Page 3 of 3
Re: FUNCTION OnMouseHover( hWnd, cFormName )
Posted: Sat Sep 04, 2021 4:36 am
by koke
Hola Andy
Estoy tratando de utilizar el código, pero cuando inserto un grid deja de funcionar
tienes alguna idea de porque está sucediendo esto???
o será algún error en mi código?? Solo hice copia y pega (sin cambios)
no estoy tratando de cambiar nada en el grid con este código solo los labels..
saludos
with google translate
Hello Andy
I am trying to use the code, but when I insert a grid it stops working
do you have any idea why this is happening ???
or will it be some error in my code? I just did copy and paste (no changes)
I am not trying to change anything in the grid with this code only the labels ..
Cheers
Posted: Sat Sep 04, 2021 2:04 pm
by andyglezl
koke wrote: ↑Sat Sep 04, 2021 4:36 am
Hola Andy
saludos
Hello Andy
Cheers
Que tal Koke
Así como está la función, solo funciona con controles "LABEL".
Porque no posteas el código para ver que pudiera ser ?
How about koke
As is the function, it only works with "LABEL" controls.
Why don't you post the code to see what it might be?
Posted: Sat Sep 04, 2021 3:37 pm
by koke
Hola Andy
Solo agregue un grid en el form no modifique nada de la función.
Google translate
Hello Andy
Just add a grid in the form do not modify anything of the function.
Labels.fmg
* HMG-IDE ANSI Form Designer Generated Code
DEFINE WINDOW TEMPLATE AT 296 , 438 WIDTH 550 HEIGHT 350 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "" ICON NIL CURSOR NIL ON INIT Nil ON RELEASE Nil ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR Nil NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
DEFINE LABEL Label_1
ROW 100
COL 50
WIDTH 120
HEIGHT 24
VALUE "Label_1"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
END LABEL
DEFINE LABEL Label_2
ROW 100
COL 200
WIDTH 120
HEIGHT 24
VALUE "Label_2"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
END LABEL
DEFINE LABEL Label_3
ROW 100
COL 350
WIDTH 120
HEIGHT 24
VALUE "Label_3"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
END LABEL
DEFINE GRID Grid_1
ROW 170
COL 70
WIDTH 120
HEIGHT 120
ITEMS { {""} }
VALUE Nil
WIDTHS { 0 }
HEADERS {''}
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ONHEADCLICK Nil
ONQUERYDATA Nil
MULTISELECT .F.
ALLOWEDIT .F.
VIRTUAL .F.
DYNAMICBACKCOLOR Nil
DYNAMICFORECOLOR Nil
COLUMNWHEN Nil
COLUMNVALID Nil
COLUMNCONTROLS Nil
SHOWHEADERS .T.
CELLNAVIGATION .F.
NOLINES .F.
HELPID Nil
IMAGE Nil
JUSTIFY Nil
ITEMCOUNT Nil
BACKCOLOR Nil
FONTCOLOR Nil
HEADERIMAGES Nil
ROWSOURCE Nil
COLUMNFIELDS Nil
ALLOWAPPEND .F.
ALLOWDELETE .F.
BUFFERED .F.
DYNAMICDISPLAY Nil
ONSAVE Nil
LOCKCOLUMNS Nil
END GRID
CREATE EVENT PROCNAME OnMouseHover( EventWPARAM(), "Labels" ) HWND Labels.Handle
Main.fmg
DEFINE WINDOW TEMPLATE AT 168 , 343 WIDTH 666 HEIGHT 458 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "" ICON NIL MAIN CURSOR NIL ON INIT Nil ON RELEASE Nil ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR Nil NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
ROW 40
COL 40
WIDTH 120
HEIGHT 50
VALUE "Label_1"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
END LABEL
ROW 110
COL 40
WIDTH 120
HEIGHT 50
VALUE "Label_2"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
END LABEL
ROW 170
COL 40
WIDTH 120
HEIGHT 50
VALUE "Label_3"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
END LABEL
DEFINE LABEL Label_4
ROW 230
COL 40
WIDTH 120
HEIGHT 50
VALUE "Label_4"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
END LABEL
DEFINE BUTTON Button_1
ROW 320
COL 170
WIDTH 100
HEIGHT 28
ACTION main_button_1_action()
CAPTION "Button_1"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
HELPID Nil
FLAT .F.
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .F.
MULTILINE .F.
