SQL Help
MGOLDFARB
SQL Help
Post by MGOLDFARB »
The following query seems to have the desired result when I execute it from MS SQL Server Management Studio:
insert into epictest.dbo.prtcrd (cempno,clname,cfname,ctaxstate,cdeptno,ctcno,dtrs) select idno,lname,fname,taxstate,fdept,transid,'20140920' from epictest.dbo.payupdate
However, when I run from my application (text from application below) , it does not seem to execute. It seems to do nothing.
sSQL = "insert into epictest.dbo.prtcrd (cempno,clname,cfname,ctaxstate,cdeptno,ctcno,dtrs) select idno,lname,fname,taxstate,fdept, transid, '20140920' from epictest.dbo.payupdate "
lodp := RDDINFO(1003, ssql)
Anyone with any ideas?
Thanks!
Mark
dhaine_adp
Re: SQL Help
Post by dhaine_adp »
Hello Mark,
If you add a semi-colon at the end of the statement like below:
sSQL = "insert into epictest.dbo.prtcrd (cempno,clname,cfname,ctaxstate,cdeptno,ctcno,dtrs) select idno,lname,fname,taxstate,fdept, transid, '20140920' from epictest.dbo.payupdate;"
Does it make any difference?
Good luck,
Danny
Danny
Manila, Philippines
franco
Re: SQL Help
Post by franco »
Can anyone tell me why this does not work.
I am trying to this type of sql in my program.
ot what do I need to do to make it work
#include <mysql.ch>
   tbls()
DEFINE WINDOW Form_1 ;
		WIDTH 600 ;
		HEIGHT 610 ;
		Main;
		on release {|| 'close all tables' } ;
		TITLE 'SQL Test'
		@95,10 BUTTON Button_2 CAPTION '              SEARCH' WIDTH 75 HEIGHT 75 ;
		       MULTILINE NOTABSTOP TOOLTIP 'Add New Item:'  ACTION { || ADD()}
	    DEFINE GRID Grid_1
         COL 0
         ROW 190
         WIDTH 1300
         HEIGHT 200
         HEADERS {"Item", "Description"}
         WIDTHS {100,195 }
		 JUSTIFY {0,0}
         ROWSOURCE "inv"
         COLUMNFIELDS {"num1", "desc"}
		END GRID
        form_1.Center
        form_1.Activate
function tbls
   LOCAL CF
   if ! file('inv.dbf')
        CF := {}
        aADD(CF,{'NUM1'       ,'C' , 15,0})
        aADD(CF,{'DESC'       ,'C' , 25,0})
		aAdd(CF, {'NUM2'      , 'C'  , 25,0 })
		aAdd(CF, {'NUM3'      , 'C'  , 25,0 })
	    aAdd(CF, {'COST'      , 'N'  , 10,2 })
		aAdd(CF, {'UNIT_PRICE ', 'N'  , 10,2 })
   if !hb_dbcreatetemp("inv", cf)
       msgbox("Cannot create temporary table: Item")
       RELEASE WINDOW ALL
       return nil
	   USE INV EXCLUSIVE NEW
       INDEX ON NUM1 TO NUM1
        do while recno()< 500
	      Inv->( DBAPPEND())
	      Inv->( FIELDPUT(1, 'P'+ALLTRIM(STR(20+RECNO())) ))
		  Inv->( FIELDPUT(2, 'DESC'+ALLTRIM(STR(20+RECNO())) ))
		  Inv->( FIELDPUT(3, 'N2'+ALLTRIM(STR(20+RECNO())) ))
		  Inv->( FIELDPUT(5, RECNO()))
		  Inv->( FIELDPUT(6, 20+RECNO()))
	      LOOP
        enddo
       use
       use inv new
	   set index to num1
return
procedure add       //////////////// saved for review only
 aTable := mySQL(dbo, "select * from inv")
return
I would like to use my sql table in the grid,
at this time program crashes at mysql.
Thanks Franco ;)
All The Best,
Franco
Canada
Re: SQL Help
Where did you realised connection to mysql database?
franco
Re: SQL Help
Post by franco »
I do not know how to do this.
can you help ............ Franco
All The Best,
Franco
Canada
Re: SQL Help
Why can't you use HMGMySQL library to connect and query?
franco
Re: SQL Help
Post by franco »
not sure how.
I have 3 tables I need to select from.
like
select name from table1, custid from table2, inv_no from table3 where table1->custid = table2->custid .and.
table3->inv_no = table2->inv_no into table temp.
how can I set up to connect to these 3 tables first.
Thanks Franco
All The Best,
Franco
Canada
Re: SQL Help
Franco,
Try something like this:
FUNCTION SQL_Connect()
dbo := tmysqlserver():new(ALLTRIM(your_host),ALLTRIM(your_username),ALLTRIM(your_password))
IF dbo:NetErr()
   RETURN nil
IF!EMPTY(your_dbname)
   dbo:selectdb(your_dbname)
   IF dbo:NetErr()
      RETURN nil
RETURN dbo
Then do :
if SQL_Connect() // connection OK
msgstop ..
return
and make sure that all your_* vars are filled in correctly
franco
Re: SQL Help
Post by franco »
can you show me how to make this work.
thanks Franco
#include <mysql.ch>
private dbo := ' '
tbls()
SQL_Connect()
WIDTH 600 ;
HEIGHT 610 ;
Main;
on release closeta() ; // {|| 'close all tables', 'delete file inv.dbf' } ;
TITLE 'SQL Test'
DEFINE GRID Grid_1
COL 0
ROW 190
WIDTH 1300
HEIGHT 200
WIDTHS {100,195 }
JUSTIFY {0,0}
ROWSOURCE "inv"
END GRID
form_1.Center
form_1.Activate
function closeta
close inv
delete file inv.dbf
delete file num1.ntx
return nil
function tbls
LOCAL CF
CF := {}
if ! dbcreate("inv", cf)
RELEASE WINDOW ALL
return nil
USE INV NEW
Inv->( DBAPPEND())
LOOP
enddo
use
use inv new
index on num1 to num1
return
*aTable := mySQL(dbo, "select * from inv")
return
*dbo := ' ' // *tmysqlserver():new(ALLTRIM(your_host),ALLTRIM(your_username),ALLTRIM(your_password))
*IF dbo:NetErr()
* RETURN nil
*ENDIF
IF!EMPTY('inv.dbf')
dbo:selectdb('inv.dbf')
IF dbo:NetErr()
RETURN nil
RETURN dbo
All The Best,
Franco
Canada
Re: SQL Help
Hola Franco
Ya anteriormente habia preguntado esto, no te sirvio lo de la vez anterior ?
viewtopic.php?f=5&t=3939&p=36875#p36875
Creo que estas mezclando "naranjas" con "manzanas", estas utilizando MySql o archivos .DBF ?
Hi Franco
Previously had asked this, I not served you for the last time?
I think you're mixing "orange" to "apples", you are using MySql or .DBF files?
