Page 2 of 4
Re: Set function key to a Value
Posted: Sat Jul 23, 2016 5:09 pm
by franco
Thanks to all.
I am still having trouble.
I have a field in a table called F2 which holds a value of EG: '123' ( I class this as a macro)
I am using an inputbox to enter a part number to put on an invoice.
I am in Form_1.Grid_1
My program says p:= inputbox('Enter Item')
When I press Ctrl+F2 which is Function 22 (in clipper) I want table->f2 value typed in inputbox for me .
Then I seek 'p' in an other table .
My command in Clipper Program was Set Function 22 to Alltrim(Table->f2)
This was at very start of program so no matter where I was in program when I pushed Ctrl+F2 Table->F2 was enterd for me.
I have 9 of these macros
Table->F3 := Function 23 and so on.
I tried this with a text box in my program but would not work. Entry was blank.
ON KEY F2 OF Form_Grid_In2 ACTION SetProperty( 'FORM_GRID_IN2.Grid_2' , GetProperty( 'Form_Grid_In2.Grid_2' , 'FocusedControl' ) , 'Value' , '123' )
I hope I have explained this clearly.
Thanks again FRanco
Posted: Sat Jul 23, 2016 5:27 pm
by franco
Maybe I could create 9 variables at start of program Main saying
use table
V2 := table->v2, V3:= table->V3 ..... and so on
use
Set Function 22 to V2 .......... I do not know how to code this.
Then later in program when I am in Inputbox if I press Ctrl+f2 V2 would be entered
Franco
Posted: Sat Jul 23, 2016 5:38 pm
by trmpluym
Franco,
Can you post a PRG with a DBF so we can analyse the problem ?
Theo
Posted: Sat Jul 23, 2016 7:28 pm
by franco
Theo, try this.
All works except inputbox. because it is not connected to win1. It is hmg function.
I want to press f1 on inputbox and it enters 123 for me.
Also what would command be for Set key ctrl+f2 to somefunction(var1)
clippers ctrl+f2 = Function 22, but will not work
public Var1 := '123', Var2 := 'ABC'
DEFINE WINDOW Win1 ;
WIDTH 800 ;
HEIGHT 400 ;
TITLE 'Test Input' ;
ON KEY F2 OF WIN1 ACTION Somefunction(Var1)
ON KEY F3 OF WIN1 ACTION Somefunction(Var2)
ON KEY F4 OF WIN1 Action Inputbox('Enter Item')
* ON KEY F22 OF WIN1 ACTION Somefunction(Var1) //will not work
DEFINE TEXTBOX TEXT1
ROW 10
COL 10
WIDTH 150
HEIGHT 20
END TEXTBOX
Win1.Center
ACTIVATE WINDOW Win1
FUNCTION Somefunction
Parameters var
cFocusedControl := GetProperty( 'Win1' , 'FocusedControl' )
IF GetControlType( cFocusedControl , "Win1") == "EDIT" .Or. GetControlType( cFocusedControl ,;
"Win1") == "TEXT"
SetProperty( 'Win1' , cFocusedControl , 'Value' , var )
***** This will not work and is what I need *****
***** Inputbox is not part of Win1
*IF GetControlType == Inputbox
* SetProperty( 'Inputbox' , 'Value' , var )
*ENDIF
Posted: Sat Jul 23, 2016 8:09 pm
Inputbox window name is '_InputBox'
Textbox/editbox inside inputbox is named as '_TextBox'
This you can use in your programme.
For various key combinations that can be used, please see i_keybd.ch in HMG include folder.
Posted: Sun Jul 24, 2016 12:32 am
by andyglezl
Porque no creas tu propio Inputbox() ?
Por ejemplo...
Why not create your own Inputbox() ?
