HMG SMS
HMG SMS
One of my clients had asked for SMS sending feature in HMG software.
I have connected GSM modem using COM port connection and created a SMS utility in HMG. I used the concept from hbcomm and hbsms contrib.
Hope this will be useful for others too.
sms.zip
(4.84 KiB) Downloaded 747 times
apais
Re: HMG SMS
Post by apais »
Cool !!!
Angel Pais
Re: HMG SMS
thanks !
Re: HMG SMS
Muy buen trabajo Rathi.
good job Rathi.
Re: HMG SMS
Thank you Rathi for sharing
Re: HMG SMS
Hi Rathi,
We can use API to send SMS from internet ?
Re: HMG SMS
You mean free sms services given by internet companies? Yes. we can.
Re: HMG SMS
rathinagiri wrote:You mean free sms services given by internet companies? Yes. we can.
Not free but SMS purchased from service provider
Interest to know how to use send SMS using API
Re: HMG SMS
Hola BDP: aqui la empresa Movistar proporciona una API muy sencilla que nos permite enviar mensajes de texto vía HTTP. El requisito es que el servicio debe de utilizar un número móvil de Movistar.
Para poder utilizar esta API, primero hay que darse de alta en el servicio y para ello hay que mandar un mensaje al número 22770 con el texto CLAVE. Al instante recibirás otro mensaje con un password para que puedas empezar a utilizar el API.
Los mensajes que se envíen, serán cobrados al número que se ha utilizado en la configuración del API con el precio normal de la tarifa contratada.
Translate Google :
Hello BDP: here the company Movistar provides a simple API that allows us to send text messages via HTTP. The requirement is that the service must use a Movistar mobile number.
To use this API, you must first register with the service and for this we must send a message to the number 22770 with the key text. Instantly receive another message with a password so you can start using the API.
The messages sent will be charged to the number that was used in the API configuration with the normal price of the contracted rate.
Info : http://open.movilforum.com/en/home/A
Info : https://github.com/Krun/snappy-sms-movistar
Info : http://omf.morfeo-project.org/wiki/inde ... vio_de_SMS
bels79
DBs Used: DBF, MySQL
Re: HMG SMS
Post by bels79 »
if using usb gsm, how to change its port com ?
tq
