Page 4 of 5
Re: implement LETODB
Posted: Wed Apr 21, 2021 3:32 pm
by fouednoomen
how I can connect simultaneously to two LETODB servers from a workstation on the same application
thanks in advance
Posted: Thu Apr 22, 2021 5:45 am
by mol
I dind't try.
Really interesting
Posted: Thu Apr 22, 2021 8:33 am
by fouednoomen
I just found this article on a site which confirms the possibility of simultaneously connecting to several servers from a single application but I cannot deploy the solution.
i need your help
Posted: Thu Apr 22, 2021 9:36 am
by edk
Try this:
#include "dbinfo.ch"
//#include "leto_std.ch"
REQUEST LETO
//RDDSETDEFAULT( "DBFCDX" )
REQUEST HB_GT_WIN_DEFAULT
REQUEST HB_LANG_PL852
request HB_CODEPAGE_PL852
	Local i, plikDBF1, plikNTX1, plikDBF2, plikNTX2, lCreate, pola, plik
	public cRDDDriver := "DBFNTX"
	public cLocalRDDDriver := "DBFNTX"
	public cLetoSerwer1 := "192.168.1.18"
	public nLetoSerwerPort1 := 2812
	public cLetoSerwer2 := "192.168.1.52"
	public nLetoSerwerPort2 := 2812
	public nHotbuf := 100
	public nTimeOut := 6000
	public lUseSerwerLeto1 := .F.
	public nStatusLETO1 := -1
	public cLetoSerwerPath1 := ""
    public lAllowWorkWithoutLetoSerwer := .T.
    Public cPath1 := ""
    public lUseSerwerLeto2 := .F.
	public nStatusLETO2 := -1
	public cLetoSerwerPath2 := ""
    Public cPath2 := ""
    Public cLetoUser := ""
    Public cLetoPass := ""
SET LANGUAGE TO POLISH
SET CODEPAGE TO POLISH
SET MULTIPLE OFF WARNING
set( _SET_CODEPAGE, "PL852" )
hb_LangSelect( 'PL852')
SETBLINK(.F.)
SETCANCEL(.F.)
SET MARGIN TO 0
SET SCOREBOARD OFF
SET WRAP ON
SET CONFIRM ON
SET DATE ANSI
SET ESCAPE OFF
@0,0 CLEA
if !( Empty( cLetoSerwer1 ) .OR. Empty(nLetoSerwerPort1) )
	cLetoSerwerPath1 := "//" + Alltrim ( cLetoSerwer1 ) + ":" + Alltrim( Str( nLetoSerwerPort1 ) ) + "/"
	lUseSerwerLeto1 := (( nStatusLETO1 := LETO_CONNECT( cLetoSerwerPath1, cLetoUser /*user*/, cLetoPass /*pass*/, nTimeOut /*timeout*/, nHotBuf /*hot buffer*/ )) >= 0)
	? "nStatusLETO1", nStatusLETO1
	if lUseSerwerLeto1
		RDDSETDEFAULT( "LETO" )
		cRDDDriver := "LETO"
		cPath1 := cLetoSerwerPath1
		? "1", LETO_GetServerVersion(), " at address: ", Leto_getLocalIP( .T. )
		? "DBF DATABASE DRIVER        :", LETO_DBDRIVER()[ 1 ], "MEMOTYPE:", LETO_DBDRIVER()[ 2 ]
		? "CurrentConnection: ", LETO_GETCURRENTCONNECTION()
		if lAllowWorkWithoutLetoSerwer
			? "Brak połączenia z serwerem LETO1 ", cLetoSerwerPath1, leto_Connect_Err( .T. )
			? "Brak połączenia z serwerem LETO1 ", cLetoSerwerPath1, leto_Connect_Err( .T. ), "Program zatrzymany!"
			quit
		RDDSETDEFAULT( "DBFNTX" )
if !( Empty( cLetoSerwer2 ) .OR. Empty(nLetoSerwerPort2) )
	cLetoSerwerPath2 := "//" + Alltrim ( cLetoSerwer2 ) + ":" + Alltrim( Str( nLetoSerwerPort2 ) ) + "/"
	lUseSerwerLeto2 := (( nStatusLETO2 := LETO_CONNECT( cLetoSerwerPath2, cLetoUser /*user*/, cLetoPass /*pass*/, nTimeOut /*timeout*/, nHotBuf /*hot buffer*/ )) >= 0)
	? "nStatusLETO2", nStatusLETO2
	if lUseSerwerLeto2
		cPath2 := cLetoSerwerPath2
		? "2", LETO_GetServerVersion(), " at address: ", Leto_getLocalIP( .T. )
			? "Brak połączenia z serwerem LETO2 ", cLetoSerwerPath2, leto_Connect_Err( .T. )
			? "Brak połączenia z serwerem LETO2 ", cLetoSerwerPath2, leto_Connect_Err( .T. ), "Program zatrzymany!"
