Run Notepad to display text file
Posted: Sat Jan 14, 2017 1:48 am
by RussBaker
This should be easy, but I'm having trouble.
My code is
RUN ( "NOTEPAD" + "report.TXT" )
I want to display my report.txt in notepad after it's generated and wait for the user to close it.
Why doesn't this work?
Is there a simple way to display a text file in HMG?
Posted: Sat Jan 14, 2017 2:25 am
RussBaker wrote: ↑Sat Jan 14, 2017 1:48 am
My code is
Hi Russ,
It did not work because it is simply missing a space character between NOTEPAD and its filename.
RUN ( "NOTEPAD" + " report.TXT" ) // check if report.TXT is in the current folder (same folder than executable's folder)
There is better use with:
EXECUTE FILE "report.TXT"
Sometimes we hit our heads and find no solution, and the mistake we made is well ahead of us ...
Re: Run Notepad to display text file
Posted: Mon Jan 16, 2017 4:58 am
by RussBaker
Gracias Pablo.
That was exactly the problem. It is working now.
--Russ
