Page 2 of 4
Posted: Fri Dec 09, 2016 1:53 pm
by mol
I'm using 32bit
Compiling error by Marek
Posted: Fri Dec 09, 2016 2:29 pm
mol wrote:I'm using 32bit
:shock:
Please give more information. Like what HMG version and what SO and if you tried as I indicated and in what case (hb_SendMail / tip_MailSend) is not compiling ?
I've tested this demo in another PC without any installation and works pretty well...
Very poor info... :|
Posted: Fri Dec 09, 2016 4:33 pm
by mol
Hmg343, but I 'm out of office and home this week. I can test it at monday
Posted: Fri Dec 09, 2016 4:35 pm
by mol
My app doesn't want to link. I'm using hb_sendmail.
I had problems with ssl, so I want to test these libraries
hb_SendMail / tip_MailSend and CDO
Posted: Sat Dec 10, 2016 1:23 am
I am proud and glad to introduce to you more this way of sending emails: vbs_SendMail ( via CDO ) :D
The example is in VBScript (I love it, simple, practical, and powerful).
This new function does not require any extra library.
Please change emails address for testing.
I hope you like it. :P
vbs_SendMail.rar
Source files
(1.81 KiB) Downloaded 456 times
Multiple address for To, Cc and BCc. Attached files and works in GMail server.
mol wrote:Hmg343, but I 'm out of office and home this week. I can test it at monday
Marek, in view of your difficulties with libraries, probably this will be your good choice to use it. :)
I have tested and it's workings perfectly !!! (Works like a charm, I'm happy)
Posted: Sat Dec 10, 2016 12:37 pm
Maybe some might think I just copied and posted ... But no.
I took this example in pure VBScript:
EmailSubject = "Sending Email by CDO"
EmailBody = "This is the body of a message sent via" & vbCRLF & _
            "a CDO.Message object using SMTP authentication ,with port 465."
' What's in [] must be replaced by its contains
Const EmailFrom = "[myemail]@gmail.com"
Const EmailFromName = "[myfull name]"
Const EmailTo = "[other email, could be my email too]@gmail.com"
Const SMTPServer = "smtp.gmail.com"
Const SMTPLogon = "[myemail]@gmail.com"
Const SMTPPassword = "[mypassword]"
Const SMTPSSL = True
Const SMTPPort = 465
Const cdoSendUsingPickup = 1    'Send message using local SMTP service pickup directory.
Const cdoSendUsingPort = 2  'Send the message using SMTP over TCP/IP networking.
Const cdoAnonymous = 0  ' No authentication
Const cdoBasic = 1  ' BASIC clear text authentication
Const cdoNTLM = 2   ' NTLM, Microsoft proprietary authentication
' First, create the message
Set objMessage = CreateObject("CDO.Message")
objMessage.Subject = EmailSubject
objMessage.From = """" & EmailFromName & """ <" & EmailFrom & ">"
objMessage.To = EmailTo
objMessage.TextBody = EmailBody
objMessage.AddAttachment "D:\Fontes\HMG\eMail\VBScript\Test1.txt" ' Full Path must be informed
objMessage.AddAttachment "D:\Fontes\HMG\eMail\VBScript\Test2.txt" ' Full Path must be informed
' Second, configure the server
objMessage.Configuration.Fields.Item _
("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
("http://schemas.microsoft.com/cdo/configuration/smtpserver") = SMTPServer
("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = cdoBasic
("http://schemas.microsoft.com/cdo/configuration/sendusername") = SMTPLogon
("http://schemas.microsoft.com/cdo/configuration/sendpassword") = SMTPPassword
("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = SMTPPort
("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = SMTPSSL
("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 60
objMessage.Configuration.Fields.Update
' Now send the message!
On Error Resume Next
objMessage.Send
If Err.Number <> 0 Then
    MsgBox Err.Description,16,"Error Sending Mail"
Else
    MsgBox "Mail was successfully sent !",64,"Information"
End If
I relied on it, first tested it on the command line by writing it to .vbs file extension and: bingo! So I decided to convert line by line. I found several difficulties, but thanks to the internet, we can count on a great collection.
I have started by quite zero, but after I was able to compile, I saw that the sequence of creating message first and then configuring message: was reversed to the use case by Harbour. I saw this in an example of another forum.
Today I saw Daniel Maximiliano made and posted here in the forum but it's different. I feel mission accomplished, because it works first. If this code that I posted with the correct email addresses was written to a .vbs file and executed on the command line; Will work perfectly.
Re: hb_SendMail / tip_MailSend and CDO
Posted: Mon Dec 12, 2016 9:35 am
by mol
libeay.dll and ssleay.dll are dynamically linked libraries, so phrase:
libs=libeay.dll
libs=ssleay.dll
is wrong and causes linker error.
Posted: Mon Dec 12, 2016 10:05 am
Marek, please remove .dll at your .hbc file.
Let it like I have indicated:
Remember also to be included:
libs=hbtip
libs=hbssl
After your right setup of .hbc you compile again.
But please do nothing to replace any original HMG library.
Posted: Mon Dec 12, 2016 10:42 am
by mol
I missed "32"
Sorry for my carelessness :shock:
Posted: Mon Dec 12, 2016 10:47 am
It's Ok, Marek. The important we found mistake at time of give up...
Have you tested with CDO way ? Any restrictions/disadvantages about CDO ?
