implement LETODB
fouednoomen
implement LETODB
Post by fouednoomen »
Hi All Friends
Could you please help me to implement the LETODB step by step , I have already tried it alone but I did not arrive.
Thanks in advance
Re: implement LETODB
I'm using letodbf by Elch.
Works very good.
I'll try to write tomorrow
Hola Mol, es posible que puedas compartir ese conocimiento?. Gracias
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Post by Claudio Ricardo »
Hola Mol... Yo también estoy interesado ya que Netio me ha dado un par de dolores de cabeza
y en aplicaciones pequeñas ( 2-3 ps's en red local ) como que no se justifica usar SQL.
Google traducer:
Hello Mol ... I am also interested as Netio has given me a couple of headaches
and in small applications (2-3 ps's in local network) as it is not justified to use SQL.
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hi Mol,
Salamandra, Brazil
jorge.posadas
Post by jorge.posadas »
Mol.
I am also interested in using letobe
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Programador independiente
Morelia, Mich.
M é x i c o .
Movil +52 44 3734 1858
SKYPE: jorge.posadasch
First, to use leto, you have to include it to your project.
I think, everybody needs to use aloso local files via DBFCDX
In MAIN function you have to place code
	REQUEST LETO
	REQUEST DBFCDX , DBFFPT
	RDDSETDEFAULT( "DBFCDX" )
	public cRDDDriver := "DBFCDX"
	public cLocalRDDDriver := "DBFCDX"
	public cLetoSerwer := ""
	public nLetoSerwerPort := 2812
	public lUseSerwerLeto := .f.
	public nStatusLETO := -1
	public cLetoSerwerPath := ""
After reading initials from .INI, I'm trying to establish connection with server:
	if !( empty(cLetoServer) .or. empty(nLetoServerPort) )
		cLetoServerPath := "//"+alltrim(cLetoSerwer)+":"+alltrim(str(nLetoSerwerPort))+"/"
		lUseSerwerLeto := ((nStatusLETO := LETO_CONNECT( cLetoSerwerPath, "", "")) >= 0)
		if lUseSerwerLeto
			RDDSETDEFAULT( "LETO" )
			cRDDDriver := "LETO"
			if lAllowWorkWithoutLetoSerwer
				MsgStop("No connection with LETO server ")
				MsgStop("No connection with LETO server. Program Abandoned")
				quit
Now, it's easy to open areas
if lLocalDB
  lCreate := !file("MyFile.DBF")
   lCreate := !Leto_file("MyFile.DBF")
if lCreate
	// create procedure here
DBUseArea(.T.,   if(lLocalDB, "DBFCDX","LETO"), "MyFile.DBF", .f., .f.)
After that, you can access MyFile.DBF via LETO in the same way as via DBFCDX
fouednoomen
Many thanks Mol for your prompt response ,
I also need the library implementation necessary to run LETODB and how to install LETODB in the server
Thanks
I can pass compiled library and server service
you can install letodb as a service:
letodbsvd.exe install
you have to put .ini file in letodbfsvc directory
My letodb.ini is like this:
[Main]
; server port number;
; Port = 2812
; connection timeout;
; TimeOut = -1
; path to a data directory on a server;
DataPath=d:\projekty
;logowanie na hasło
Pass_for_login=0
Pass_form_manage=0
Pass_for_Data=0
; path and name of a log file;
; Logpath = letodb.log
; default RDD to open files on server ( CDX/NTX );
Default_Driver = CDX
; memo type ( FPT/DBT ). Default: FPT for DBFCDX, DBT for DBFNTX;
; Memo_Type = FPT
; if 1, convert all paths to lower case;
; Lower_Path = 0
; if 1, using of file functions ( leto_file(),
; leto_ferase(), leto_frename() is enabled;
EnableFileFunc = 1
; if 1, creating of data tables and indexes with
; any extention, other than standard ( dbf,cdx,ntx )
; is enabled;
; EnableAnyExt = 0
; if 1, user authentication is necessary to
; login to the server;
; Pass_for_Login = 0
; use management functions ( Leto_mggetinfo(), etc. );
; Pass_for_Manage = 0
; have write access to the data;
; Pass_for_Data = 0
; the path and name of users info file;
Pass_File = d:\leto\leto_users
; if 1, the data passes to the network encrypted;
; Crypt_Traffic = 0
; if 0 (default, this mode server was the only from the
; start of a letodb project), the letodb opens all
; tables in an exclusive mode, what allows to increase
; the speed. If 1 (new mode, added since June 11, 2009),
; tables are opened in the same mode as client
; applications opens them, exclusive or shared, what
; allows the letodb to work in coexistence with other
; types of applications.
Share_Tables = 1
; The number of records to read into the cache
; Cache_Records = 10
; Maximum number of shared variables
; Max_Vars_Number = 10000
; Maximim size of a text variable
; Max_Var_Size = 10000
; Global function letodb RDDI_TRIGGER
; Trigger = <cFuncName>
; Global function letodb RDDI_PENDINGTRIGGER
; PendingTrigger = <cFuncName>
; Number of tables
Tables_Max  = 8000
; Number of users
; Users_Max = 500
; Debug level
Debug = 0
; if 1, SET HARDCOMMIT OFF
; Optimize = 0
; SET AUTORDER setting
; AutOrder = 0
; _SET_FORCEOPT setting
; ForceOpt = 0
[DATABASE]
Datapath=d:\projekty\_ak\
driver = CDX
packed library you can download froom my server https://molsystemy.pl/hmg/leto.zip
fouednoomen
Hi Mol ,
after adding the lines of code that you showed me previously and the librddleto_20190517 library in the project, the compiler shows me this error
[image][/image]
