On error...
On error...
In HMG, can we have some error catching blocks (like try...catch... in Java) that shall be executed before the application is closed abruptly?
For operations like saving some files, closing the database connections, re-encrypt the decrypted files?
raumi75
Re: On error...
Post by raumi75 »
That is a question I have asked myself many times.
Is use the clipper command
ERRORBLOCK({ |oErr| MyOnError(oErr)})
To log real serious errors.
How do you guys catch errors?
Raumi
Re: On error...
Hi Rathi and Raumi
Did you tried BEGIN/END SEQUENCE structure ?
Re: On error...
Nope Esgici. I will try. :)
Re: On error...
I use this in IDE to report preview and works perfectly (I've adapted from an old Clipper sample.
bSaveHandler := errorblock( { |x| break(x) } )
BEGIN SEQUENCE
     * This is the code to execute that could fail
     EXECUTE REPORT _TempReport PREVIEW
     DELETE FILE RePreviewSemaforo.Txt
RECOVER USING oError
     * This is the code to execute if the above code fails
     MSGSTOP( oError:Description + " " + oError:Operation  , "Report Error:" )
     Exit Program
END
errorblock( bSaveHandler )
Re: On error...
A more useful sample is shown in Clipper manual:
This example demonstrates an error handler returning an error
        object to the variable specified in the USING clause of the RECOVER
        statement:
            LOCAL objLocal, bLastHandler
            // Save current and set new error handler
            bLastHandler := ERRORBLOCK({ |objErr| ;
                  MyHandler(objErr, .T.) })
            BEGIN SEQUENCE
               . <operation that might fail>
            RECOVER USING objLocal
               // Send messages to objLocal and handle the error
               ? "Error: "
               IF objLocal:genCode != 0
                  ?? objLocal:description
            END
            // Restore previous error handler
            ERRORBLOCK( bLastHandler )
            FUNCTION MyHandler( objError, lLocalHandler )
               // Handle locally returning the error object
               IF lLocalHandler
                  BREAK objError
               . <other statements to handle the error>
Re: On error...
Thanks Roberto. I will go through and use it.
Re: On error...
I'm using errorblock and begin/end sequence.
In one of my latest projects I've added sending e-mail with error to me, when something wrong is going on...
Re: On error...
Hi Rathi
A little (!?) late answer (because just added) : a short compilation about error handling
I hope that will be useful :)
Rossine
Re: On error...
Post by Rossine »
Hello all,
This interests me :)
It would be possible to assemble a complete example to demonstrate this new method using error control and the old ?
Rossine.
