Page 6 of 11
Posted: Sun Jan 12, 2020 6:05 am
by AUGE_OHR
did HMG Syntax now work with CLICK and "your" Source :?:
i have add new Function GetDBFInfo() :D
we do have "Data Path" and we got Tbl_cros.TXT but it only say which DBF is used ... not it's Structure.
now i scan "Data Path" for DBF and "try" to open it an get DBSTRUCT() which just take some Seconds.
"try" mean FOPEN() to read Header of DBF.
   nHandle := FOPEN( cDbf )
   FSEEK( nHandle, 0, 0 )
   FREAD( nHandle, @cBuffer, 1 )
   FCLOSE( nHandle )
   nType := ASC( cBuffer )
Question : if a DBF is already open how to get "more" Information e.g. "VIA" :?:
   DO CASE
      CASE nType = 3
         USE (cDBF) VIA "DBFNTX"
      CASE nType = 7
         // MSGInfo( VAR2CHAR( aType ), "Warning DBF Type" )
      CASE nType = 48 .OR. nType = 49
         USE (cDBF) VIA "DBFCDX"
      CASE nType = 131
      CASE nType = 245
         // using Cl*pper Comix/SixDrive
    OTHERWISE
         // MsgInfo("no supportet" )
    ENDCASE
i do have more Type but i don't know if i need it under harbour / HMG :?:
FUNCTION _DbfFileType( nType, cDbf )
CASE nType = 2 // 02h FoxBASE
CASE nType = 3 // 03h FoxBASE+/Dbase III plus, no memo
CASE nType = 4 //* 04h
CASE nType = 5 //* 05h
CASE nType = 7 //* 07h
CASE nType = 48 // 30h Visual FoxPro
CASE nType = 49 // 31h Visual FoxPro, autoincrement enabled
CASE nType = 67 // 43h dBASE IV SQL table files, no memo
CASE nType = 99 // ???
CASE nType = 123 //* 7Bh
CASE nType = 131 // 83h FoxBASE+/dBASE III PLUS, with memo
CASE nType = 135 //* 87h
CASE nType = 139 // 8Bh
CASE nType = 142 //* 8Eh
CASE nType = 179 //* B3h
CASE nType = 203 // 0xCB dBASE IV SQL table files, with memo
CASE nType = 229 //* E5h HiPer-Six format with SMT memo file
CASE nType = 245 // F5h FoxPro 2.x (or earlier) with memo
CASE nType = 251 // FBh FoxBASE
so here CLICK.EXE v0.22 (packed with UPX)
Source will follow soon
hb_CLICK_EXE22.zip
(1.37 MiB) Downloaded 493 times
Posted: Sun Jan 12, 2020 7:38 pm
by RPC
Hi AUGE_OHR
Tried ver 22. In one of the files got error msg "Control Underflow 1: Error detected at line 204"
This file was not re-formatted in clickout folder.
Compiling my program however does not produce any error.
Posted: Sun Jan 12, 2020 8:55 pm
by AUGE_OHR
thx for Answer,
the Error Message is about "your" Code but i don't know what is in "your" line 204.
if VERBOSE=ON you can see last Line of "Input" Window (middle) what is in line 204
i guess it is a END xxx so i need to know what xxx is which i have not implement yet.
so please help me and give me a Hint what DEFINE xxx is still missing, thx.
