Please help with syntax
robbie73
Re: Please help with syntax
Post by robbie73 »
I have just checked with a different set of data and the program seems to run ok up to a point... That is if one of the tables listed in the supporting .dbf does not exist (How can I check that db exists and exit gracefully if it doesn't? Or trap the error and skip overe it?)
OR if there is some other kind of problem with the data? I also attached .D file that causes the problem with the ALLTRIM Error.
robbie73
Post by robbie73 »
Thnak you esgici and Pablo very much for your advice and help :D
robbie73 wrote: I have just checked with a different set of data and the program seems to run ok up to a point... That is if one of the tables listed in the supporting .dbf does not exist (How can I check that db exists and exit gracefully if it doesn't? Or trap the error and skip overe it?)
Hi Robby
This check program :
PROC MAIN
  USE LBORROW
  MsgDebug( "SurName : ", LEN( ALLTRIM( SURNAME ) ),;
							      EMPTY( SURNAME ) ,;
            "GivenName : ", LEN( ALLTRIM( GIVENNAME ) ),;
                                    EMPTY( GIVENNAME ) )
RETU
said :
This means no problem in your data.
My environment is : HMG 3.4.0, 32 Bit; IDE: Unicode.
May be you are using IDE-ANSII ?
Please check and if inform me if problem persist.
robbie73
Post by robbie73 »
Thank you Escigi :) MY IDE shows unicode? I think? where to check?
changelog says:
-HMG 3.4.0 2015/01/18
- Updated to latest Harbour Nightly Build (2015-01-14)
- Updated to latest MingW Compiler
- New HMG IDE version 1.0.8
hmg forum Unicode.PNG (14.02 KiB) Viewed 5420 times
robbie73
Post by robbie73 »
ahh.. i think i might have found the problem. The .prg uses other .dbf files as a lookup. For the person first and surname it looks like this in the lookup table:
ColumnA(DB), ColumnB(Field), ColumnC(Size)
PERSON_DATABASE.DBF BARCODE 1 <-- this is good and the rest of the reference table looks like this.
PERSON_DATABASE.DBF SURNAME+GIVENNAME 1 <-- Is where the problem is i think
Surname and given name are two separate fields in the data, that have been joined in the reference table with the + symbol. This is because duplicate checking requires this. otherwise it would delete all the people with the same first name or surname.
Advice how to handle this please? or maybe remove from the duplicate check on NAME?
UPDATE:
No. i used a different reference table and avoided the SURNAME + GIVEN NAME and it made no difference. same error.
Robbie,
May I suggest to examine to valueof vfield before using the Alltrim function; vfield is probably empty.
Hi Robby
Please try this ( two lines added and marked with "<--" ) :
procedure blanks()
   select 1; use blank.dbf
   message(3,opy,mess,"Blank and Invalid Codes")
  do while !eof()
      vfile=file; vfield=field; vsize=size
      message(4,filey,mess,"Deleting "+(vfile))
      select 2; use &vfile; setbar()
      hold=4
     do while !eof()
         progress(recno(),lastrec())
		 IF VALTYPE( &vfield ) = "C"   // <--
            if len(alltrim(&vfield))<vsize
               //if len(alltrim(&vfield)) <-- how to use alternative to ALL TRIM?
               errortofile("Blank/Invalid",vfile,recno())
               if upper(delrep)="D"
                  delete
		 ENDIF                        // <--
         skip
      enddo
      select 1
      skip
   enddo
   close 1; close 2
serge_girard wrote:May I suggest to examine to valueof vfield before using the Alltrim function; vfield is probably empty.
esgici wrote:IF VALTYPE( &vfield ) = "C"
Pablo César wrote:I believe this error, it is because there is nothing to make alltrim. Probably data type it is not data character type (Nil type, an array, date type or numeric type). Then it's not gonna works.
You can previously test it with Alert( ValType(cVar) ).
Always be carful with error messages. It's saying: BASE/2022 Argument error: ALLTRIM
So, please read this :idea:
As I said before... 8-)
robbie73
Post by robbie73 »
Thank you All. I am going to work my way through your suggestions..
Bear in mind I am new to clipper! so it might take some time.
Thank you all again. :) I will post back when i have solved it.
robbie73 wrote:I am going to work my way through your suggestions..
Hi Robbie
Please don't worry about being new; all of us was new at beginning ;)
I'm sure that you will like Clipper programming and Harbour + HMG : Clipper for Windows :arrow:
More, here you are between friends; please don't hesitate to ask anything; hopefully you will find always helpers.
I hope that this short sample will be useful for you.
