Page 2 of 2
Re: consumo de API REST con HMG
Posted: Sun Mar 21, 2021 7:36 pm
by nekbmm
I do not know if it will work because I do not have authorization data, I have no way to check.
I found the Swagger UIhttps://rcrf.trezor.gov.rs/swagger/index.html and what surprised me is that there is a different json structure for the "/ api / invoice / register" function than that given in https://crf.trezor.gov.rs/docs/user/int ... ceregister
I think these are different versions of the API.
Thank you for your reply. I tried your example and hb_HGetDef() returns empty creationTime, accessToken and refreshToken even though they are
shown in response(attachment).
How can I access these data?
Posted: Sun Mar 21, 2021 9:27 pm
by edk
nekbmm wrote: Sun Mar 21, 2021 7:36 pm How can I access these data?
Oh, I was expecting a different response (that's how it is, if I don't know Serbian :D )
The AccesToken is included in the "payload" key. First, the value of the "payload" key should be read, we should receive another Hash, and from this Hash we read the "accessToken" key.
Check out this code snippet:
//login
cApiFunction :=  "/api/login"
//prepare json
hAtributi := { => }
hAtributi ["login"] := "foo"
hAtributi ["password"] := "bar"
strfile (hb_jsonEncode( hAtributi , .F. ), 'login_json.txt')
cResp := SendRestApi( cUrl + cApiFunction, hb_jsonEncode( hAtributi , .F. ), oRestApi )
IF cResp = "!ERROR!"
	MsgStop (cResp)
	oRestApi := Nil
	Quit
IF oRestApi:Status <> 200
	MsgStop ( "HTTP status: " + hb_NToS(oRestApi:status) + " "  +oRestApi:statusText + CRLF + CRLF + "Response: " + cResp )
hResp   := hb_jsonDecode( cResp )
hStatus := hb_HGetDef( hResp  , "status", { => } )
msginfo ("Message :" + hb_HGetDef( hStatus  , "message", "" ) + CRLF + "Code    :" + hb_ValToStr ( hb_HGetDef( hStatus  , "code", "" ) ) )
hPayload := hb_HGetDef( hResp  , "payload", { => } )
cCreationTime := hb_HGetDef( hPayload  , "creationTime", "" )
cAccessToken  := hb_HGetDef( hPayload  , "accessToken", "" )
cRefreshToken := hb_HGetDef( hPayload  , "refreshToken", "" )
msginfo ( "creationTime: " + cCreationTime + CRLF + ;
	  "accessToken:  " + cAccessToken + CRLF + ;
  	  "refreshToken: " + cRefreshToken )
IF Empty ( cAccessToken )
	MsgStop ("No accessToken, no authorization !!!")
I am not sure about the authorization yet, according to the description, the accessToken should be sent in the header "Authorization" as Bearer <accessToken>, while in Swagger it is sent without the word "Bearer". If the authorization does not work, try changing to:
oRestApi:setRequestHeader ("Authorization", cAuth)
Posted: Mon Mar 22, 2021 7:05 am
by nekbmm
Thanks edk, it's working now !
Posted: Tue Mar 23, 2021 2:19 am
by edufloriv
Edk it works !! - Thanks a lot mi friend if you visit Perú some day, I will be your guide.
Here is the response:
Works perfectly !!
Best regards !!
Edk muchas gracias, funciona. Si visitas algún dia Perú yo seré tu guia, tenlo por seguro.
Esta es la respuesta de la Api-Rest:
Trabaja perfecto !!
Saludos y un abrazo.
Posted: Tue Mar 23, 2021 10:04 am
by edk
edufloriv wrote: Tue Mar 23, 2021 2:19 am Si visitas algún dia Perú yo seré tu guia, tenlo por seguro.
Gracias, mi tocayo.
Posted: Tue Sep 21, 2021 2:54 pm
by jparada
I am trying to work with Monday API and I'm guiding myself in the example code, it doesn't generate an error, but I don't get any response, I know that the token and query are correct because I have tested them in the Monday live playground and I get the expected results, this is an example of how they perform the request with the VBA language
Public Pass As Variant
Sub monday()
 Dim monday As New MSXML2.ServerXMLHTTP60
 Dim response As Variant
 Dim status As Variant
 Dim query As String
 query = " { ""query"" : ""{boards(ids: xxxxx){views{name}}}""} "
    With monday
        .Open "POST", myurl , False
        .SetRequestHeader "Content-Type", "application/json"
        .SetRequestHeader "Accept", "application/json"
        .SetRequestHeader "Authorization", mytoken
        .Send query
        response = .ResponseText
        status = .status & " | " & .StatusText
        MsgBox response
        MsgBox status
    End With
and this is the code that I am trying
Function main
  Local cUrl := "https://api.monday.com/v2"
  Local nTimeOut := 20  // seconds
  Local oRestApi
  Local cReturn, cResponse
  Local cAuth := "TOKEN"
  oRestApi := Win_OleCreateObject( "MSXML2.ServerXMLHTTP" )
  oRestApi:setTimeouts(nTimeout * 1000 /* nResolve */ , nTimeout * 1000 /* nConnect*/ , nTimeout * 1000 /* nSend */, nTimeout * 1000 /* nReceive */ )
  If Empty( oRestApi )
	  ? "Error al inicializar..."
	  Return NIL
  Endif
  query = ' { ""query"" : ""{boards(ids: 1673472238){name views{name}}}""} '
  BEGIN SEQUENCE WITH { |o| Break(o) }
    oRestApi:Open( "POST", cUrl, .F. )
    oRestApi:setRequestHeader( "Content-Type", "application/json" )
    oRestApi:setRequestHeader( "Accept", "application/json" )
    oRestApi:setRequestHeader( "Authorization", cAuth )
    oRestApi:Send( query )
    ? cReturn  := hb_jsonDecode( oRestApi:ResponseText() )
    ? hb_jsonDecode( oRestApi:ResponseBody() )
  RECOVER USING oErr
    cReturn := "Error!" + hb_eol() + If ( ValType( oErr ) = 'O', oErr:Description, oErr )
  END SEQUENCE
  oRestApi := NIL
what's wrong with my test?
I appreciate any help
Javier
Posted: Wed Sep 22, 2021 2:57 am
by jparada
I advanced just a little more just adding
 oRestApi:Send( hb_jsonEncode ( query ) )
I get a 200 code in the request, but I don't get the correct result
doing a test by command line with curl the query should be escaped something like this:
 "{\"query\":\"{ boards (ids: 1673472238){name views{name}}}\"}"
how can i send something like that with harbour, this doesn't work either:
query :=  '{"query": "{boards (ids: 1673472238){name views{name}}}"}'
Any idea?
Javier
Posted: Wed Sep 22, 2021 2:24 pm
by martingz
Maybe this
#xcommand TEXT TO VAR <var> => #pragma __stream|<var>:=%s
TEXT TO VAR cQuery
ENDTEXT
Posted: Thu Sep 23, 2021 3:24 am
by jparada
Hi Martín,
It was my fault because i was sending the query encoded as json, and that's why it sent the malformed query
and no need to escape the characters.
There will be some advantage or disadvantage to make the request with cURL against XMLHttpRequest, just to know...
Javier
