Message Extended
Has thanked: 411 times
Been thanked: 120 times
Message Extended
Hi to all
MsgExtended is Freevare HMG Message function.
Test program (MsgExtTest.prg) also demonstrate using
some handy HMG functions and commands.
All bug reports and suggestions are welcome.
Developed under Harbour Compiler and
MINIGUI - Harbour Win32 GUI library (HMG);
compiled and linked by MinGW.
Thanks to "Le Roy" Roberto Lopez.
All modules in the MsgExtended.prg and MExTest.prg
copyrighted : 2008 Bicahi Esgici <esgici@gmail.com>
  MINIGUI - Harbour Win32 GUI library Demo/Sample
  Copyright 2002-08 Roberto Lopez <harbourminigui@gmail.com>
  MsgExtTest.prg is a Freevare test program for MsgExtended() function.
  Also demonstrate using some handy HMG functions and commands.
  History :
     2008.08 : First Release
#include <minigui.ch>
#define NTrim( n ) ( LTRIM( STR( n ) ) )
#translate ISNIL(  <xVal> ) => ( <xVal> == NIL )
#translate ISARRY( <xVal> ) => ( VALTYPE( <xVal> ) == "A" )
#translate ISCHAR( <xVal> ) => ( VALTYPE( <xVal> ) == "C" )
#translate ISNUMB( <xVal> ) => ( VALTYPE( <xVal> ) == "N" )
SET PROC TO "MsgExtended.prg"
PROC Main()                               // Multiple message boxs for testing by sample
   LOCA nParam   :=  0,;
        c1Label  := "",;
        c1LblNam := "",;
        c1txbNam := ""
   SET DATE TO GERM
   SET CENT ON
   PRIV aParNames, aMsgSamples, aSamples
   MakSamples()
   DEFINE WINDOW frmMOptsTest ;
      AT     0,0 ;
      WIDTH  400 ;
      HEIGHT 450 ;
      MAIN       ;
      TITLE  "Tests for f.MsgExtended()"  ;
      ON INIT SetSmpVals( frmMOptsTest.cbxSamples.value )
      ON KEY ESCAPE ACTION frmMOptsTest.Release
      DEFINE COMBOBOX cbxSamples
         ROW 50
         COL 50
         WIDTH   200
         HEIGHT  180
         VALUE   5
         ON CHANGE SetSmpVals( this.value )
         ITEMS  aSamples
      END COMBOBOX // cbxSamples
      DEFINE FRAME fraSamples
          ROW 30
          COL 40
          CAPTION "  Samples "
          WIDTH 220
          HEIGHT 50
      END FRAME // fraSamples
      FOR nParam  := 1 TO LEN( aParNames )
         c1Label  := aParNames[ nParam ]
         c1LblNam := "lbl" + PADL( nParam, 2, "0" )
         DEFINE LABEL &c1LblNam
            ROW        103 + ( nParam - 1 ) * 30
            COL        45
            WIDTH      100
            VALUE      c1Label
            RIGHTALIGN .T.
         END LABEL // &c1LblNam
         c1txbNam := "txb" + PADL( nParam, 2, "0" )
         DEFINE TEXTBOX &c1txbNam
            ROW     100 + ( nParam - 1 ) * 30
            COL     150
            WIDTH   200
            HEIGHT  20
         END TEXTBOX // &c1txbNam
      NEXT nParam
      DEFINE BUTTON btnSampAply
         ROW 50
         COL 300
         WIDTH   40
         HEIGHT  20
         CAPTION 'Apply'
         ACTION  TstSamples( frmMOptsTest.cbxSamples.Value )
      END BUTTON // btnSampAply
      DEFINE FRAME fraParams
          ROW 85
          COL 40
          CAPTION "  Parameters  "
          WIDTH 320
          HEIGHT 315
      END FRAME // fraParams
   END WINDOW // frmMOptsTest
   CENTER WINDOW   frmMOptsTest
   ACTIVATE WINDOW frmMOptsTest
RETU // Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
PROC MakSamples()                         // Make sample datas for testing f.MsgExtended()
   LOCA nSample  := {},;
        a1MesLn  := {},;
        a1Option := {},;
        x1MesLn,;
        x1Option
   aSamples  := { "Without any parameter",;               //  1
                  "Without title",;                       //  2
                  "Without mesaj",;                       //  3
                  "Only mesaj",;                          //  4
                  "No mesaj, multiple options",;          //  5
                  "Simple message",;                      //  6
                  "Message with expressions - 1",;        //  7
                  "Famous Message",;                      //  8
                  "Two lines, two options",;              //  9
                  "Multiple Options",;                    // 10
                  "Single Line, multiple options",;       // 11
                  "Message with expressions - 2",;        // 12
                  "Different back color - 1",;            // 13
                  "Different back color - 2",;            // 14
                  "Different Font Size" }                 // 15
   aMsgSamples := { {},;                                                            //  1
