to use CLICK get rid of SWITCH and go back to Basic and use Clipper Syntax DO CASE
ENDWITH
hm ... "might" be possible while use 2 x Words "WITH OBJECT"... but ...
as i know "WITH" it a the "Keyword" under Cl*pper and i'm not sure how CLICK will "understand" when a Line begin with "WITH" :roll:
CLASS xxx
ENDCLASS
that is include but you have to use this Syntax
CLASS xxx
EXPORTED:
     METHOD ABC
ENDCLASS
METHOD xxx:ABC
this is CLASSY Syntax which Xbase++ use too.
it will write Header into CLASS Code but no Cross-Reference like Function/Procedure
it Code does NOT work well
INLINE METHOD
INLINE CLASS METHOD
INLINE ACCESS CLASS METHOD
INLINE ASSIGN ACCESS METHOD
CLICK is a Cl*pper Code Formatter and i want to add HMG xCommad SYNTAX used by FMG***.
i found out that it work with HMG / FMG while i have a "Start" with "DEFINE abcd" and "End" with "ENDabcd".
i "just" had to find out "where" to put "Start" and "End" to increase / decrease Counter for Intend left / right
but i can't use CLICK e.g with FiveWin while there is no "ENDabcd" ... and also FoxPro Code will not work well with CLICK.
it is still the old Cl*pper Code so we have to go back to Basic Cl*pper Syntax which still work when we want to use CLICK.
if someone find out how to enhance Code for "new Syntax" feel free to modify Code which i prepare to release.
please write about Result in "this" Forum ... i don't like Google Forum, thx
***i use "modify" FMG in MiniGUI and "that" Syntax work too with CLICK
to use CLICK with MinGUI i recommend to write all "C"-Code into a Extra *.PRG
Posted: Fri Jan 17, 2020 6:27 am
by AUGE_OHR
huiyi_ch wrote: Fri Jan 17, 2020 2:50 am Can you add a choice to the main interface that supports HARBOUR extension syntax?
i'm simple not able to extend CLICK for "other" than Cl*pper or Xbase++ OOP Syntax.
as i say my Concept with DEFINE xxx work while 2nd "fix" Parameter xxx is also in "ENDxxx"
for other Syntax without "Start" / "End" i have no Idea :idea:
perhaps you have a Idea. please report your Result in "this" Forum, thx
Posted: Fri Jan 17, 2020 9:50 am
by RPC
AUGE_OHR wrote: Tue Jan 14, 2020 7:15 pm
RPC wrote: Tue Jan 14, 2020 7:49 am
   START PRINTPAGE
   END PRINTPAGE
Aha ...this i have oversee.ok i will fix it
Hi AUGE_OHR
I tried ver 25 . Now I don't get error regarding clickout directory.
However the error regarding START PRINTPAGE ... END PRINTPAGE still exsits. :(
Posted: Fri Jan 17, 2020 8:42 pm
by AUGE_OHR
RPC wrote: Fri Jan 17, 2020 9:50 am However the error regarding START PRINTPAGE ... END PRINTPAGE still exsits. :(
uuuups ... i have enhance Code for DEFINE PRINTPAGE.
as it is not DEFINE i have to look "where" to place
START PRINTDOC
   START PRINTPAGE
   END PRINTPAGE
END PRINTDOC
not sure if i can fix it until Sunday
Posted: Fri Jan 17, 2020 11:41 pm
by AUGE_OHR
have found Solution for START PRINTDOC / START PRINTPAGE :D
hb_CLICK_EXE26.zip
(1.58 MiB) Downloaded 406 times
as it have 2 x Word i can use same Concept like DEFINE so i only have to add 2 x Variable for Intend
btw. DEFINE and START Indent are "fix" on Space(3) ... i have to enhance CLICK.INI to include it.
so this is now last Call so fix something in CLICK for HMG and Extendet Version.
p.s. does new Icon of CLICK appear on your PC :?:
on some PC Icon was not updated so i have to clean Windows Icon Cache
Posted: Sat Jan 18, 2020 12:08 am
by AUGE_OHR
hi
while search for sample with START PRINTxxx i found some *.RMG
it contain Syntax like
BEGIN LAYOUT
BEGIN HEADER
BEGIN TEXT
BEGIN LINE
BEGIN FOOTER
BEGIN DATA
BEGIN DETAIL
BEGIN SUMMARY
BEGIN GROUP
BEGIN GROUPHEADER
BEGIN GROUPFOOTER
BEGIN RECTANGLE
Question : does someone use those REPORT Syntax without *.RMG :?:
so it is the same as BEGIN INI where i had Problem to find a Concept ...
Posted: Sat Jan 18, 2020 5:57 am
by AUGE_OHR
when using ";" to break line the "last" might be "lost" :shock:
this will produce wrong Code where "end" and "return" are missing :!:
IF a=b ; blabla ; end
IF a=b ; blbla  ; return
and also this Syntax
  xVar := a+b+c;
          +d+e+f
while this work with ";"
  xVar := a+b+c+;
          d+e+f
so it must be a "+" before ";" to work correct with CLICK
Error will NOT warn by CLICK ... if fail on compile / link :!:
