AutoFill in Text Box
Has thanked: 411 times
Been thanked: 120 times
Re: AutoFill in Text Box
Hi
Thanks my friends Rathi and Sudip :D ; but sorry, IMO neither working perfect nor everything is fine :(
Because from user perspective there are some confusing situations: under some conditions back space and delete keys seems not working :(
Anyway here is new version localized UP and DOWN arrow keys by using Rathi's method.
  AutoFill in Text Box try
  Started by Esgici
  Enhanced by Roberto Lopez and Rathinagiri
  2009.05.10
#include "minigui.ch"
PROC Main()
   aCountries := HB_ATOKENS( MEMOREAD( "Countries.lst" ),   CRLF )
   ASORT( aCountries )                    // This Array MUST be sorted
   DEFINE WINDOW frmAFTest ;
      WIDTH  550 ;
      HEIGHT 300 ;
      TITLE 'AutoFill in Text Box try (BE2)' ;
      MAIN
      ON KEY ESCAPE ACTION frmAFTest.Release
      DEFINE LABEL lblCountry
         ROW        50
         COL        50
         VALUE      "Country :"
         RIGHTALIGN .T.
         AUTOSIZE   .T.
      END LABEL // lblCountry
      DEFINE TEXTBOX txbCountry
         ROW         48
         COL         110
         ONCHANGE    AutoFill( ThisWindow.Name, This.Name, aCountries )
         ONGOTFOCUS  AFKeySet( ThisWindow.Name, This.Name, aCountries )
         ONLOSTFOCUS AFKeyRls( ThisWindow.Name )
      END TEXTBOX // txbCountry
   END WINDOW // frmAFTest
   frmAFTest.Center
   frmAFTest.Activate
RETU // Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
PROC AutoFill( ;              // Auto filling text box
                cFrmName  ,;  // Form / Windows name
                cTxBName  ,;  // Text Box Name
                aList,;       // Items list
                nCaller )     // NIL : OnChange, 1: UP, 2: Down
   STATIC cLastVal := '',;
          n1Result := 0
   LOCAL  cTxBValue := GetProperty( cFrmName, cTxBName, "Value" ),;     // Text Box Value
          nCarePos  := GetProperty( cFrmName, cTxBName, "CaretPos" ),;  // Text Box CaretPos
          cCurval   := ''
   IF HB_ISNIL( nCaller )
      IF !( cLastVal == cTxBValue )
         cCurval  := LEFT( cTxBValue, nCarePos )
         IF !EMPTY( cCurval )
            n1Result := ASCAN( aList, { | c1 | UPPER( LEFT( c1, LEN( cCurval ) ) ) == UPPER( cCurval )} )
            IF n1Result > 0
               cCurval := aList[ n1Result ]
            ENDIF n1Result > 0
         ENDIF !EMPTY( cCurval )
         cLastVal := cCurval
         AF_Apply( cFrmName, cTxBName, cCurval, nCarePos )
      ENDIF cLastVal # cCurval
      IF n1Result > 0
         IF nCaller < 2
            n1Result -= IF( n1Result > 1, 1, 0 )
            n1Result += IF( n1Result < LEN( aList ), 1, 0 )
         cLastVal := cCurval
      ENDIF n1Result > 0
   ENDIF HB_ISNIL( nCaller )
RETU // AutoFill()
PROC AF_Apply( ;
               cFrmName,;
               cTxBName,;
               cValue,;
               nPosit )
   SetProperty( cFrmName, cTxBName, "Value", cValue )
   SetProperty( cFrmName, cTxBName, "CaretPos", nPosit )
RETU // AF_Apply()
PROC AFKeySet(;
               cFrmName ,;
               cTxBName ,;
               aitems )
   ON KEY UP   OF &cFrmName  ACTION AutoFill( cFrmName, cTxBName, aitems, 1 )
   ON KEY DOWN OF &cFrmName  ACTION AutoFill( cFrmName, cTxBName, aitems, 2 )
RETU // AFKeySet()
PROC AFKeyRls( ;
               cFrmName )
   RELEASE KEY UP   OF &cFrmName
   RELEASE KEY DOWN OF &cFrmName
RETU // AFKeyRls()
One comforting point is : it's usable for indulgent users :)
Has thanked: 251 times
Been thanked: 302 times
Now, it is working fine, I think.
IMHO, we can remove the parameters windowname and controlname as suggested by Roberto.
rathinagiri wrote:Now, it is working fine, I think.