                    { "Without Title" },;                                           //  2
                    {  , "Without mesaj" },;                                        //  3
                    { "Only one line message", "Only mesaj" },;                     //  4
                    { , "Column Selected", ;
                       {"Sort on this column","Hide Column","Ignore"} },;           //  5
                    { "This is message line", "Simple message", "Ok" },;            //  6
                    { DATE(), "Type is 'D'" },;                                     //  7
                    { "An undeterminable error occured",;                           //  8
                               "Famous Message",;
                               "Abort;;Retry;;Fail;;Ignore;;Cancel" },;
                    { { "Exit command requested",;                                  //  9
                               "Are you sure to quit ?" },;
                             { "No, Continue",;
                               "Yes, Quit" } },;
                    { { "This file hase been modified.",;                           // 10
                                 "Save it before close ? " },;
                               { "Save and Close",;
                                 "Close without save",;
                                 "Save, don't Close",;
                                 "Cancel Close Command" } },;
                    { { "Who is your favorite ?" },;                                // 11
                               { "Bart Simpson",;
                                 "Maradona" ,;
                                 "Don Quichote de La Mancha",;
                                 "C. Rice (Blackwitch)" ,;
                                 "G.W.Bush" } },;
                    { { "Today is:", DTOC(DATE()) + " " + CDOW(DATE()),;            // 12
                                  "90 day before is:",;
                                  DTOC(DATE() - 90) + " " + CDOW(DATE() - 90),;
                                  "2 * 2 = 4 is " + Any2Strg( 2 * 2 = 4 ),;
                                  "2 * 2 = 5 is " + Any2Strg( 2 * 2 = 5 ) },;
                                  "Message with expressions",;
                               { "Ok", "What is the matter?" } } }
   AADD( aMsgSamples, ACLONE( aMsgSamples[ 10 ] ) )                                 // 13
   aMsgSamples[ 13, 2 ] := "Different back color - 1"
   AADD( aMsgSamples[ 13 ], { 201, 215, 228 }  )  // grayed blue
   AADD( aMsgSamples, ACLONE( aMsgSamples[ 10 ] ) )                                 // 14
   aMsgSamples[ 14, 2 ] := "Different back color - 2"
   AADD( aMsgSamples[ 14 ], { 24, 240, 223 } )    // pastel turkuaz
   AADD( aMsgSamples, ACLONE( aMsgSamples[ 9 ] ) )                                  // 15
   aMsgSamples[ 15, 2 ] := "Different Font Size"
   AADD( aMsgSamples[ 15 ], NIL )  // Back color: default
   AADD( aMsgSamples[ 15 ], NIL )  // Message Font name: default
   AADD( aMsgSamples[ 15 ], 11 )   // Message Font Size
   AADD( aMsgSamples[ 15 ], NIL )  // Message Font color: default
   AADD( aMsgSamples[ 15 ], NIL )  // Opts. Font name: default
   AADD( aMsgSamples[ 15 ], 9)     // Opts. Font size
   AADD( aMsgSamples[ 15 ], { 0,8 } )    // Position
   FOR nSample := 1 TO LEN( aMsgSamples )
      IF !EMPTY( aMsgSamples[ nSample ] )
         x1MesLn  := aMsgSamples[ nSample, 1 ]
         IF !ISARRY( x1MesLn )                           // If isn't convert to array
            x1MesLn := { Any2Strg( x1MesLn )  }
         a1MesLn := ParsArStr( x1MesLn  )                // CRLF Evaluation for Messages lines
         x1MesLn := ACLONE( a1MesLn )
         a1MesLn := {}
         a1MesLn := ParsArStr( x1MesLn, ";;" )        // Double Semicolon Evaluation for Messages lines
         aMsgSamples[ nSample, 1 ] := a1MesLn
      ENDIF !EMPTY( aMsgSamples[ nSample ]
      IF LEN( aMsgSamples[ nSample ] ) > 2
         x1Option := aMsgSamples[ nSample, 3 ]
         IF !ISARRY( x1Option )                           // If isn't convert to array
            x1Option := { Any2Strg( x1Option )  }
         a1Option := ParsArStr( x1Option )                // CRLF Evaluation for Options
         x1Option := ACLONE( a1Option )
         a1Option := {}
         a1Option := ParsArStr( x1Option, ";;" )       // Double Semicolon Evaluation for Options
         aMsgSamples[ nSample, 3 ] := a1Option
      ENDIF LEN( aMsgSamples[ nSample ] ) > 2