			quit
? "UseLetoSerwer1", lUseSerwerLeto1
? "UseLetoSerwer2", lUseSerwerLeto2
? "RDD: ", RddSetDefault(),  " , DBF EXTENSION:", hb_rddInfo( RDDI_TABLEEXT )
inkey ( 5 )
plikDBF1 := cPath1 + "MyFile1.DBF"
plikNTX1 := cPath1 + "Indeksy1.NTX"
lCreate := .F.
if !lUseSerwerLeto1
	lCreate := !File( plikDBF1 )
	lCreate := !Leto_file( plikDBF1 )
? "Create file ", plikDBF1, lCreate
inkey (1)
if lCreate
	pola := {}
	AADD(pola, {'REGON','N',13,0})
	AADD(pola, {'AKT','C',2,0})
	AADD(pola, {'DATA','D',8,0})
	//file on Leto server #1
	DBCREATE( F_DBF (plikDBF1), pola )
	DBUseArea(.T., cRDDDriver, F_DBF (plikDBF1), .f., .f.)
	INDEX ON regon TO &plikNTX1
	FOR i:=1 TO 10
		APPEND BLANK
		REPLACE regon WITH i
		REPLACE akt WITH CHR(i+64)
		REPLACE data WITH hb_date() - i
	NEXT i
	USE
SELECT 1		//file on Leto server #1
plik := F_DBF ( plikDBF1 )
USE &plik INDEX &plikNTX1
? ALIAS()
go top
do while !eof()
? recno()
?? regon
?? akt
?? data
inkey(1)
skip
enddo
plikDBF2 := cPath2 + "MyFile2.DBF"
plikNTX2 := cPath2 + "Indeksy2.NTX"
lCreate := .F.
if !lUseSerwerLeto2
	lCreate := !File( plikDBF2 )
	lCreate := !Leto_file( plikDBF2 )
? "Create file ", plikDBF2, lCreate
inkey (1)
if lCreate
	pola := {}
	//file on Leto server #2
	DBCREATE( F_DBF (plikDBF2), pola )
	DBUseArea(.T., cRDDDriver, F_DBF (plikDBF2), .f., .f.)
	INDEX ON regon TO &plikNTX2
	USE
SELECT 2	//file on Leto server #2
plik := F_DBF ( plikDBF2 )
USE &plik INDEX &plikNTX2
GO TOP
DO WHILE !EOF()
	APPEND BLANK
	REPLACE 2->regon WITH 1->regon
	REPLACE 2->akt WITH 1->akt
	REPLACE 2->data WITH 1->data
	SKIP
ENDDO
? ALIAS()
go top
do while !eof()
? recno()
?? regon
?? akt
?? data
inkey(1)
skip
enddo
close data
Leto_Disconnect( cLetoSerwerPath1 )
Leto_Disconnect( cLetoSerwerPath2 )
? "press any key to exit...."
inkey(0)
QUIT
FUNCTION F_DBF ( cFileName )
RETURN hb_FNameExtSet(cFileName, "")
Note: Unlike to RDD "DBFNTX" when referencing DBF files in "LETO" (eg USE, DBCREATE) the default file extension ".DBF" cannot be used, causes error 1010 invalid characters in Alias.
Posted: Thu May 06, 2021 10:50 am
by JRGEMS
After I add the following line in my main prg, error occurs while compiling.
REQUEST leto
error on compiling:
hbmk2: Error: Referenced, missing, but unknown function(s): LETO()
Ramesh Bhat.
Posted: Thu May 06, 2021 2:23 pm
by edk
1. Download the package from Marek containing the library "librddleto_20190517.a" (link: http://hmgforum.com/viewtopic.php?p=65987#p65987)
2. Place the downloaded file librddleto_20190517.a in the folder c:\hmg.3.4.4\lib\
3. If you are using the IDE, in the project's * .hbc configuration file enter: libs=rddleto_20190517
or
3. If you are using build.bat: your command line should look like this: call c:\hmg.3.4.4\build.bat project.hbp -lrddleto_20190517
Posted: Thu May 06, 2021 4:46 pm
by JRGEMS
Thank you EDK.
Now it is compiling OK using IDE.
Build.bat still giving same error.
my command prompt build command is:
build.bat jt.hbp jt.hbc
jt.hbc given below:
incpaths=
libpaths=
gt=
mt=yes
Bhat.
Posted: Thu May 06, 2021 9:34 pm
by edk
Try:
build.bat jt.hbp -lrddleto_20190517
Posted: Sat Feb 25, 2023 3:21 pm
by mol
Hi!
I want to refresh this topic.
Now, I need to connect to read and write data from php application.
Sample attached to leto is working,but it shows only a few information.
Did anybody realize change data from PHP to DBF and vice versa?
Posted: Sat Feb 25, 2023 5:04 pm
by dragancesu
