AutoFill in Text Box
Has thanked: 251 times
Been thanked: 302 times
Re: AutoFill in Text Box
When pressing back space, it selects left character in stead of deleting it.
Yes. In your previous code, what was the behavior? Left character gets deleted and nothing is selected in the right?
Has thanked: 411 times
Been thanked: 120 times
Hi All
In appearance this isn't easy task as far as seen at first sight.
Please look and test this version.
  AutoFill in Text Box try
  Started by Esgici
  Enhanced by Roberto Lopez and Rathinagiri
  2009.05.09
#include "minigui.ch"
PROC Main()
   aCountries := HB_ATOKENS( MEMOREAD( "Countries.lst" ),   CRLF )
   ASORT( aCountries )                    // This Array MUST be sorted
   DEFINE WINDOW frmAFTest ;
      WIDTH 550 ;
      HEIGHT 300 ;
      TITLE 'AutoFill in Text Box try' ;
      MAIN
      ON KEY UP     ACTION AutoFill( ThisWindow.Name, "txbCountry",  aCountries, 1 )
      ON KEY DOWN   ACTION AutoFill( ThisWindow.Name, "txbCountry",  aCountries, 2 )
      ON KEY ESCAPE ACTION frmAFTest.Release
      DEFINE LABEL lblCountry
         ROW        50
         COL        50
         VALUE      "Country :"
         RIGHTALIGN .T.
         AUTOSIZE   .T.
      END LABEL // lblCountry
      DEFINE TEXTBOX txbCountry
         ROW      48
         COL      110
         ONCHANGE AutoFill( ThisWindow.Name, This.Name, aCountries )
      END TEXTBOX // txbCountry
   END WINDOW // frmAFTest
   frmAFTest.Center
   frmAFTest.Activate
RETU // Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
PROC AutoFill( ;              // Auto filling text box
                cFrmName  ,;  // Form / Windows name
                cTxBName  ,;  // Text Box Name
                aList,;       // Items list
                nCaller )     // NIL : OnChange, 1: UP, 2: Down
   STATIC cLastVal := '',;
          n1Result := 0
   LOCAL  cTxBValue := GetProperty( cFrmName, cTxBName, "Value" ),;     // Text Box Value
          nCarePos  := GetProperty( cFrmName, cTxBName, "CaretPos" ),;  // Text Box CaretPos
          cCurval   := ''
   IF HB_ISNIL( nCaller )
      IF !( cLastVal == cTxBValue )
         cCurval  := LEFT( cTxBValue, nCarePos )
         IF !EMPTY( cCurval )
            n1Result := ASCAN( aList, { | c1 | UPPER( LEFT( c1, LEN( cCurval ) ) ) == UPPER( cCurval )} )
            IF n1Result > 0
               cCurval := aList[ n1Result ]
            ENDIF n1Result > 0
         ENDIF !EMPTY( cCurval )
         cLastVal := cCurval
         AF_Apply( cFrmName, cTxBName, cCurval, nCarePos )
      ENDIF cLastVal # cCurval
      IF n1Result > 0
         IF nCaller < 2
            n1Result -= IF( n1Result > 1, 1, 0 )
            n1Result += IF( n1Result < LEN( aList ), 1, 0 )
         cLastVal := cCurval
      ENDIF n1Result > 0
   ENDIF HB_ISNIL( nCaller )
RETU // AutoFill()
PROC AF_Apply( cFrmName, cTxBName, cValue, nPosit )
   SetProperty( cFrmName, cTxBName, "Value", cValue )
   SetProperty( cFrmName, cTxBName, "CaretPos", nPosit )
   * I don't like this low-level trick ! :(
   SendMessage( GetControlHandle( cTxBname, cFrmName), 177, LEN( cValue ), nPosit )
RETU // AF_Apply()
I'm waiting your comments.
PS: Please attention: Sometimes seems nothing changed by seeing text box value not changed. This occurs especially after pressing backspace or delete keys. This is because the result off filling process become identical with previous one.
Hi Esgici,
Had u tested my last version here?
IMHO, we can't have a generic UP/DOWN key definitions because, if you define another listbox in this window, you can't scroll that listbox with the UP/DOWN key.
Hi Rathi
Yes, tested.
IMHO at this stage adequate working of auto filling process is more important than scope of up-down keys. For localizing instead of global on-key definition will be easy by your method, I thought.
Thanks and regards.
As you had rightly said, working of the process is more important.
Had you gone through the back space handling too?
rathinagiri wrote: Had you gone through the back space handling too?
Didn't you tried ?
Any problem ?
Hi
IMHO that love-level trick
SendMessage( GetControlHandle(  ...
is causing some serious problems.
Please extract ( or simply comment ) it in my last code.
It's very last line :
Yes. Now it is working perfect. Thanks a lot Esgici.
Has thanked: 5 times
Been thanked: 5 times
Hi Rathi and Esgici,
Thank you very much. Now, everything is fine :) I tested it :D
Yesterday I was busy with formatting my laptop. It's registry was corrupted. And at that time I couldn't understand low level functions. Still now I am very novice in HMG. ;)
Rathi, sorry my friend. I was wrong regarding user interface. I have to learn many things from you :D
Yes, my friend, it was not currect :)
Regards.