Posted: Sun Jan 12, 2020 11:16 pm
by AUGE_OHR
it seems i still have not include many DEFINE as i have not use it yet like
DEFINE DATEPICKER
DEFINE EDITBOX
DEFINE HYPERLINK
DEFINE IMAGE
DEFINE LABEL
DEFINE LISTBOX
DEFINE ACTIVEX
DEFINE ANIMATEBOX
DEFINE BROWSE
DEFINE CHECKBOX
DEFINE CHECKBUTTON
DEFINE COMBOBOX
DEFINE CONTEXTMENU
DEFINE DROPDOWN
DEFINE FRAME
DEFINE IPADDRESS
DEFINE MONTHCALENDAR
DEFINE PLAYER
DEFINE PROGRESSBAR
DEFINE SLIDER
DEFINE SPINNER
DEFINE SPLITBOX
DEFINE TAB
DEFINE TEXTBOX
DEFINE TIMEPICKER
DEFINE TIMER
there are some Sample which can make Probem
DEFINE TREE
possible Problem while no DEFINE
NODE 'Docs'
TREEITEM 'Docs 1' IMAGES {'varios'}
END NODE
DEFINE REPORT
possible Problem with BEGIN
BEGIN DATA
END DATA
BEGIN LAYOUT
END LAYOUT
BEGIN HEADER
END HEADER
BEGIN DETAIL
END DETAIL
BEGIN FOOTER
END FOOTER
BEGIN SUMMARY
END SUMMARY
BEGIN GROUP
BEGIN GROUPHEADER
END GROUPHEADER
BEGIN GROUPFOOTER
END GROUPFOOTER
END GROUP
END REPORT
so if someone have a DEFINE TREE or DEFINE REPORT please check if CLICK work with that Syntax, thx
Posted: Mon Jan 13, 2020 9:30 am
by RPC
AUGE_OHR wrote: Sun Jan 12, 2020 8:55 pm hi,
thx for Answer,
Hi AUGE_OHR
Its ENDIF at line no 204
Posted: Mon Jan 13, 2020 9:20 pm
by AUGE_OHR
here EXE v.0.23 which include all DEFINE i have post before.
hb_CLICK_EXE23.zip
(1.37 MiB) Downloaded 548 times
if you still get a Error please send me a Notice which END xxx of DEFINE xxx is not include
   DEFINE xxx // i need THIS
   END xxx // i need THIS
ENDIF  <- Error
Posted: Tue Jan 14, 2020 7:49 am
by RPC
Hi AUGE_OHR
I am still getting error.
I have used commands
IF
START PRINTPAGE
END PRINTPAGE
ENDIF // line no 204
Another error , which was in earlier version, also is inspite of having sub-dir \clickout i get error msg about \clickout not existing and if I select it to create , i get another error msg regarding directory cannot be created and then the program runs normally.
Posted: Tue Jan 14, 2020 7:15 pm
by AUGE_OHR
RPC wrote: Tue Jan 14, 2020 7:49 am
   START PRINTPAGE
   END PRINTPAGE
Aha ...this i have oversee.ok i will fix it
RPC wrote:Another error , which was in earlier version, also is inspite of having sub-dir \clickout i get error msg about \clickout not existing and if I select it to create , i get another error msg regarding directory cannot be created and then the program runs normally.
YES ...
   IF !isdir( cOutDir )
      IF verify( 'The output directory "' + cOutDir + '" does not exist.', ;
                 .t., 'Create', 'Abort' )
         ft_mkdir( cOutDir )
         QUIT
i have to check my Function ISDIR() in Xbase.PRG
thx for help
Posted: Thu Jan 16, 2020 12:40 am
by AUGE_OHR
hi
i have check my Function ISDIR() but i can't reproduce Error any more :o
FUNCTION ISDIR( cIn )
LOCAL aDir  := DIRECTORY( cIn, "D" )
LOCAL i, iMax
LOCAL nPosi, cDir, lRet := .F.
   iMax := LEN( aDir )
   nPosi := RAT( "\", cIn )
   IF nPosi > 0
      cDir := SUBSTR( cIn, nPosi + 1 )
      FOR i := 1 TO iMax
         IF aDir[ i ] [ 1 ] = cDir .AND. "D" $ aDir[ i ] [ 5 ]
            lRet := .T.
            EXIT
RETURN lRet
so i can only give some Hint
delete old "OutPut" Folder and let CLICK create new
try Name of "OutPut" Folder with / without "\" at End
did someone find more Problem :?:
does it work well enough now to release Source Code :?:
Posted: Thu Jan 16, 2020 5:56 am
by AUGE_OHR
here now "Release Candidate 1".
hb_CLICK_EXE25.zip
(1.37 MiB) Downloaded 553 times
i don't use FMG File any more and have create a new Icon for Click (Darkmode ...)
if i don't get any more Error Message i will freeze this Version an Release Source Code on Sunday.
