Page 2 of 5
Re: HMG Forum "Codebox" Reader
Posted: Sun Aug 14, 2022 9:22 am
Jimmy,
Write own date conversion, I think
Posted: Sun Aug 14, 2022 11:15 am
by mustafa
Hi Jimmy:
possible date conversion?
https://vivaclipper.wordpress.com/2014/01/19/set-date/
#include "HMG.CH"
PROCEDURE MAIN
SET DATE FORMAT TO 'dd/mm/yyyy'
SET DATE ANSI
fecha1 := DTOC( DATE())
hora  := TIME()
fecha2 := SUBSTR( fecha1 , 1, 4)
fecha3 := SUBSTR( fecha1 , 6, 2)
fecha4 := SUBSTR( fecha1 , 9, 2)
msginfo(  fecha1  + CRLF + CRLF + HORA )
msginfo( fecha2 + "-"+ fecha3 + "-" + fecha4  + CRLF + CRLF + hora )
Posted: Sun Aug 14, 2022 7:28 pm
by AUGE_OHR
have forgot to say that CONFIG.INI was create
[CONFIGURATIONS]
Row=0
Col=0
Width=1024
Height=800
MemoRow=0
MemoCol=0
MemoWidth=1024
MemoHeight=800
FontSize=16
1-4 belong to MAIN Window. other are CODE Window
when Row=0 and Col=0 Windows will be CENTER
p.s. minimum Width = 800 and Height = 500
Posted: Mon Aug 15, 2022 8:19 pm
by AUGE_OHR
hi
this Version can "better" handle "other" PhpBB Forum like Xbase++ Forum or Fivewin Forum
FORUMHMG_23.zip
(1.55 MiB) Downloaded 416 times
! Note : delete CONFIG.INI as a new enhanced File will be create
Posted: Wed Aug 24, 2022 3:33 pm
by AUGE_OHR
i found a Problem to get "new" Mail of "old" Thread ...
when press F7 it will get "next" 100 Thread but there can be a "New" Message of "old" Thread
so i have to start with "old" Number ... but which "old" Number(s) ...
the only Way seems to start from 1 (it will seek for Dupe Date/Time)
is there any other Way :idea:
Posted: Thu Aug 25, 2022 10:38 am
An interesting project! Useful to understand and get data from internet websites!
Posted: Thu Aug 25, 2022 4:27 pm
by AUGE_OHR
hi Rathinagiri,
I don't dare to publish the CODE which "analyze" a Website ... it is "quick and dirty" from an Internet Dummy :roll:
Posted: Fri Aug 26, 2022 6:34 am
Nothing wrong with 'quick and dirty'!
Posted: Wed Aug 31, 2022 12:10 am
by AUGE_OHR
i "think" a have a Solution to "analyze" Message
   aTopic := MarkerPos( '<h3 class="first">', cMemo )
   aAuthor := MarkerPos( '<p class="author">', cMemo )
   IF "fivetechsupport" $ LOWER( cWorkURL )
      aDateTime := MarkerPos( '&raquo;', cMemo )
      aDateTime := MarkerPos( '<time datetime="', cMemo )
   aContent := MarkerPos( '<div class="content">', cMemo )
   aQouteIn := MarkerPos( '<blockquote>', cMemo )
   aQouteOut := MarkerPos( '</blockquote>', cMemo )
   aCodeIn := MarkerPos( '<code>', cMemo )
   aCodeOut := MarkerPos( '</code>', cMemo )
   aEndBody := MarkerPos( '<div id=', cMemo )
i do ADD all to aBody and sort Position
   AADD( aBody, { aContent[ ii ] , "StartBody"  } )
   AADD( aBody, { aQouteIn[ ii ] , "QouteIn"    } )
   AADD( aBody, { aQouteOut[ ii ], "QouteOut"   } )
   AADD( aBody, { aCodeIn[ ii ]  , "aCodeIn"    } )
   AADD( aBody, { aCodeOut[ ii ] , "aCodeOut"   } )
   AADD( aBody, { aEndBody[ ii ] , "EndeBody"   } )
   aBody := ASORT( aBody,,, { | aX, aY | aX[ 1 ] < aY[ 1 ] } )
now i do search for "Marker" and than "strip" HTML from Body / CODE
why that Way :
a Message begin with '<div class="content">' and End is '</div>' ... but there are more
you also can have '<blockquote>' and '</blockquote>' ... "<code>" and "</code>" ...
while it can be many "Quote" and "Code" i had Problem before when try to work with MEMOLINE()
now it seems to work "better" as i got "more than 1 x "Quote" oder "Code" and no "Code" in "Body" any more
Thx Edward for Code to "translate" Body of Message, it work PERFECT !
for this i have add it in CONFIG.INI so please delete "old" Version
[TRANSLATEWINDOW]
TranslateRow=0
TranslateCol=1024
TranslateCP=DE
Size and Font i use same as for "Code" Window
please change TranslateCP to your Codepage e.g. EN, ES, PL etc
as i have "new" Entry in HTMLSIGN.DBF please delete "old" DBF, it will be create new
have change Design with bigger "Body" Windows
i will clean up Source Code and than release it here in Forum.
here new EXE
FORUMHMG_40.zip
(1.71 MiB) Downloaded 378 times
p.s. most of last Work was for FiveWin Forum. for HMG Forum "old" Concept does not make those Problem
Posted: Thu Sep 01, 2022 12:17 am
by AUGE_OHR
i last version i use "in" FILTER
!DELETED()
which slow down BROWSE :(
please wait for next Version include Source Code which i have clean up
