Deactivation of main or context menu
When you activate main or context menu (by hotkey
(I like hotkey lastdays
)), there is no way to dewactivate it eg. by pressing ESCAPE. It's annoying in my opinion, because when I'm working with keyboard, I need to use mouse to click in any other place on the screen.
- HMG Founder
Re: Deactivation of main or context menu
I've just come out from bed and don't took my morning coffee yet...but... What do you exactly mean with 'activate a menu via a hotkey'?mol wrote:When you activate main or context menu (by hotkey(I like hotkey lastdays
Simply, I define main menu with positions:
FILE
TOOLS
HELP....
When I presss Alt-F - main menu is activated.
But, there is no way to deactivate it by keyboard, when no action from menu is needed.
FILE
TOOLS
HELP....
- HMG Founder
Ok. I'll check it, but, anyway, IMHO this is not a bug... maybe a missing feature, but not a bug...mol wrote:Simply, I define main menu with positions:
FILE
TOOLS
HELP....
I'll add to wish list...
- HMG Founder
Anyway... could be you so kind to post a sample?mol wrote:I didn't know, where to place it....
TIA.
I've prepared sample.
Please, open second window by button.
then press Alt-F (top menu of second window will be activated)
then try to press ESC
DEFINE WINDOW Main ;
WIDTH 550 ;
HEIGHT 350 ;
TITLE 'Menu Test' ;
MAIN
DEFINE MAIN MENU
DEFINE POPUP "File"
MENUITEM "exit" ACTION Main.Release
END POPUP
DEFINE POPUP "Help"
MENUITEM "About..." ACTION MsgInfo("Test of Main Menu")
MENUITEM "About HMG" ACTION MsgBox(HmgVersion())
END POPUP
END MENU
@ 80,160 BUTTON Button_1 ;
CAPTION "Press to activate second window" ;
ACTION SecondWindow() ;
WIDTH 200 ;
HEIGHT 60
On KEY ESCAPE OF Main Action {|| msgBox("Ending program"), Main.Release}
Main.Center
Main.Activate
function SecondWindow
DEFINE WINDOW Second ;
AT 200,200 ;
WIDTH 550 ;
HEIGHT 350 ;
TITLE 'Menu Test' ;
MODAL
DEFINE MAIN MENU
DEFINE POPUP "File"
MENUITEM "Close this window" ACTION Second.Release
END POPUP
DEFINE POPUP "Help"
END POPUP
END MENU
@ 20,40 LABEL Label_1 WIDTH 260 HEIGHT 20 ;
VALUE "This is second window" ;
FONT "Arial" SIZE 14
@ 60,40 LABEL Label_2 WIDTH 380 HEIGHT 20 ;
VALUE "Try to activate main menu pressing Alt-F" ;
@ 100,40 LABEL Label_3 WIDTH 320 HEIGHT 30 ;
VALUE "Then press ESC key to close it" ;
// when you change code to like this:
// Message is displayed, but releasing window Second is omitted.
//On Key ESCAPE OF Second Action {|| msgbox("I'm closing second window") , Second.Release}
On Key ESCAPE OF Second Action Second.Release
activate window Second
return
- HMG Founder
Thanks!mol wrote:I've prepared sample.
- HMG Founder
Well...Roberto Lopez wrote:Thanks!mol wrote:I've prepared sample.
I've been working with your sample and I've found some interesting things.
At first, I've not fully understood the problem in a first read, so, my prior answer was incorrect.
1. The problem is related with ON KEY ESCAPE command, so, if you do not use it, menus are processing escape key correctly.
2. The problem arises only in non-main windows.
Both, menus and msg* functions, process ESC key automatically.
When you point the fact that only first part of your code block is processed, the true fact is that the MsgBox is capturing the escape key for itself avoiding further processing.
If you exit from MsgBox with <return> you'll see that the block is fully executed.
Taking apart this, and attempting to release the windows without displaying a message, a similar conflict appears to be between menu automatic escape key processing and predefined ON KEY ESCAPE.
I'll continue researching to determine if this behavior is inherited from Windows API or not and (in both cases) if it is 'fixable'.
The fix (if possible) could take a long time for me to make it, so, if someone has additional information that helps on this, please post here!
TIA.
HiRoberto Lopez wrote: ... if someone has additional information that helps on this, please post here!
No additional information, only personal thought:
IMHO problem is ON KEY ESCAPE .. command. When this line discarded, everything work well:
- If menu activated by Alt key (or clicked), escape key deactivate it,
- If pressed a letter key after Alt key (or highlighted by mouse) and sub menu open, escape key close sub menu
These are standard OS ( Windows API ) behaviors. And if program set a key for other than standard action, system quit this standard action and obey this command.
I'm not a Win API expert, this is only my humble opinion.
