Page 3 of 6
Re: On error...
Posted: Fri Jul 20, 2012 7:52 pm
rathinagiri wrote:That's great!
Which one
Only a joke
By the way,
Esgici wrote:Please don't forget keeping your handler clean (error free); otherwise (as I noticed in top comment of .prg), result may be a real nightmare !
Made some changes for preventing this "nightmare"; please test deeply and don't hesitate to criticize
- SErrHand.zip
- Simple error handle sample - 2; .prg file
- (1.7 KiB) Downloaded 356 times
Re: On error...
Posted: Fri Jul 27, 2012 8:27 am
by Dilip Patel
Hi Rati,
Attached is a block of code which i used with clipper.
The code will have to be modified for HMG.
Hope it will be of use to you.
The code has been partially modified and can be used - see further down the blogg.
The attached file is deleted.
Re: On error...
Posted: Fri Jul 27, 2012 8:35 am
Dilip Patel wrote:Hi Rati,
Hi Dilip
Thanks to participation
Perhaps you forgot to attach your code
Re: On error...
Posted: Fri Jul 27, 2012 11:20 am
Hi Dilip
This .prg require two header files
SPECIAL.CH
LOWLEVEL.CH
Re: On error...
Posted: Fri Jul 27, 2012 1:07 pm
... and probably this isn't a Clipper .prg; may be Fox ?
... and require also a "main/host" prg ( KSMENU ?) that call / use this one
Re: On error...
Posted: Fri Jul 27, 2012 3:17 pm
by Dilip Patel
Hi Esgici,
Please find attached the CH files.
This errorsys program is a clipper routine. It was taken from a book written for clipper by Steven Straley. The KSMMENU reference was for the main menu of a clipper program. it was not necessary to reference the errorsys routine in a program. The errorsys program was compiled using clipper and the object file errorsys.obj was linked with any main clipper program.
Re: On error...
Posted: Fri Jul 27, 2012 4:37 pm
OK Dilip
I'm continuing to work.
BTW, what about copyright issue of this .prg ?
Regards.
Re: On error...
Posted: Fri Jul 27, 2012 5:33 pm
by Dilip Patel
Hi Esgici,
This program taken from a book which was purchased legally. All samples in that book were available to the purchaser. I have somewhat got it to work partially. At the moment having a problem with the last function which saves the memory variables to a memory.mem file and therafter it processes the memory file. The program seems to have a recursion problem which i cannot solve.
Dilip
Re: On error...
Posted: Fri Jul 27, 2012 6:15 pm
OK Dilip
Re: On error...
Posted: Fri Jul 27, 2012 6:44 pm
by Dilip Patel
Attached find test results of the modified error routine for HMG. I have been communicating with Esgici regarding the program. I have got it to work partially. For the memory variables to be also listed in the error file, some one with more knowledge than myself with have to solve it. I am having a problem with 'recursion' in that routine. That part of the program has been commented out. Also the screen saving part will also have to be modified.
Dilip
