AES File Encryption Library & Sample
I am glad to attach a library for AES File Encryption along with a demo to encrypt/decrypt a file using password. This library is based on PolarSSL
Extract the contents in your HMG 3.0.40 directory. A directory in the name of 'aes' will be created which contains the source and sample subdirectories.
You can call the following function for crypt/decrypting a file:
CryptFileAES( cFileIn, cFileOut, cPassword, nMode )
nMode = 0 (For Encryption)
nMode = 1 (For Decryption)
cPassword can be either a character string or a key filename also!
Please give your comments.
aes.zip
(53.51 KiB) Downloaded 741 times
Re: AES File Encryption Library & Sample
Hi Rathi
Perfect :!: ( as always ) 8-)
Thanks a lot :)
fchirico
Post by fchirico »
Thanks rathinagiri!
very interesting.
Saludos, Fernando Chirico.
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
;) Thanks a lot rathi, it is perfect
[]´s Salamandra
