Page 20 of 21
Re: HMG.3.4.2
Posted: Wed May 04, 2016 3:11 pm
by srvet_claudio
mol wrote:
1) while control is moved to debugger window, application should be blocked. Now, When focus is set to debugger window, you can operate on application and it causes errors.
2) I'm using two displays in my work - is there a way to remember position of debug window (on the second screen) and recall these coordinates at next run?
I am sorry but I do not understand
mol wrote:there was splitted area of source code with evaluation area in traditional debugger. Could it be done in this way in your solution, Claudio?
I wrote down on my to-do list.
Re: HMG.3.4.2
Posted: Thu May 05, 2016 12:51 pm
by mol
Sorry for my bad English, I want to place sample and some screenshots to illustrate what about I'm thinking.
First - Run this sample in debugger mode:
* HMG - Harbour Win32 GUI library
* Copyright 2002-2008 Roberto Lopez <mail.box.hmg@gmail.com>
* http://www.hmgforum.com//
Function Main()
set century on
set date ital
WIDTH 400 ;
HEIGHT 200 ;
MAIN;
TITLE 'Test'
@ 30,70 BUTTON Button_1 CAPTION "Run test" WIDTH 200 HEIGHT 50 ACTION CallForm2()
CENTER WINDOW Form_1
FUNCTION CallForm2
DEFINE WINDOW Form_2 ;
WIDTH 400 ;
HEIGHT 200 ;
TITLE 'second window...';
MODAL
@ 10,10 LABEL LABEL_1 VALUE "This is only label..."
@ 30,70 BUTTON Button_1 CAPTION "CALL DEBUGGER ALTD()" WIDTH 200 HEIGHT 50 ACTION TestLabelValue()
CENTER WINDOW Form_2
ACTIVATE WINDOW Form_2
return
function TestLabelValue
altd()
// close form_2 manually before next step!
msgbox(Form_2.Label_1.Value)
return
Call second window and press button to call TestLabelValue() function
This function recalls debugger
( links below contains pictures illustating situations - I can't place these screenshots in another way now...)
https://dysk.onet.pl/link/Vck6R#
Now - close Form_2 window by clicking X
https://dysk.onet.pl/link/K402d
And now - Use GO function in debugger
https://dysk.onet.pl/link/7qP0S
Debugger crashes because manipulating with application forms is allowed...
It's only programmer problem, but, would be fine if such a situation could be disabled
Re: HMG.3.4.2
Posted: Thu May 05, 2016 3:11 pm
by srvet_claudio
mol wrote:Sorry for my bad English, I want to place sample and some screenshots to illustrate what about I'm thinking.
Function Main()
set century on
set date ital
WIDTH 400 ;
HEIGHT 200 ;
MAIN;
TITLE 'Test'
FUNCTION CallForm2
WIDTH 400 ;
HEIGHT 200 ;
MODAL
return
altd()
return
Hi Marek,
I can hardly reproduce the error, these are the right steps:
1) In debugger press Animate Button --> activate form_1 (line 27)
2) Press "Run Test "--> activate form_2 (line 47)
3) Press "CALL DEBUGGER ALTD()"
4) Close MsgBox() (line 56)
5) Close form_2 (click X)
6) In debugger press Go Button
If you eliminate the AltD() function of the source code, the bug persist ?
PD: AltD() is only for Harbour debugger (console mode)
Re: HMG.3.4.2
Posted: Thu May 05, 2016 5:04 pm
by mol
There is no big problem with this "bug". I must to use debugger in this new way...
Old, ALTD() function also calls your debugger and it's fine
Re: HMG.3.4.2
Posted: Thu May 05, 2016 8:42 pm
by srvet_claudio
mol wrote:There is no big problem with this "bug". I must to use debugger in this new way...
