Please help with syntax
robbie73
Re: Please help with syntax
Post by robbie73 »
serge_girard wrote:Robbie,
May I suggest to examine to valueof vfield before using the Alltrim function; vfield is probably empty.
Thank you serge, Yes, examining the data in the field is what i'm trying to do. But I am very beginner. :(
I need to clear EVERYTHING that is not an alpha-numeric character. Oddly, the exact code example I posted will work perfectly well when compiled in clipper/linker in DOS with the same sample data. Compiling in hmg won't work. I'm not saying HMG is the cause. merely that is seems to compile 'differently' or perhaps less forgiving of bad code?
Anyway, i still need a procedure that will examine the field and remove allnon alpha-numeric characters.. thinking about it... it needs to not only trim from both ends, but examine the entire string and remove/replace non alphanumeric characters that can be compiled in hmg unicode.
Do you know of the existence of such a procedure please??
Robbie,
Please why not post your code and your DBF or where you ontienes your information seriously that easier.
I would say that Uses the VALTYPE() functions and function TYPE().
robbie73 wrote:...i still need a procedure that will examine the field and remove allnon alpha-numeric characters.. thinking about it... it needs to not only trim from both ends, but examine the entire string and remove/replace non alphanumeric characters that can be compiled in hmg unicode.
   Remove all non alpha-numeric characters from a string
PROC MAIN
   cOriginal := "=<abc_-.#@123>#+-.,"
   cCleaned  := RemNAN( cOriginal )
   MsgBox( "Original : " + cOriginal + STR( LEN( cOriginal ), 3 ) + CRLF + ;
           "Cleaned  : " + cCleaned  + STR( LEN( cCleaned ), 3 ) )
RETU
FUNC RemNAN( cString )
   LOCAL cRVal  := "",;
         c1Char := ""
   FOR EACH c1Char IN cString
      cRVal += IF( ISALPHA( c1Char ) .OR. ISDIGIT( c1Char ), c1Char, "" )
RETU cRVal
A sample test program that scan any table records for empty fields in any type ,
and reports number of record(s) included empty field(s) with number of FIRST empty field.
PROC MAIN
   SET( _SET_EOF, .F. )
   USE TEST
   nFldCount := FCOU()
   cTestFNam := "empties.txt"
   nEmptyRec := 0
   SET ALTERNATE TO (cTestFNam)
   SET ALTERNATE ON
   WHIL ! EOF()
      FOR nFld := 1 TO nFldCount
	     IF EMPTY( FIELDGET( nFld ) )
            ? RECN(), nFld
			++nEmptyRec
	        EXIT
         ENDI
      SKIP
   ENDD
   SET ALTE OFF
   SET ALTE TO
   MsgBox( LTRIM( STR( RECC() ) ) + " records with " + LTRIM( STR( nFldCount ) ) + " field(s) scanned ;" + CRLF + ;
           LTRIM( STR( nEmptyRec ) ) + " records found with empty field." )
   EXECUTE FILE "NOTEPAD.EXE" PARAMETERS cTestFNam
RETU
Brilliant Esgici !
Thanks Serge :oops:
Brilliant is HMG and supporters :)
Viva HMG :D
Esgici Many thanks, we apply
