HMG 3.4.4
Mario Mansilla
Re: HMG 3.4.4
Post by Mario Mansilla »
Hola Amigos :
sigo investigando y probando .
He instalado el sistema realizado con HMG.3.4.4 (32 bits) con su IDE en win 7 64 bits y win 10 64 bits , y a los 15 minutos o menos de uso continuo ya empieza a manifestar la falla , el sistema se cuelga o se cierra en cualquier lugar del programa . El sistema se vuelve a ejecutar funciona 15 minutos y vuelve a presentar el problema .
Voy a instalar el sistema en win 7 32 bits y les comento el resultado .
Mario Mansilla
Hello friends :
I'm still researching and testing.
I have installed the system made with HMG.3.4.4 (32 bits) with its IDE in win 7 64 bits and win 10 64 bits, and after 15 minutes or less of continuous use it begins to manifest the fault, the system hangs up or It closes anywhere in the program. The system runs again for 15 minutes and returns to present the problem.
I will install the system in win 7 32 bits and I tell you the result.
Mario Mansilla
koke
DBs Used: DBF, mySql, mariaDB
Re: HMG 3.4.4
Post by koke »
Buenas tardes.
Mira este post. A partir de la versión 3.4 iniciaron problemas de memoria se corrigieron un poco en la versión 3.4.3 intenta con esta versión
y platícanos como se siguió comportando.
Saludos.
traductor google.
Good afternoon.
Look at this post As of version 3.4 they started memory problems were corrected a bit in version 3.4.3 try with this version
and talked about how they behaved.
Regards.
viewtopic.php?f=35&t=4381
,___,
[O.o]
/)__)
KoKe
franco
Re: HMG 3.4.4
Post by franco »
Hello all,
I am having this same problem and am glad I found this post, as without I was totally lost.
I have one system that has the same problem. Looses Buttons and shuts down three times a day.
I am waiting to find out what operating sys they have and memory.
I am using hmg 3.44 and 32 bit. compiled in windows 10 64 bit home.
Has anyone have suggestions for me.
Thanks Franco
All The Best,
Franco
Canada
Re: HMG 3.4.4
In hmg 3.4.2 I had problem with resources and growing memory usage by application.
I've added code
RELEASE MEMORY
after main menu commands execution and nobody reports problem with app now
Mario Mansilla
Re: HMG 3.4.4
Hola Mol :
he implementado RELEASE MEMORY en un control TIMER con la funcion que sugirio Claudio , tambien en cada cierre de modulo de la aplicacion principal coloque RELEASE MEMORY en la aplicacion construida con HMG.3.4.4 sin solucion del problema .
Estas usando HMG.3.4.4 en tus aplicaciones ?.
Mario Mansilla
Hello mol :
I have implemented RELEASE MEMORY in a TIMER control with the function that Claudio suggested, also in each module closure of the main application place RELEASE MEMORY in the application built with HMG.3.4.4 without solving the problem.
You are using HMG.3.4.4 in your applications ?.
Mario Mansilla
Re: HMG 3.4.4
Yes, I'm using 3.4.4 and it's very stable in my opinion. From win XP to win'10
Mario Mansilla
Re: HMG 3.4.4
Hola Mol :
cuando usas hmg.3.4.4 , usas para compilar un bat propio o desde el IDE .
Usas modo ANSI o UNICODE ? , compilas 32 bits o 64 bits ? .
Si usas 32 bit , esta aplicacion no presenta problemas en sistemas operativos de 64 bits .
Mario Mansilla
Hello mol :
when you use hmg.3.4.4, you use to compile a bat of your own or from the IDE.
Do you use ANSI or UNICODE mode? Do you compile 32 bits or 64 bits? .
If you use 32 bit, this application does not present problems in 64-bit operating systems.
Mario Mansilla
Re: HMG 3.4.4
Ide, ansi 32 bit.
I don't want to move to 64 bit because a lot of my clients still work under XP
franco
Re: HMG 3.4.4
Post by franco »
Thanks Mol,
I have tried what you suggested. I have tested this. I have public vars at start of main program before main menu. These variables do not
get released or changed on release memory. Is this so. Do you know what release memory releases. I put a memory check before and after release
and memory comes back and my public vars stay the same, so this seems to work. I am a bit nervous of sending out program to my one client with
this problem because they are a very busy business, but I guess it is the only way to test it. What do you think.
Franco
All The Best,
Franco
Canada
Re: HMG 3.4.4
Release memory realizes garbage collection, I think
