VLC for HMG
VLC for HMG
i have see VLC in MiniGUI c:\hmg.3.4.4\0\VLC\ and want to use it under HMG
so i change "MiniGUI.CH" to "HMG.ch" but there are some "different" ...
DEFINE ACTIVEX Activex1
 EVENTMAP { { E_MediaPlayerTimeChanged, "VLC_OnTimeChanged" } }
how can i get a Event under HMG from ActiveX :?:
   SLIDER Slider1 ... ON SCROLL
HMG have ON CHANGE but no ON SCROLL for a SLIDER
i understand
   oActivex := _HMG_aControlIds[..] -> _HMG_SYSDATA[...]
but why oActivex:Refresh() crash under HMG :?:
MiniGUI
   oVlc := TVlc():New( Win1.Activex1.XObject )
HMG
   oVlc := TVlc():New( Win1.Activex1.Object )
where do i find #define TRUE / FALSE :?:
so how to get VLC running under HMG :idea:
Re: VLC for HMG
Hola Jimmy :
el ActiveX de VLC es axvlc.dll progid VideoLAN.VLCPlugin.2
oVLC := CreateObject("AXVLC.VLCPlugin2")
Look here : https://wiki.videolan.org/ActiveX/
Re: VLC for HMG
thx for Answer.
i got VLC running but like my WMP Player i can "only" Get/Set Property or call Method
EVENTMAP seems the missing Point to receive Notify Events from ActiveX Control
i have look into MiniGUI c:\MiniGUI\SOURCE\h_activex.prg, which is "big", and HMG
in c:\hmg.3.4.4\SOURCE\c_controlmisc.c there is HB_FUNC( INITACTIVEX ) but that all
i guess i can´t get Notify Event under HMG while it have nothing like EVENTMAP, or :?:
i have learn to get Windows Message ( WM_* ) Event under HMG but how about Notify Event from ActiveX :idea:
Re: VLC for HMG
Hola Jimmy, en VFP hay un manejador de eventos dentro del IDE que maneja eventos de los controles ActiveX, puede leer aqui algo sobre lo que necesita https://docs.microsoft.com/en-us/cpp/mf ... w=msvc-160
Re: VLC for HMG
thx for Answer.
i have try to use c:\MiniGUI\SOURCE\h_activex.prg from MiniGUI Extended Version, which have the Solution, with HMG.
it also use i_UsrInit.ch but i was not able (yet) to include it into HMG.
i still have to learn how i can enhance HMG ...
Re: VLC for HMG
i have re-write MiniGUI Extended Version VLC Sample to use under HMG
i also include axvlc.chm so you can look what Method and Property VLC ActiveX have.
HMG_VLC.ZIP
(61.37 KiB) Downloaded 258 times
HMG Version does not support Notify Events so i can´t get Mouse or Keyboard Events "from" VLC ( e.g. Fullscreen - Mode )
about Help File and CLASS TVLC
DATA oControl, oPlayList, oInput, oVideo, oAudio
in Help File look for "IVLC" instead of "o" ( oInput -> IVLCInput )
oControl is Object itself (VLCPlugin2) so you have in CLASS
oControl:playlist
oControl:input
oControl:video
oControl:audio
chrisjx2002
Re: VLC for HMG
Post by chrisjx2002 »
Hello,
Very interested by this implementation of VLC in HMG. When compliling it, I got an error message : Can't open DLL.CH. Where can I download it?
Re: VLC for HMG
chrisjx2002 wrote: Wed Apr 28, 2021 2:40 pm When compliling it, I got an error message : Can't open DLL.CH. Where can I download it?
i forgot that DLL.CH is Part of c:\hmg.3.4.4\HARBOUR\contrib\hbxpp\dll.ch
it is need for Function _GetShortPathName which use Constant DLL_OSAPI
#ifndef _DLL_CH
#define _DLL_CH
#define DLL_CDECL                   0x08
#define DLL_STDCALL                 0x20
#define DLL_SYSTEM                  0x04
#if defined( __PLATFORM__WINDOWS )
#define DLL_OSAPI                   DLL_STDCALL
#elif defined( __PLATFORM__OS2 )
#define DLL_OSAPI                   DLL_SYSTEM
#else
#define DLL_OSAPI                   DLL_CDECL
#endif
/* Only for compatiblity.
   Harbour always copies the string to a temporary buffer. */
#define DLL_CALLMODE_COPY           0
#define DLL_CALLMODE_NORMAL         DLL_CALLMODE_COPY
#endif /* _DLL_CH */
Re: VLC for HMG
Hola Jimmy :
no existe myplayer.ico y da error
2021-04-28 18_44_07-MyPlayer.png (26.7 KiB) Viewed 7526 times
Re: VLC for HMG
danielmaximiliano wrote: Wed Apr 28, 2021 9:47 pm no existe myplayer.ico y da error 2021-04-28 18_44_07-MyPlayer.png
oh, sorry
have upload new HMG_VLC.ZIP which include myplayer.ico and DLL.CH
hm ... Error point to Line 282 and say Method does not exit
282       ::oPlaylist := oControl:playlist
it come from
   // create VLC object
127   oVlc := TVlc():New( Win1.Activex1.Object )
so i have to ask if VLC is installed :?:
VLC ActiveX Plugin and IE Web Plugin v2
{9BE31822-FDAD-461B-AD51-BE1D1C159921}