Please, insert this code in your .prg file and test it:
PROCEDURE AltD()
HMG_Debugger():Pause()
I have not documented the HMG Debugger class, but you can invoke the debugger from your source code, for example:
#pragma /b+ // this directive force to compile this file in debug mode
FUNCTION MAIN
Local cFileName := ProcFile( 0 ) // this file
Local nLine := 69 // line of code
Private nCount := 0
IF .not. HMG_Debugger():IsValidStopLine( cFileName, nLine )
nLine := HMG_Debugger():GetNextValidStopLineEx( cFileName, nLine )
HMG_Debugger():BreakPointToggle( cFileName, nLine )
DEFINE WINDOW Form1 ;
WIDTH 640 HEIGHT 480 ;
TITLE 'Main Window' ;
@ 200,250 BUTTON Button_1 CAPTION 'ProcTest' ACTION ProcTest()
HMG_Debugger():Go()
HMG_Debugger():Step()
HMG_Debugger():Animate()
HMG_Debugger():Trace()
HMG_Debugger():SetCBTrace( lCBTrace )
HMG_Debugger():SetToCursor( cFileName, nLine )
HMG_Debugger():Quit()
HMG_Debugger():Exit()
HMG_Debugger():GetNextValidStopLine( nProcLevel )
HMG_Debugger():BreakPointCount()
HMG_Debugger():IsBreakPoint( cFileName, nLine )
HMG_Debugger():BreakPointDelete( nPos )
HMG_Debugger():BreakPointDeleteAll()
HMG_Debugger():BreakPointAddFunc( cFuncName )
HMG_Debugger():GetExprValue( xExpr, lValid )
HMG_Debugger():WatchCount()
HMG_Debugger():WatchDeleteAll()
HMG_Debugger():WatchDelete( nWatch )
HMG_Debugger():WatchGetInfo( nWatch )
HMG_Debugger():WatchSetExpr( nWatch, cExpr )
HMG_Debugger():WatchPointAdd( cExpr )
HMG_Debugger():TracepointAdd( cExpr )
other methods
HMG_Debugger():TracepointAdd( "nCount == 2" ) // add Trace point
HMG_Debugger():BreakPointToggle() // Toggle BreakPoint in the following line of code of this file
Form1.TITLE := "BreakPoin 1"
Form1.TITLE := "BreakPoin 2"
CENTER WINDOW Form1
ACTIVATE WINDOW Form1
PROCEDURE ProcTest
nCount++
MsgDebug ("ProcTest", nCount)
When it is not compiled in the form of debugging, HMG ignores calls the functions of the debugger and therefore do not need to remove them from your source code.
Re: HMG.3.4.2
Posted: Thu May 05, 2016 9:46 pm
by srvet_claudio
srvet_claudio wrote:mol wrote:Sorry for my bad English, I want to place sample and some screenshots to illustrate what about I'm thinking.
Function Main()
set century on
set date ital
WIDTH 400 ;
HEIGHT 200 ;
MAIN;
TITLE 'Test'
FUNCTION CallForm2
WIDTH 400 ;
HEIGHT 200 ;
MODAL
return
altd()
return
Hi Marek,
Hi Marek,
I investigated your code, is not a bug is the normal behavior of Windows, change your function for this function and see the comments:
Function TestLabelValue
MsgInfo(" If you close Form_2 at this point by clicking on X box" + hb_eol() +;
" it is equivalent to call Form_2.RELEASE at this point" + hb_eol() +;
" and consequently the following code ( Form_2.Label_1.Value ) is invalid")
HMG_Debugger():Pause() // the program stop at this point
IF IsWindowDefined( Form_2 )
MsgInfo( Form_2.Label_1.Value )
MsgInfo("Error: Form_2 is released")
Re: HMG.3.4.2
Posted: Fri May 06, 2016 4:19 am
Nice Claudio. I think you can document some portion of HMGDebugger() for effective use of the debugger from inside source code.
Re: HMG.3.4.2
Posted: Fri May 06, 2016 4:51 am
by srvet_claudio
Rathinagiri wrote:Nice Claudio. I think you can document some portion of HMGDebugger() for effective use of the debugger from inside source code.
Yes, I have to document this class!
Re: HMG.3.4.2
Posted: Fri May 06, 2016 5:23 am
by mol
Thank you, Claudio!
Re: HMG.3.4.2
Posted: Fri May 06, 2016 8:16 pm
srvet_claudio wrote:Rathinagiri wrote:Nice Claudio. I think you can document some portion of HMGDebugger() for effective use of the debugger from inside source code.
Buenisimo
