Simple Error Handling - 2
Re: Simple Error Handling - 2
Nice work!
In my project, I've added sending e-mail message with error info.
hb_SendMail( cServer, nPort, cFrom, xTo, xCC, xBCC, cBody, cSubject, aFiles, cUser, cPass, cPopServer,;
nPriority, lRead, bTrace, lPopAuth, lNoAuth, nTimeOut, cReplyTo, lTLS, cSMTPPass, cCharset, cEncoding )
when parameters are:
cServer -> Required. IP or domain name of the mail server
nPort -> Optional. Port used my email server
cFrom -> Required. Email address of the sender
xTo -> Required. Character string or array of email addresses to send the email to
xCC -> Optional. Character string or array of email adresses for CC (Carbon Copy)
xBCC -> Optional. Character string or array of email adresses for BCC (Blind Carbon Copy)
cBody -> Optional. The body message of the email as text, or the filename of the HTML message to send.
cSubject -> Optional. Subject of the sending email
aFiles -> Optional. Array of attachments to the email to send
cUser -> Required. User name for the POP3 server
cPass -> Required. Password for cUser
cPopServer -> Required. POP3 server name or address
nPriority -> Optional. Email priority: 1=High, 3=Normal (Standard), 5=Low
lRead -> Optional. If set to .T., a confirmation request is send. Standard setting is .F.
bTrace -> Optional. If set to .T., a log file is created (smtp-<nNr>.log). Standard setting is NIL.
If a block is passed, it will be called for each log event with the message a string, no param on session close.
lPopAuth -> Optional. Do POP3 authentication before sending mail.
lNoAuth -> Optional. Disable Autentication methods
nTimeOut -> Optional. Number os ms to wait default 20000 (20s)
cReplyTo -> Optional.
mol wrote: In my project, I've added sending e-mail message with error info.
Thanks Mol :)
Dilip Patel
Post by Dilip Patel »
Hi Esgici,
It would be nice if MOL's sendmail routine is added to the errorsys program.
Dilip
Hi Dilip
Dilip Patel wrote: It would be nice if MOL's sendmail routine is added to the errorsys program.
You are right.
Sadly I haven't any experience about send-mail.
Since "Simple Error Handling - 2" is fully open, anyone experienced on send-mail, may add send-mail feature to it.
Otherwise if anyone will send a simple and working example for send-mail, we can work to try.
Hi All
This is the second version of Simple Error Handling - 2.
Something changed ( details in description.txt file ).
SEH2.zip
Simple Error Handling - 2.2 Source files
(60.91 KiB) Downloaded 570 times
Simple Error Handling - 2.2 Screenshoot
Thanks a lot Esgici. :)
Wow :!: , very nice and very useful.
Claudio
Gracias por compartir Esgici ...
Thanks for sharing Esgici ...
Great job Esgici, and Mol good idea.
Post by EduardoLuis »
Master Esgici: Woh, Woh, Woh, what a usefull tool
Congratulations, and thanks for share with us.
With regards.