For example...
	public aCpos
*	use table
	aCpos := {"123", "456", "789" }
		WIDTH 800 ;
		HEIGHT 400 ;
		TITLE 'Test Input' MAIN
		ON KEY F2 OF "Win1" ACTION (  MyInputBox( aCpos, "Win1" ) )
			ROW 10
			COL 10
			WIDTH 150
			HEIGHT 20
		END TEXTBOX
	CENTER WINDOW Win1
FUNCTION MyInputBox( aCpos, cForm )
	cFocusedControl := ThisWindow.FocusedControl
	IF GetControlType( cFocusedControl , cForm ) == "TEXT"
		DEFINE WINDOW InpBox AT 0,0 WIDTH 200 HEIGHT 200 TITLE 'My InputBox()' CHILD
			*------------  Other way  ------------------------------------------------------------------------------------------
			*SELE Table
			*@ 020,000 COMBOBOX CB_Options OF &cForm. ITEMSOURCE F1, F2, F3 VALUE 1 WIDTH 50 HEIGHT 25 FONT "Verdana" SIZE 10
			@ 020,010 COMBOBOX CB_Options OF InpBox ITEMS aCpos VALUE 1 WIDTH 150 HEIGHT 70 FONT "Verdana" SIZE 10  ;
					  ON CHANGE ( SetProperty( cForm, cFocusedControl , 'Value', InpBox.CB_Options.DisplayValue ), ThisWindow.Release )
		CENTER WINDOW InpBox
		ACTIVATE WINDOW InpBox
O intenta con el ejemplo:
..\HMG\3.4.3\SAMPLES\Controls\Grid\GRID_10\demo.prg
Posted: Sun Jul 24, 2016 1:10 am
by Roberto Lopez
As Rathi said:
SetProperty( '_InputBox', '_TextBox', 'Value' ,'something...' )
Will do the trick...
Posted: Sun Jul 24, 2016 10:02 am
by mustafa
Hola Andres
Me he tomado la libertad de modificar un poco tu Sample
para que se parezca un poco más a un Inputbox()
Hello Andres
I have taken the liberty to modify a little your Sample
to make it look a bit more to a Inputbox ()
   public aCpos
*   use table
      WIDTH 800 ;
      HEIGHT 400 ;
      TITLE 'Test Input  ->  KEY [F2]' MAIN
         ROW 10
         COL 10
         WIDTH 150
         HEIGHT 20
      END TEXTBOX
   CENTER WINDOW Win1
      DEFINE WINDOW InpBox AT 0,0 WIDTH 300 HEIGHT 150 TITLE 'My InputBox()'  NOSYSMENU NOMAXIMIZE NOMINIMIZE CHILD
         *SELE Table
         @ 020,030 COMBOBOX CB_Options OF InpBox ITEMS aCpos VALUE 1 WIDTH 150 HEIGHT 70 FONT "Verdana" SIZE 10  //;
**                 ON CHANGE ( SetProperty( cForm, cFocusedControl , 'Value', InpBox.CB_Options.DisplayValue ), ThisWindow.Release )
      *------------------------------  Botones --------------------------------------------------------------------*
            @ 69,068 BUTTON CercaX               ;
                     CAPTION 'Accept'             ;
                     TOOLTIP 'Search by Date'     ;
                     ACTION ( SetProperty( cForm, cFocusedControl , 'Value', InpBox.CB_Options.DisplayValue ), ThisWindow.Release )
            @ 69,172 BUTTON SalidaX               ;
                     CAPTION 'Cancel'             ;
                     TOOLTIP 'Cancel ...'         ;
                     ACTION InpBox.Release
Posted: Sun Jul 24, 2016 4:39 pm
by andyglezl
Perfecto Mustafa
Es la idea de que estemos en el Foro: compartir, participar, aportar, adaptar, mejorar y volver a compartir.
(y porque no, en su caso, alguna critica constructiva).
Cada duda y respuesta, da pie a nuevas ideas que podemos adaptar a nuestras necesidades y aprender uno del otro.
Perfect Mustafa
It is the idea that we are in Forum: share, participate, contribute, adapt, improve and share back.
(And why not, if necessary, any constructive criticism).
Each question and answer, gives rise to new ideas that can adapt to our needs and learn from each other.
Posted: Sun Jul 24, 2016 10:48 pm
by franco
I want to thank all for your responses. I have learned so much from this problem.
I like the idea of creating my own inputbox and putting it in my procedure file.
This way I can change function key for different windows .
I am still working on Rathinagiri and Roberto's response but have not quite figured it out yet.
Thanks again ......... Franco
