Download file from WWW
RPC
Re: Download file from WWW
Post by RPC »
Hi mlnr
Thanks for the code. It works !!!
I can download from the net now :D
I have another problem. I want to download some information from the web page.
It means I have to "read" the page from the program and download that information.
Is it possible :?:
Thanks once again for your help.
hmgaams57
Post by hmgaams57 »
Hi mlnr
The program works fine but it would be even better
if there is way to add a progress bar and the ability
to resume downloads without starting from the beginning
after interruption.
mlnr
Post by mlnr »
hmgaams57 wrote: Wed Mar 08, 2017 3:47 pm Hi mlnr
after interruption.
Hi hmgaams57
You can get the file size
oSoap:getResponseHeader("Content-Length")
and try to watch the download state. Some info here
https://msdn.microsoft.com/en-us/librar ... s.85).aspx
RPC wrote: Wed Mar 08, 2017 3:15 pm Hi mlnr
Is it possible :?:
Hi RPC,
Sorry, i cannot help you. Maybe someone has an information.
RPC
Post by RPC »
Hi mlnr
Its OK if you cant help in "reading" webpage
At least now I can download links.
Thank you
edk
Post by edk »
Hi RPC.
Try this: C:\hmg.3.4.3\HARBOUR\contrib\hbtip\tests\loadhtml.prg
But, if you need to read pages from https, you must include SSL suport
#require "hbssl"
REQUEST __HBEXTERN__HBSSL__
IF !tip_SSL()
	MsgStop("Required SSL")
oHttp := TIPClientHTTP():new( "https://www.google.com/search", .F. )
You need also in hbc:
libs=hbssl
libs=libeay32
libs=ssleay32
Libs=hbtip
Include in hbp:
hbssl.hbc
And most important: DLLs
ssl_dll.7z
(566.58 KiB) Downloaded 445 times
Edward.
Thx Edward!
Is there a specific folder for the DLL needed or just where the EXE is located?
edk
Post by edk »
Just where EXE is located.
Edward.
RPC
Post by RPC »
edk wrote: Fri Mar 10, 2017 10:29 am Hi RPC.
#require "hbssl"
IF !tip_SSL()
libs=hbssl
libs=libeay32
libs=ssleay32
Libs=hbtip
Include in hbp:
hbssl.hbc
ssl_dll.7z
Edward.
Hi Edwards
Many thanks for the code and description.
I tried to compile, thro IDE, loadhtml.prg but got error BASE/1004 No Exported method: AS
Unfortunately I am quite dumb in understanding all this.
I have to download data from following site
https://www.nseindia.com/products/conte ... x_data.htm
Time period is 10 march 2017 to 10 march 2017 and click Get Data button. Then you will get follo info
Date : 10-Mar-2017 | Open : 8953.70 | High : 8975.70 | Low : 8903.95 | Close : 8934.55 | Shares Traded : 157419999 | Turnover(Rs Cr) : 7385.28
There is also a hyperlink - Download file in CSV format - towards right side corner of the information downloaded. Clicking on this downloads the above information in a CSV file.
It is this information which I want to download. I notice it is a https page. Could you please send a program to download the info in a CSV/text file. I would be very grateful.
Thanks
RPC
Hi!
Sorry for delay, but last week I was absent without internet.
I have no limitations in type of downloaded file, but this solution has a problem with some proxy servers.
Put a description of error which you geet.
Hi Gabor! Your solution with SOAP is very interesting. Can you add to your code lines, which changes http AGENT to Mozilla or IE?
RPC
Post by RPC »
mol wrote: Sun Mar 12, 2017 6:06 am Hi!
Hi mol
Its ok if you couldn't answer earlier. You have been very helpful and I appreciate that.
Following is the screen shot of the error
Error - Download - mol.png (32.64 KiB) Viewed 8190 times
I put following url in window
https://www.nseindia.com/content/histor ... av.csv.zip
and save to was a.zip filename, when I click the download button I got above error message.
Thanks
