Page 3 of 4
Re: VLC for HMG
Posted: Sun May 02, 2021 10:19 am
by AUGE_OHR
chrisjx2002 wrote: ↑Sun May 02, 2021 8:13 am
I uninstall and reinstall vlc. Always the same problem. I take a look in the registry and I find :
Ordinateur\HKEY_CLASSES_ROOT\
TypeLib\{DF2BBE39-40A8-433B-A279-073F48DA94B6}\1.0\0\win64
Not the same as yours.
you show me your "TypeLib" but i like to see "CLSID" and "ProgID"
Computer\HKEY_CLASSES_ROOT\CLSID\{9BE31822-FDAD-461B-AD51-BE1D1C159921}\ProgID
so search for 9BE31822-FDAD-461B-AD51-BE1D1C159921
- VLC_CLSID.JPG (49.5 KiB) Viewed 9971 times
which VLC Version did you install
have you "check" Option AciveX & WebPlugin when Install VLC
older x64 IMHO did not work but that Version 3.0.13 ( 3.0.12 ) did work for me under 64 Bit
Re: VLC for HMG
Posted: Mon May 03, 2021 4:45 pm
by chrisjx2002
Hello,
I search for search for 9BE31822-FDAD-461B-AD51-BE1D1C159921. And I find it.
But I have always the same problem. The VLC version is the one you have 3.0.12. I am working with windows 10 64 bits last update.
There is a problem with PLAYLIST
Re: VLC for HMG
Posted: Mon May 03, 2021 9:06 pm
by AUGE_OHR
chrisjx2002 wrote: ↑Mon May 03, 2021 4:45 pm
your last Snapshot is what i mean.
it looks all OK ... hm
can you "open" Registry Tree of last Snapshot to see what is in "ProgID"
Line 282 show this
IMHO it does not work while oControl fail, not :playlist
i guess ActiveX is not create ... hm
try this
::oControl := oControl
IF EMPTY(oControl)
MsgInfo("VLC not correct installed")
QUIT
::oPlaylist := oControl:playlist
in Source Code you can change
to
"{9BE31822-FDAD-461B-AD51-BE1D1C159921}"
and try it again
did 32 bit Version work
Re: VLC for HMG
Posted: Tue May 04, 2021 8:22 am
by chrisjx2002
I try again.
With 32 bit version it works!
With 64 bits always problem. I try with "{9BE31822-FDAD-461B-AD51-BE1D1C159921}"instead of "VideoLAN.VLCPlugin.2". Same problem.
When I change the code, I have not the message "VLC not correct installed" but the same error. See screnshot.
I search the progid in regedit. See screenshot.
Re: VLC for HMG
Posted: Tue May 04, 2021 9:54 am
by AUGE_OHR
chrisjx2002 wrote: ↑Tue May 04, 2021 8:22 am
mystery ... 32 Bit is working and 64 Registry "seem" OK but does not work ...
try to change
IF EMPTY(oControl)
QUIT
into
IF VALTYPE(oControl) <> "O"
MsgInfo("VLC Object was not create")
QUIT
if you now get MsgInfo() than ACTIVEX Object was not create ... but i don´t know why
... ANSI or UNICODE IDE
Re: VLC for HMG
Posted: Tue May 04, 2021 4:05 pm
by chrisjx2002
I made the test. I don't have the msginfo but the same error. Very strange.
Re: VLC for HMG
Posted: Tue May 04, 2021 5:52 pm
by andyglezl
Aquí, solo probando...
No tengo instalado el VLC !. (Win10/64)
Here, just testing ...
I don't have VLC installed !. (Win10/64)
Re: VLC for HMG
Posted: Wed May 05, 2021 12:18 pm
by chrisjx2002
I have perhaps found the problem. I compile with hmg 32 bits and not 64 bits. It is probably why it does not work.
Re: VLC for HMG
Posted: Wed May 05, 2021 5:14 pm
by chrisjx2002
Got it! It was a problem of 64 bits compilation. Now it works!
Re: VLC for HMG
Posted: Thu May 06, 2021 2:39 am
by AUGE_OHR
chrisjx2002 wrote: ↑Wed May 05, 2021 12:18 pm
that can be the Problem when try to use 64 Bit Component with 32 Bit
