CheckBox in a Grid Problem
Red2
Post by Red2 »
I really want a CheckBox to be the Display Control in Column #1 of a Grid.
I ran "C:\HMG.3.4.4\Samples\Controls\Grid\Grid_CheckBoxes\Demo.prg"
Here Column #1's display gives what I want:
However this does not show in my Grid. My Column #1's has no CheckBox:[/i]
Important:
My Grid's Column Controls Array: {{"CHECKBOX"},{'TEXTBOX'}, {'TEXTBOX'},.....}
My Column #1's control source is a .DBF field of type LOGICAL.
My .FRM code is created using the HMG IDE.
NOTE: I have read the following relevant forum post:
https://www.hmgforum.com/viewtopic.php? ... led#p62213
salamandra » Tue Jun 02, 2020 5:16 am
mol wrote: Mon Jun 01, 2020 11:47 pm
I want to redefine piece of code and use Grid with CheckBoxItems.
I'm using IDE to design form. But, I can't see possibility for grid with CheckBoxItems. Am I wrong?
No, you can´t, but you can enable checkboxes at window loading time
Thus: My code contains this (from salamandra):
LOAD window DataBrowse
// https://www.hmgforum.com/viewtopic.php?f=5&t=6467&p=62213&hilit=CheckBoxEnabled#p62213
//                                              /* Enable checkboxes here */
DataBrowse.BrowseStates.CheckBoxEnabled := .T.	/* Form_1.Grid_1.CheckBoxEnabled := .T. */
QUESTION: Can anyone please help me with I do not understand about a CheckBox in a Grid?
Thank you!
Red2
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: CheckBox in a Grid Problem
Post by dragancesu »
Look \SAMPLES\Controls\Grid\GRID_36\demo.prg
it doesn't seem to work as we would expect
Red2
Post by Red2 »
Thank you dragancesu, I appreciate your kind response.
As you note ...\SAMPLES\Controls\Grid\GRID_36\Demo.PRG (using demo.hbp via the IDE)
displays differently than ... \SAMPLES\Controls\Grid\Grid_CheckBox\Demo.PRG.
I have looked at both Demo.PRG program samples (and others) but still do not
understand what might allow a simple CheckBox in my Grid.
Any help would be appreciated. Thank you,
Red2
Hi red2
I use this grid with simple checkbox:
DEFINE GRID Grid_Agenda
   ROW 10
   COL 10
   WIDTH  1565
   HEIGHT 650
   HEADERS {"Weg", "Nr", 'Dag'   }
   WIDTHS  {50,     30,   90 }
   CELLNAVIGATION TRUE
   COLUMNWHEN     {  {|| TRUE },  { || FALSE }, {|| FALSE }}
   JUSTIFY {GRID_JTFY_LEFT, GRID_JTFY_LEFT, GRID_JTFY_LEFT }
   COLUMNCONTROLS {   { 'CHECKBOX', 'Yes' , 'No' }, ; // DELETION
                      { 'TEXTBOX',  'CHARACTER'}, ;
                      { 'TEXTBOX',  'CHARACTER'} }
   ALLOWEDIT      TRUE
   ITEMS aGrid_Agenda
END GRID
Grid filled up after screen is activated!
Maybe this can help, succes, Serge
Red2
Post by Red2 »
Hi Serge,
Thank you. I'll have a look at your example code.
I really appreciate all of your kind guidance!
Red2
Red2
Post by Red2 »
Hi Serge,
I compared your sample code to mine (an IDE created .FRM) and found nothing significant to change.
Unfortunately Column #1's cell still does not display a CheckBox.
My Grid's Control Source is a .DBF table, not an Array.
I wonder if the kind of a Grid's Control Source somehow changes the column's Display.
Does your Grid's Control Source display via an Array or a .DBF?
Question: Can you rule in or rule out whether the kind of Control Source prevents the display of my CheckBox control?
Again, thank you for your valuable guidance.
Red2
hi Red,,
have you use
   SET BROWSESYNC ON                                                  // sync BROWSE with DBF
Red,
In my ARRAY example first column (which is the checkbox) is in my ARRAY .T. or .F.
ADD ITEM	 {.F., ALLTRIM(STR(nNR,4,0)), dag1}
This has to match in your DBF. If first DBF field is CHAR then no checkbox will be in the grid.
I think this the cause.
Red2
Post by Red2 »
Hi All, Thank you for your help. I really appreciate all the kind help here.
Jimmy: I cannot find BROWSESYNC in a Grid control. The control in this case is a Grid.
My purpose in choosing a Grid control over a Browse control is to allow a CheckBox in Column #1.
Serge: The first Column's control source is a .DBF field of type LOGICAL. We can rule this out.
QUESTION: What else am I missing here?
Thanks again,
Red2
Try to change ColumnControls[1] to NIL
don't set it as {"CHECKBOX"}
