HB_WebView (a cross-platform Webview library)
Re: HB_WebView (a cross-platform Webview library)
Serge,
On Windows, the cross-platform C/C++ base library (Webview) invokes Windows' Webview2. You'll need to look in the Webview2 documentation to see if the option you need is available. HB_webview is simply a wrapper around the base library's and Harbour, meaning it merely acts as a bridge between Harbour and the base C/C++ library.
https://learn.microsoft.com/microsoft-e ... orm=MA13LH
Thanks, I' will take a look!
I have added to the first post where the source files are located, a .pdf file with the documentation of HB_WebView:
https://www.hmgforum.com/viewtopic.php?t=7659
Thanks!
jorge_riv
DBs Used: DBF, MySQL,SQL SERVER, Oracle.
Post by jorge_riv »
Hola, en Harbour MiniGUI Extended Edition 24.12 (Standard), se puede compilar?? en la version de hmg 3.6 anda perfecto, como seria en minigui para compilar?
Hola Jorge,
No he probado en MG Ex, pero el código fuente ya se lo pasé a Grigory, así que seguramente pronto estará disponible en MG Ex.
Hi all,
I have added to the first post where the source files are located, a new demo4.prg and the pdf file documentation.
I've added new comments inside the demos for better code understanding.
The added demo4.prg is very interesting; it allows you to inject PRG code written entirely in Harbour from JavaScript.
Thank you, very amazing!
Do you think it would be possible to have MySQL integrated?
Hi Serge,
Yes, of course. I don't have much experience with MySQL. Please upload a small demo complete with all the necessary libraries, and I'll try to adapt it to HB_Webwiew.
Claudio,
Here is a small example (not tested or compiled !) but it gives an idea!
Many thanks, Serge
FUNCTION MAIN()
PUBLIC dbo
PUBLIC dbname
PUBLIC host
PUBLIC user
PUBLIC password
PUBLIC cVersion
PUBLIC aRESULT := {}
IF SQL_Connect()
   cQuery1a  := " SELECT SOME_FIELD "
   cQuery1a  += " FROM   SOME_TABLE "
   cQuery1a  += " WHERE  SOME_REC_NO  = 1  "
   cSQL1    := cQuery1a
   ? cSQL1
   cQuery1a	:= dbo:Query( cQuery1a )
   IF cQuery1a:NetErr()
      MSGINFO( 'SQL DEMO ' + UPPER(cQuery1a:Error()))
   FOR i := 1 to cQuery1a:Lastrec()
      aCurRowa			   := cQuery1a:GetRow(i)
      cNAAM             := Strvalue(aCurRow:fieldGet(1))
      AADD(aRESULT, {cNAAM } )
   SQL_Disconnect()
   ? 'NO CONNECTION'
	WIDTH  1200  ;
	HEIGHT 500 ;
	TITLE '';
	MAIN  ;
   FONT 'Arial' SIZE 15   ;
   @ 10,10 GRID Grid_ZF		;
      WIDTH  1150			;
      HEIGHT 450		;
      HEADERS {'SOME_FIELD'};
      WIDTHS  {250    };
      JUSTIFY { GRID_JTFY_LEFT  } ;
      FONT "Arial" SIZE 09		;
      iTEMS aRESULT
CENTER WINDOW Form_1
FUNCTION SQL_Connect()
dbname      := 'dbname'
host			:= 'host.db.host.xx'
user			:= 'dbname_user'
password		:= 'secret_password'
dbo := tmysqlserver():new(AllTrim(host), AllTrim(user), AllTrim(password))
IF dbo:NetErr()
   ?'R1',  dbo:ERROR()
   RETURN nil
IF!EMPTY(dbname)
   dbo:selectdb(dbname)
   IF dbo:NetErr()
     ?'R2',  dbo:ERROR()
      RETURN nil
cVersion := dbo:sql_Version()
? 'cVersion', cVersion
RETURN dbo
FUNCTION SQL_Disconnect()
dbo:Destroy()
