Page 3 of 4
Re: Deactivation of main or context menu
Posted: Thu Apr 29, 2010 1:00 pm
by Roberto Lopez
gfilatov wrote:
The Marek's sample works fine after these changes:
On Key ESCAPE OF Second Action ( IIF(Empty(EndMenu()), NIL, Second.Release) )
It seems that Windows API
EndMenu() function is not
available at the Win9x
I've changed on Key code processing to do this automatically, so, it will simply work transparently from Marek's code POV.
But, there is some bad news...
In fact, there is another problem exposed by Marek's code. This problem is not related with menu or On Key processing.
The problem is the following: If you call a Msg* function, exiting from the dialog with Esc. and your attempts to close Msg* parent via 'Release' method immediately after this, the 'Release' method fails with no error message, it is simply ignored. I'm working on that.
Regarding availability of EndMenu() in 9x, you could try WM_CANCELMODE message (
http://msdn.microsoft.com/en-us/library ... S.85).aspx)
Anyway, I guess that it's time to drop Win9x support for future HMG versions. Win9x machines are near to the end of its lives.
Posted: Thu Apr 29, 2010 2:03 pm
by gfilatov
Sure. I guess that your code in h_windows.prg is similar as below
case nMsg == WM_HOTKEY
* Process HotKeys
i := Ascan ( _HMG_SYSDATA [ 5 ] , wParam )
If i > 0
If _HMG_SYSDATA [1] [i] = "HOTKEY" .And. _HMG_SYSDATA [4][i] == GetActiveWIndow()
If _HMG_SYSDATA [ 8 ] [i] == VK_ESCAPE
If Empty( EndMenu() )
Return 0
EndIf
EndIf
If _DoControlEventProcedure ( _HMG_SYSDATA [ 6 ] [i] , i )
Return 0
EndIf
EndIf
EndIf
Just idea
Posted: Thu Apr 29, 2010 2:28 pm
by Roberto Lopez
* Process HotKeys
If i > 0
Return 0
EndIf
EndIf
Return 0
EndIf
EndIf
EndIf
Just idea
Almost, but I've done _DoControlEventProcedure unconditionally processed.
Perhaps, you are right and the first Escape should close menu only and to not process Esc. user action procedure... I'm not sure... I'll think on that...
Posted: Thu Apr 29, 2010 4:23 pm
by Czarny_Pijar
Roberto Lopez wrote:Perhaps, you are right and the first Escape should close menu only and to not process Esc. user action procedure... I'm not sure... I'll think on that...
If I can vote here : Single HotKey = Single Action, no combos, please. It cost next to nothing to press the Esc key twice.
Alex Gustow wrote: At present about 30% (!! I'm shocking too
) of computers in our district's hospitals are "old and slow" and XP (or 7) can't run on that "ancients"... but Win98 runs OK;
Don't be sad! I can show you some of my clients still happy with DOS5/DOS6.2 connected to Novell3.12. Surprisingly, they do not want anything else, even if the old machine breaks down and must replace it with another of modern machine. Now my efforts are commited to slowdown these speed demons - disabling all caches is a must
Alex Gustow wrote:So (it's only my opinion) it's not yet time "to drop Win9x support for future HMG versions"... I understand that such support is a bigger and bigger problem for HMG developers (for you at first) and programmers who uses HMG... Maybe some later?..
The decision is really tough: To leave the Win9x users? To sacrifice the new possibilities? If both 'no' then what? Split the HMG into 9x-compatble and XP-and-next divisions? Happily I do not have to answer such questions.
Posted: Thu Apr 29, 2010 4:26 pm
by Alex Gustow
Roberto Lopez wrote:Anyway, I guess that it's time to drop Win9x support for future HMG versions. Win9x machines are near to the end of its lives.
I'm not fully agree with you, Roberto (but maybe I'm wrong
Let me explain my view... At present about 30% (!! I'm shocking too
) of computers in our district's hospitals are "old and slow" and XP (or 7) can't run on that "ancients"... but Win98 runs OK; and lot of "ancient" software - Office97, Foxpro for DOS, Clipper apps (and Harbour/HMG apps [created by me] of course!
) etc. - runs very well till now... and (as users said) "it works? we can execute our everyday tasks? we can input data about patients - and output various reports?.. it's fully enough for us! we haven't money for noneeded new toys..."
you at first) and programmers who uses HMG... Maybe some later?.. But it's only
your decision as "HMG father"
Posted: Thu Apr 29, 2010 7:21 pm
by Roberto Lopez
Alex Gustow wrote:Roberto Lopez wrote:Anyway, I guess that it's time to drop Win9x support for future HMG versions. Win9x machines are near to the end of its lives.
Alex,
One of my customers has a PII with Win98 working as a POS with an HMG application written by me, so, I understand you situation perfectly.
I've was talking about this issue specifically, since I'm afraid that there is no so much alternatives here (I must test WM_CANCELMODE message (9x compatible?) yet).
Anyway, with 'drop 9x', I've was thinking on things that will be ignored by 9x systems without impeding the application to work.
Moreover, MSDN had changed minimum requirements for most API calls to 'Windows XP' so, it's very difficult to know what things TRULY requires Win XP.
The solution here is simply test a demo application containing the fix (available from 3.0.32) on a 9x machine.
Anyway, the end is near
Posted: Thu Apr 29, 2010 7:44 pm
by Roberto Lopez
Czarny_Pijar wrote:Roberto Lopez wrote:Perhaps, you are right and the first Escape should close menu only and to not process Esc. user action procedure... I'm not sure... I'll think on that...
We should think about it a little more...
If you define <Esc> key to close a window, perhaps, the fact that a popup menu be visible be irrelevant and that the window must close anyway without a double <Esc>, the right solution.
So, the 'single action' could be 'close the window' without care about the menu state.
Perhaps, we should only to wait. The time is on our side. Sooner or later Win9x will disappear. Every day we are a step closer to that...
Moreover, the 'Split' is already in place. HMG 2.x is still there. It uses MingW 3.x, Harbour 1.x and code fully compliant with Win 9x. It works fine in slow machines.
Posted: Thu Apr 29, 2010 7:52 pm
by PeteWG
Hi Czarny_Pijar,
Please let me understand: Are you commenting/answering to Alex Gustov's message, 3 minutes *before* Alex publish his message?
This is a kind of quantization of the forum. How do you do that?
Pete
Posted: Thu Apr 29, 2010 8:01 pm
by Roberto Lopez
Grigory,
Not all MessageBox styles process Esc key.
According MSDN Esc key should be functional only when the MessageBox window has a <cancel> button, but this is not true.
The bottom line is that MessageBoxes processing Esc key will make SC_CLOSE (WM_SYSCOMMAND) message useless to close a window.
Have you any clue about this?
I'll still researching...
Posted: Thu Apr 29, 2010 8:13 pm
by Czarny_Pijar
Roberto Lopez wrote:We should think about it a little more...
Imagine this situation: The seller counted the whole shopping cart, now he wants to print the bill, therefore he has moved to the menu. Suddenly the customer wants one more chewing gum for the child ... Do you start with the whole bill from the beginning?
PeteWG wrote:Hi Czarny_Pijar,
Pete
That was quite easy: I've just edited my previous post, in order not to clutter this forum to much
PS
Hurray! The post number 10.000 is mine!