Hi Rathi
Unfortunately I couldn't understand Roberto's codes :(
Please could you apply ?
Yep. Here it is.
      Started by Esgici
      2009.05.10
    PROC Main()
          WIDTH  550 ;
          HEIGHT 300 ;
          MAIN
             ROW        50
             COL        50
             VALUE      "Country :"
             RIGHTALIGN .T.
             AUTOSIZE   .T.
             ROW         48
             COL         110
             ONCHANGE    AutoFill( aCountries )
             ONGOTFOCUS  AFKeySet( aCountries )
             ONLOSTFOCUS AFKeyRls(  )
       frmAFTest.Center
       frmAFTest.Activate
    RETU // Main()
              n1Result := 0
       LOCAL  cFrmName := thiswindow.name,;
              cTxBname := this.name,;
              cCurval   := ''
                IF n1Result > 0
                ENDIF n1Result > 0
             cLastVal := cCurval
             AF_Apply( cCurval, nCarePos )
          IF n1Result > 0
             IF nCaller < 2
             cLastVal := cCurval
          ENDIF n1Result > 0
    RETU // AutoFill()
    PROC AF_Apply( ;
                   cValue,;
                   nPosit )
       Local cFrmName := thiswindow.name,;
             cTxBName := this.name
    RETU // AF_Apply()
    PROC AFKeySet(;
                   aitems )
    RETU // AFKeySet()
    PROC AFKeyRls( )
    RETU // AFKeyRls()
rathinagiri wrote:Yep. Here it is.
Without using _HMG_SYSDATA ?
Sorry, but :
Error: Harbour MiniGUI 2.9.0 (2009.05.03)
Control: Of frmAFTest Not defined. Program Terminated
Called from GETPROPERTY(6793)
Called from AUTOFILL(70)
Called from (b)AFKEYSET(138)
Called from _DOCONTROLEVENTPROCEDURE(4680)
Called from EVENTS(553)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4322)
Called from DOMETHOD(7224)
Called from MAIN(52)
Sorry for the bug.
Please try now.
          Started by Esgici
          2009.05.10
*/        #include "minigui.ch"
        PROC Main()
              WIDTH  550 ;
              HEIGHT 300 ;
              MAIN
                 ROW        50
                 COL        50
                 VALUE      "Country :"
                 RIGHTALIGN .T.
                 AUTOSIZE   .T.
                 ROW         48
                 COL         110
           frmAFTest.Center
           frmAFTest.Activate
        RETU // Main()
                        nCaller,;     // NIL : OnChange, 1: UP, 2: Down
                        cControlName )
                  n1Result := 0
           LOCAL  cFrmName := '',;
                  cTxBname := '',;
                  cTxBValue := '',;     // Text Box Value
                  nCarePos  := 0,;  // Text Box CaretPos
                  cCurval   := ''
           if pcount() == 3
              cTxBName := cControlName
           cTxBValue := GetProperty( cFrmName, cTxBName, "Value" )     // Text Box Value
           nCarePos  := GetProperty( cFrmName, cTxBName, "CaretPos" )  // Text Box CaretPos
                    IF n1Result > 0
                    ENDIF n1Result > 0
                 cLastVal := cCurval
                 AF_Apply( cFrmName,cTxBName,cCurval, nCarePos )
              IF n1Result > 0
                 IF nCaller < 2
                 cLastVal := cCurval
              ENDIF n1Result > 0
        RETU // AutoFill()
        PROC AF_Apply( ;
                       cFrmName,;
                       cTxBName,;
                       cValue,;
                       nPosit )
        RETU // AF_Apply()
        PROC AFKeySet(;
                       aitems )
           ON KEY UP   OF &cFrmName  ACTION AutoFill(  aitems, 1,cTxBName )
           ON KEY DOWN OF &cFrmName  ACTION AutoFill(  aitems, 2,cTxBName )
        RETU // AFKeySet()
        PROC AFKeyRls( )
        RETU // AFKeyRls()
That's all :D
Thanks a lot :)
Vanguarda
Been thanked: 1 time
Post by Vanguarda »
Hi Esgici,
thanks for sharing this function... it is very amazing. will help me a lot
I also thank all the brother for help in advancing this function.
Thanks a lot,
I´m glad for participe this community.
Hola Vanguarda
Vanguarda wrote: thanks for sharing this function... it is very amazing. will help me a lot
No thank required, everything is for community,
Viva HMG, viva Roberto :!: :D
