Re: Set function key to a Value
Posted: Thu Jul 28, 2016 1:58 am
Hola Franco
Con Harbour (modo consola) puedes seguir haciendo lo que hacías con Clipper.
Pero si quieres hacerlo con HMG (modo grafico), necesitas "pensar" de modo diferente.
Si quieres seguir con HMG, deberas compilar y probar los múltiples ejemplos que tiene
la carpeta SAMPLES para que vayas entendiendo su manejo.
No se si ya viste este magnifico tutorial de Giovanni Di Maria, te será de mucha utilidad.
Se encuentra en: \HMG\3.4\DOC\data\index.htm
Hello Franco
With Harbour (console mode) you can keep doing what you did with Clipper.
But if you want to do with HMG (graphic mode), you need to "think" differently.
If you want to continue with HMG, you will have to compile and test the many examples that have
the SAMPLES folder for you to go understanding management.
I do not know if you saw this magnificent tutorial "Giovanni Di Maria" will be very useful.
It is located at: \HMG\3.4\DOC\data\index.htm
Hello Franco