PICTURE Nil
PICTALIGNMENT TOP
END BUTTON
CREATE EVENT PROCNAME OnMouseHover( EventWPARAM(), "Main" ) HWND Main.Handle
main.prg
public cPrevious1 := "", cPrevious2 := ""
Load Window Main
Main.Center
Main.Activate
FUNCTION OnMouseHover( hWnd, cFormName ) // Funciona para utilizar en varias FORMAS
LOCAL cControl := "", cForm := ""
GetControlNameByHandle( hWnd, @cControl, @cForm )
IF EMPTY( cControl ) .OR. GetControlType( cControl, cForm ) <> "LABEL" // Validar solo Control LABEL
SetProperty( cForm, "Title", cFormName + " - " + cControl ) // Para saber donde estoy... Quitar luego
DO CASE
CASE cFormName == "Main"
IF ! EMPTY( cPrevious1 ) // cPrevious1 definido como PRIVATE en MAIN
IF ! ( cControl == cPrevious1 )
SetProperty( cFormName, cPrevious1, "BackColor", WHITE ) // El mismo Color como se definió
SetProperty( cFormName, cPrevious1, "FontColor", BLACK ) // El mismo Color como se definió
SetProperty( cFormName, cPrevious1, "BackColor", { 173 , 255 , 47 } )
SetProperty( cFormName, cPrevious1, "FontColor", BLUE )
cPrevious1 := cControl
CASE cFormName == "Labels"
IF ! EMPTY( cPrevious2 ) // cPrevious2 definido como PRIVATE en MAIN
IF ! ( cControl == cPrevious2 )
SetProperty( cFormName, cPrevious2, "BackColor", { 65 , 105 , 225 } ) // El mismo Color como se definió
SET CONTROL &cPrevious2 OF &cFormName NOTEDGE // STATICEDGE
SetProperty( cFormName, cPrevious2, "BackColor", BLUE )
SET CONTROL &cPrevious2 OF &cFormName CLIENTEDGE
cPrevious2 := cControl
ENDCASE
Function main_button_1_action
if !IsWindowDefined("Labels")
load window Labels
labels.center
activate window labels
Posted: Sat Sep 04, 2021 5:55 pm
by andyglezl
koke wrote: ↑Sat Sep 04, 2021 3:37 pm
Hola Andy
Google translate
Hello Andy
No lo he probado, así a simple vista pudiera ser que no funciona con TEMPLATE...
I have not tested it, so at first glance it could be that it does not work with TEMPLATE ...
DEFINE WINDOW TEMPLATE...
DEFINE WINDOW FormMain ...
DEFINE WINDOW Form_Labels...
Posted: Mon Sep 06, 2021 9:02 pm
by andyglezl
andyglezl wrote: ↑Sat Sep 04, 2021 5:55 pm
Hola Andy
Google translate
Hello Andy
Al parecer, el control GRID siempre mantiene el FOCO hasta que se haga click en otro control
o en otra ventana u oprimiendo la tecla TAB.
El ONLOSTFOCUS del control GRID parece que no funciona...
Si yo oprimo la tecla TAB, el GRID pierde el FOCO y funciona, si lo oprimes tú te funciona ?
Apparently the GRID control always keeps FOCUS until another control is clicked
or in another window or by pressing the TAB key.
The ONLOSTFOCUS of the GRID control does not seem to work ...
If I press the TAB key, the GRID loses FOCUS and works, if you press it, will it work for you?
- imagen_2021-09-06_155353.png (133.52 KiB) Viewed 4355 times
Posted: Mon Sep 06, 2021 9:25 pm
by andyglezl
Si defines un control TextBox en la ventana Labels funciona correctamente,
si das click en el GRID, deja de funcionar, Oprimes la tecla TAB o das click
en el TextBox y vuelve a funcionar.
If you define a TextBox control in the Labels window it works correctly,
If you click on the GRID, it stops working, Press the TAB key or click
in the TextBox and it works again.
- imagen_2021-09-06_162403.png (53.57 KiB) Viewed 4353 times
Posted: Wed Sep 08, 2021 4:50 am
by koke
andyglezl wrote: ↑Mon Sep 06, 2021 9:25 pm
Gracias andy lo voy a checar para tratar de implementarlo
Thanks andy I'll check it to try to implement it
Greetings
Posted: Fri Sep 10, 2021 3:40 am
by koke
Buenas noches.
Utilice la función para un proyecto en el que estoy trabajando, así que se me ocurrió incorporar la modificación por si a alguien le es de utilidad.
Good evening
I use the function for a project I'm working on, so it occurred to me to incorporate the modification in case it would be useful to someone.
https://www.hmgforum.com/viewtopic.php? ... rio#p67271
