Page 3 of 4
Re: CheckBox in a Grid Problem
Posted: Tue Aug 16, 2022 1:11 am
by AUGE_OHR
hi Red,
Red2 wrote: Mon Aug 15, 2022 11:06 pm Unfortunately I have been not been able to make this happen using:
1) The HMG IDE
Ok, you want CHECKBOX in GRID, not Color Problem
i have look into Sample and found
ON CHECKBOXCLICKED
but it is NOT in Form-Designer and not in your *.FMG
so you can use *.FMG whdn "edit" it ... but when "load" it still have not the Codeblock Slot so when "save" it will remove Line
Solution : do not use *.FMG
Red2 wrote: Mon Aug 15, 2022 11:06 pm 2) Displaying a .DBF table instead of a data Array.
BROWSE does not have CHECKBOXCLICKED
Posted: Tue Aug 16, 2022 9:42 am
by mustafa
Hi Red2
with DBF file it is not possible CHECKBOXCLICKED
only imitation can be done
Salam
Posted: Tue Aug 16, 2022 3:23 pm
by Red2
Thank you mustafa.
I appreciate your help.
Your Demo.PRG compiles in the HMG IDE and shows a "CheckBox" I can use.
This is what I want showing in my Grid. Thank you!
This is a big step in the right direction.
I notice that your Demo.PRG:
1) Does not use SetProperty( <Form>, <Griod>, "CheckBoxEnabled", .T. ) so I removed that.
2) Does not specify ColumnControls so in my .FRM I changed that to Nil.
3) Your ColumnFields has Column #1 as 'IIF(STOCK->L,1,0)' so my Column #1 is now "iif(By_State->MergeState,1,0)"
It appears the "iif(NFA_by_State->MergeState, 1, Nil)" also gives similar results (no Zeros show).
Unfortunately my early attempts to create this "CheckBox" in my Grid are not yet successful.
(I'm ignoring BackColor for now).
Column #1 displays a DIGIT instead of your "CheckBox".
I will examine both your example and my code to see if I can find what keeps your "CheckBox" from appearing.
If anyone has any helpful ideas or thoughts I would GREATLY appreciate hearing them.
Thanks again to everyone for all your very kind help!
Red2
Posted: Tue Aug 16, 2022 4:00 pm
by mustafa
Hi Red2
the dbf file the first column has to set field L= logical .F. or .T.
and in the grid you have to place the two bmp files, which makes
make an intention to be CheckBoxEnabled
IMAGE { '02.bmp','01.bmp' }
Posted: Tue Aug 16, 2022 4:19 pm
by Red2
Hi mustafa,
Thank you so much for your quick response and expert guidance.
I will work on this later today.
I am excited to see that a Column #1 "CheckBox" will soon happen!
Again, I am most grateful for your kind help!
Red2
Posted: Wed Aug 17, 2022 1:51 am
by Red2
Hi mustafa,
Thank you. Because of your generous help, Column #1 now shows a "CheckBox".
I am 98% there! My Grid finally displays a "CheckBox". I'm very pleased.
The last problem is that clicking any Column (after Column #1) also fires this
new "CheckBox" code and Column #1's value is changed. This is a problem.
Instead I need the new "CheckBox" code to ONLY run when Column #1 is clicked!
When any other Column is clicked I need Column #1 to remain UNchanged.
QUESTION: Can anyone help me determine how to detect where on a row that the mouse was clicked?
How can this be determined? With that information I can easily ignore changing Column #1's value.
Problem then solved!
Thank you everyone for all your help!
Red2
Posted: Wed Aug 17, 2022 2:02 am
by AUGE_OHR
hi Red,
Red2 wrote: Wed Aug 17, 2022 1:51 am The last problem is that clicking any Column (after Column #1) also fires this
did you use Mustafa Sample where you got
      CELLNAVIGATION .T.
try to change to .F.
Posted: Wed Aug 17, 2022 3:07 pm
by mustafa
Hola amigos:
Nueva modificación para los cuadrados de CheckBox parecen más reales.
Según indicaciones de jimmy se cambia en la Grid ==> CELLNAVIGATION .F.
se suprime de la Grid BACKCOLOR y FONTCOLOR para que los cuadrados
de CheckBox se vean mejor.
Con ONDBLCLIC pulsando doble clic anulamos la marcación o volvemos a marcar
en el cuadro de CheckBox
*--------------------------------- Google ------------------------*
Hello friends:
New modification for CheckBox squares look more real.
According to Jimmy's indications, it is changed in the Grid ==> CELLNAVIGATION .F.
BACKCOLOR and FONTCOLOR are deleted from the Grid so that the squares
of CheckBox look better.
With ONDBLCLIC pressing double click we cancel the dialing or we dial again
in the CheckBox
Posted: Wed Aug 17, 2022 4:07 pm
by franco
Hi, Red2
On all my Grid on change procedure I find where I was and on return go back there.
Grid on change Pr1()
Function Pr1
Local aCell
aCell:= Form_1.Grid_1.value
	Go Form_1.Grid_1.Recno          // Update Table
if acell[2] = 1                                  //     acell[1] is row      acell[2] is column.
      	DO WHAT YOU WANT
	Form_1.Grid_2.value:=aCell
	return
         DO WHAT YOU WANT ALL OTHER ROWS
                Form_1.Grid_2.save
        	Form_1.Grid_2.value:=aCell             // Puts me where I was before change.
return
Still working on my colours.
Franco
Posted: Wed Aug 17, 2022 5:18 pm
by Red2
Hi mustafa,
Thank you once again for your help.
I had trouble with FUNCTION SelecDes() checking and unchecking the "CheckBox".
The following changes worked better for me:
//	Replace STOCK->L With .F. // <<==== I do not understand the purpose of this line
//	If STOCK->L = .T.
//		Form_1.Grid_1.Save
//		DoMethod ("Form_1","Grid_1","Refresh")
//	Else
//		Replace STOCK->L With .T.
//	EndIf
// The following seems (to me) a simplification of the above IF...ENDIF
Replace STOCK->L With ( ! STOCK->L )
Form_1.Grid_1.Save
Question:
Is there some way to programmatically identify mouse click coordinates so that
I can stop clicks outside of Column #1 from changing the "CheckBox".
My reason: I only want clicks in Column #1 to check and uncheck.
Thank you again for your great help!
Red2
