QUIT problem
- Czarny_Pijar
QUIT problem
I've expected QUIT ( http://www.itlnet.net/programming/progr ... d4acc.html ) is an equivalent of Alt-F4, unfortunately not.
The bad news are: The program runned from IDE stays to reside in the memory, disabling the further development. The file error.log gives an explanation: Can't delete previous my_prog.exe version (still running?) .
The good news are: At this point with Alt-Ctrl-Del option you can remove the unwanted garbage.
Re: QUIT problem
Estimado:Czarny_Pijar wrote:I've expected QUIT ( http://www.itlnet.net/programming/progr ... d4acc.html ) is an equivalent of Alt-F4, unfortunately not.
SPANISH:
El comando QUIT efectivamente cierra la aplicación. Evidentemente debes estar haciendo algo incorrecto, revisa tu código por favor o post.
ENGLISH:
The QUIT command effectively closes the application. Obviously you must be doing something wrong, please check your code or post.
Saludos, Fernando Chirico.
- Czarny_Pijar
Re: QUIT problem
That's exactly what I want to do, but I can't.fchirico wrote: SPANISH:
ENGLISH:
I want to be able to close my program with QUIT command, without Alt-F4. There's nothing to check, QUIT is QUIT, no cotroversy here.
Re: QUIT problem
SPANISHCzarny_Pijar wrote:That's exactly what I want to do, but I can't.fchirico wrote: SPANISH:
ENGLISH:
Aparentemente tu estás intentando borrar el programa ejecutable desde el IDE. Corre tu aplicación cerrando el IDE.
De otra forma debes revisar tu código, algo no está correcto.
English:
Apparently you're trying to delete the executable program from the IDE. Run your application by closing the IDE.
Otherwise you should check your code, something is wrong.
Re: QUIT problem
Hi Czarny_PijarCzarny_Pijar wrote: ...
Did you tried
<main_form_of_your_application>.RELEASE
instead of
QUIT
- Czarny_Pijar
Re: QUIT problem
Checked: Inside IDE, outside IDE, Main.RELEASE command.
The problem still persist.
- quit_program.zip
- Contents: 2-buttons application calling QUIT and RELEASE.
Created&compiled with HMG-IDE-3.0.25 , WinXP Pro SP3 - (6.45 KiB) Downloaded 372 times
- srvet_claudio
Re: QUIT problem
Look the following example:
*** File: Main.prg ***
Load Window Main
Main.Center
DEFINE BUTTON Button_2
PARENT main // new line
ROW 110
COL 50
WIDTH 520
HEIGHT 50
ACTION release_the_prog()
CAPTION "Click to Main.RELEASE ( not working )"
FONTNAME "Arial"
FONTSIZE 16
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
HELPID Nil
FLAT .F.
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .F.
MULTILINE .F.
PICTURE Nil
PICTALIGNMENT TOP
END BUTTON
Main.Activate
*-------------------------------------- Suggested by EGISCI
procedure release_the_prog()
msginfo ("Release Window") // new line
Main.RELEASE
return
*** File: Main.Fmg ***
* HMG-IDE Form Designer Generated Code
* (c) Roberto Lopez - http://harbourminigui.googlepages.com
DEFINE WINDOW TEMPLATE AT 138 , 235 WIDTH 550 HEIGHT 350 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "" ICON NIL MAIN CURSOR NIL ON INIT Nil ON RELEASE Nil ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR Nil NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
- Czarny_Pijar
Re: QUIT problem
Ta da! finally works as expected. Thank you all for help, the response was unusuall fast and reliable, comparing to other known forums
Let's consider this thread to be solved and closed.
PS
1) srvet_claudio : I've manually corrected *.fmg file, inserting 'PARENT Main' - this also works
2) despite solving this problem, I wish in the future realease, the 'QUIT' command should be more powerfull
PS
- srvet_claudio
Re: QUIT problem
This is a similar function to the QUIT command:
Claudio
Procedure Func_QUIT ()
CLOSE ALL
RELEASE WINDOW ALL
Claudio
Re: QUIT problem
Gracias Dr.srvet_claudio wrote:This is a similar function to the QUIT command:
Your veterinary skill is extremely high (appears on your bulls
Now, could we say :
"QUIT command is highly dangerous in HMG applications. Both don't work as expected and also restricts other commands (RELEASE in example)"
Regards and saludos
