FUNCTION OnMouseHover( hWnd, cFormName )
Hola
Aquí les dejo la Función (adaptada): FUNCTION OnMouseHover( hWnd, cFormName )
para poderla utilizar en varias definiciones de ventanas. Ejemplos...
Hi
Here is the Function (adapted): FUNCTION OnMouseHover (hWnd, cFormName)
so that it can be used in various window definitions. Examples ...
DEFINE WINDOW FormMain AT 0 , 0 WIDTH 1024 HEIGHT 570 MAIN NOSYSMENU BACKCOLOR BLUE TITLE " M E S A S "
CENTER WINDOW FormMain
CREATE EVENT PROCNAME OnMouseHover( EventWPARAM(), "FormMain" ) HWND FormMain.Handle
ACTIVATE WINDOW FormMain
DEFINE WINDOW Form_Labels AT 0,0 WIDTH 665 HEIGHT 610 TITLE 'LABEL DEMO' CHILD BACKCOLOR GRAY
CENTER WINDOW Form_Labels
CREATE EVENT PROCNAME OnMouseHover( EventWPARAM(), "Form_Labels" ) HWND Form_Labels.Handle
ACTIVATE WINDOW Form_Labels
FUNCTION OnMouseHover( hWnd, cFormName )	// Funciona para utilizar en varias FORMAS
	LOCAL cControl := "", cForm := ""
	GetControlNameByHandle( hWnd, @cControl, @cForm )
	IF EMPTY( cControl ) .OR. GetControlType( cControl, cForm ) <> "LABEL"					// Validar solo Control LABEL
	SetProperty( cForm, "Title", cFormName + " - " + cControl )								// Para saber donde estoy... Quitar luego
	DO CASE
		CASE cFormName == "FormMain"
			IF ! EMPTY( cPrevious1 )														// cPrevious1 definido como PRIVATE en MAIN
				IF ! ( cControl == cPrevious1 )
					SetProperty( cFormName, cPrevious1, "BackColor", WHITE )				// El mismo Color como se definió
					SetProperty( cFormName, cPrevious1, "FontColor", BLACK )				// El mismo Color como se definió
					SetProperty( cFormName, cPrevious1, "BackColor", { 173 , 255 , 47 } )
					SetProperty( cFormName, cPrevious1, "FontColor", BLUE )
			cPrevious1 := cControl
		CASE cFormName == "Form_Labels"
			IF ! EMPTY( cPrevious2 )														// cPrevious2 definido como PRIVATE en MAIN
				IF ! ( cControl == cPrevious2 )
					SetProperty( cFormName, cPrevious2, "BackColor", { 65 , 105 , 225 } )	// El mismo Color como se definió
					SET CONTROL &cPrevious2 OF &cFormName NOTEDGE	// STATICEDGE
					SetProperty( cFormName, cPrevious2, "BackColor", BLUE )
					SET CONTROL &cPrevious2 OF &cFormName CLIENTEDGE
			cPrevious2 := cControl
	ENDCASE
Hay que estar activos mientras estamos en cuarentena...
We must be active while we are in quarantine ...
jairpinho
Re: FUNCTION OnMouseHover( hWnd, cFormName )
Post by jairpinho »
fantastic great job, congratulations thanks for sharing
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Hola Andrés
Como siempre , fantastico
cPrevious1 needs to be initialized:
PUBLIC cPrevious1 := ''
and cPrevious2 too!
Si
Lo siento, no traduje el comentario.
Yes
Sorry, I didn't translate the comment.
// cPrevious1 defined as PRIVATE in MAIN
jairpinho
Post by jairpinho »
andyglezl wrote: Fri Mar 27, 2020 10:52 pm Hola
Hi
	DO CASE
	ENDCASE
it is possible with button
Jair Pinho
En los BUTTONS no se pueden cambiar los colores, solo que sea: FONT, SIZE, BOLD ...
In BUTTONS you cannot change the colors, only that it is: FONT, SIZE, BOLD ...
Puedes probar cambiando:
You can try changing:
	IF EMPTY( cControl ) .OR. GetControlType( cControl, cForm ) <> "BUTTON"
hi
andyglezl wrote: Mon Mar 30, 2020 8:58 pm In BUTTONS you cannot change the colors ...
this is true when have visual Style on (default)
you can disable Visual Style with
   hwnd:= GetControlHandle( "Button_1", cForm)
   SetWindowTheme( hwnd, 0, 0 )
now you can use Color for Button
Hola Jimmy
En lo personal, yo si podría cambiar el estilo visual de mi PC, pero, (siempre hay un "pero")
hay clientes que no permiten que se les cambie. Y ya me ha pasado, que cuando modificas algo,
lo siguiente que falla, es porque "tu" causaste el problema... no se si a ustedes les pase diferente.
Prefiero no utilizar este tipo de cambios. (pero gracias por el tip)
Hi jimmy
Personally, I could change the visual style of my PC, but, (there is always a "but")
There are clients who do not allow them to be changed. And it has already happened to me,
that when you modify something, The next thing that fails is because "you" caused the problem ...
I don't know if it happens to you differently. I prefer not to use these kinds of changes.
(but thanks for the tip)
