Page 2 of 2
Re: Grids vacíos ?
Posted: Sun Aug 23, 2020 5:26 pm
by cmaciass
franco wrote: Sun Aug 23, 2020 4:05 pm Are you running hmg 3.44 ?
Hi !
Yes, the version I am using is 3.4.4
Re: Grids vacíos ?
Posted: Mon Aug 24, 2020 4:24 pm
by franco
It looks like the grid is not linked to the table with municipio.
you may have to select the table and refresh the grid.
On my invoicing windows. I set focus to grid after end define and before I activate the window, and on got focus of grid I refresh the the grid.
I wonder if at the start of the window you could check the table record number of the grid cell one.
Re: Grids vacíos ?
Posted: Mon Aug 24, 2020 5:59 pm
by mol
I had a lot of problems with grid with dbf many years ago.
Until now I'm using browse control for dbfs viewing. Faster, stable and without any problems
Re: Grids vacíos ?
Posted: Mon Aug 24, 2020 6:29 pm
by Ismach
Quiero ver el codigo del "USE", no deberia ser con opcion USE <BASE> SHARED ?
       USE Usuarios SHARED NEW
        IF !NETERR()
              SET INDEX TO CodUser
              MSGINFO("USE FALLIDO")
              RELEASE WINDOW ALL
Re: Grids vacíos ?
Posted: Mon Aug 24, 2020 7:02 pm
by cmaciass
Hola, a todos !! :) :)
Mil gracias por sus consejos y aportaciones, resolvi el problema, utilizando los grids con arrays (ITEMS) en vez de cargarlos directo desde el dbf (ROWSOURCE) y ya está funcionando
Hi all !! :)
Thank you very much for your advice and contributions, I solved the problem, using the grids with arrays (ITEMS) instead of loading them directly from the dbf (ROWSOURCE) and it is already working
:D
Carlos Macias
Re: Grids vacíos ?
Posted: Tue Aug 25, 2020 10:18 am
by franco
I agree with Mol.
I use browse for viewing from dbf`s, no arrays.
Re: Grids vacíos ?
Posted: Tue Aug 25, 2020 5:18 pm
by tonton2
cmaciass wrote: Sun Aug 23, 2020 4:11 am Me esta pasando en todos los grids y con diferentes DBFS solo funciona en la primer ejecución de la aplicación, al abrir una segunda vez ya sea en el propio equipo o en otros en red los grids no muestran la información, los grids los alimento a través de ROWSOURCE en donde indico el alias del dbf... :(
Bonsoir
j'ai déjà eu ce problème et je l'ai à ce jour aléatoirement, cela m'arrive lors d'une ouverture d'une base de données après avoir fermé une précédente base.
Re: Grids vacíos ?
Posted: Tue Aug 25, 2020 5:20 pm
by tonton2
mol wrote: Mon Aug 24, 2020 5:59 pm I had a lot of problems with grid with dbf many years ago.
je confirme le problème ne se pose pas avec "BROWSE"
