Re: QUIT problem
Posted: Wed Apr 28, 2010 9:43 pm
Roberto Lopez wrote:I'll check it ASAP.Steed wrote:Hi, Roberto
Something is happend with command QUIT i think is overlaped the commad oExcel:Quit(), attached please find a little example. the error that these show is: Test.prg(52) Error E0030 Syntax error "syntax error at 'WINDOW'"
Ed
Hola Roberto,
Algo esta pasando con el comando QUIT , creo que esta traslapando el comando oExcel:Quit(), adjunto un pequeño ejemplo, el error que muestras es:
Saludos,
Ed
Thanks for reporting.
I've found the problem.
I've added the following directive:
#xtranslate QUIT => RELEASE WINDOW ALLCode: Select all
#command QUIT => RELEASE WINDOW ALL