   NEXT nSample
   aParNames := { "Message Lines",;           //  1
                  "Box Title",;               //  2
                  "Options",;                 //  3
                  "BackColor",;               //  4
                  "Msg. Font Name",;          //  5
                  "Msg. Font Size",;          //  6
                  "Msg. Font Color",;         //  7
                  "Opts. FontName",;          //  8
                  "Opts. Font Size",;         //  9
                  "Position" }                // 10
RETU // MakSamples()
PROC SetSmpVals( ;                        // Set sample text box values
              nSampleNo )
   LOCA aTstPars := aMsgSamples[ nSampleNo ]
   LOCA nParamCo  := LEN( aTstPars ),;
        nTxtBoxNo :=  0,;
        cTxtBxNam := '',;
        cTempStrg := '',;
        xTxtBxVal
   FOR nTxtBoxNo := 1 TO LEN( aParNames )
      xTxtBxVal := IF( nTxtBoxNo <= nParamCo, aTstPars[ nTxtBoxNo ], "" )
      IF ISARRY( xTxtBxVal )
         cTempStrg := ''
         AEVAL( xTxtBxVal, { | x1, i1 | cTempStrg += IF( i1 > 1, IF( ISNUMB( x1 ), ",", ";;" ), "" ) + Any2Strg( x1 ) } )
         xTxtBxVal := cTempStrg
      cTxtBxNam  := "txb" + STRZERO( nTxtBoxNo, 2 )
      SetProperty ( "frmMOptsTest", cTxtBxNam, "VALUE", Any2Strg( xTxtBxVal ) )
   NEXT nParamNo
RETU // SetSmpVals()
PROC GetSmpVals( ;                        // Get sample text box values
              nSampleNo )
   LOCA nParamCo  := LEN( aParNames ),;
        nTxtBoxNo :=  0,;
        cTxtBxNam := '',;
        aTemp     := {},;
        xTxtBxVal
   FOR nTxtBoxNo := 1 TO nParamCo
      xTxtBxVal := GetProperty ( "frmMOptsTest", cTxtBxNam, "VALUE" )
      AADD( aTemp, xTxtBxVal )
   NEXT nParamNo
   aMsgSamples[ nSampleNo ] := aTemp
RETU // GetSmpVals()
PROC TstSamples(;                         // Apply test for one sample
              nSampleNo )
   LOCA aTstPars  := {},;
        nParamCo  :=  0,;
        nParamNo  := 0,;
        cParName  := '',;
        nSelected :=  0,;
        cSelected := '',;
        nTxtBoxNo :=  0,;
        cTxtBxNam := '',;
        aOptions  := {},;
        xTxtBxVal
   GetSmpVals( nSampleNo )
   aOptions := ParsArStr( aTstPars[ 3 ], { CRLF, ";;" } )
   PRIV xParam1, xParam2, xParam3, xParam4, xParam5, xParam6, xParam7, xParam8, xParam9, xParam10
   FOR nParamNo := 1 TO nParamCo
      cParName  := "xParam" + NTrim( nParamNo )
      &cParname := aTstPars[ nParamNo ]
   NEXT nParamNo
   nSelected := MsgExtended( xParam1, xParam2, xParam3, xParam4, xParam5, xParam6, xParam7, xParam8, xParam9, xParam10 )
   IF nSelected < 1
      cSelected := "Escaped"
   ELSEIF LEN( aOptions ) < 2
      cSelected := "Confirmed"
      cSelected := aOptions[ nSelected ] + CRLF + CRLF + "selected."
   MsgInfo( cSelected, "RESULT" )
   frmMOptsTest.cbxSamples.SetFocus
RETU // TstSamples()
*  end of test prg
  History :
#define Emp2Nil( x ) IF( ISCHAR( x ) .AND. EMPTY( ALLTRIM( x ) ), , x )
#xcommand DEFAULT <v1> TO <x1> [, <vn> TO <xn> ]                        ;
          IF <v1> == NIL ; <v1> := <x1> ; END                           ;
          [; IF <vn> == NIL ; <vn> := <xn> ; END ]
   f.MsgExtended() : Message Extended
   Author  : Bicahi Esgici
   Syntax  : MsgExtended( [ <acMsgLines> ],;
                          [ <xTitle> ],;
                          [ <acOptions> ],;
                          [ <anBackColor> ],;
                          [ <cFontNameM> ],;
                          [ <nFontSizeM> ],;
                          [ <anFontColorM> ],;
                          [ <cFontNameO> ],;
                          [ <nFontSizeO> ],;
                          [ <xPosition ] )       => <nResult>
   Parameters :
             All parameters are optional.
             <acMsgLines>   : Message Line(s); Char for single, array for multiple lines; default is ""
             <xTitle>       : Tittle for Message box; char; default is ""
             <acOptions>    : Options; Char for single, array for multiple options; default is ""
             <anBackColor>  : Back Color; num array; default is windows default
             <cFontNameM>   : Font Name for message line(s); char; default is windows default
             <nFontSizeM>   : Font Size for message line(s); numeric; default is windows default
             <anFontColorM> : Font Color message line(s);  num array; default is windows default
             <cFontNameO>   : Font Name for option(s); default is windows default
             <nFontSizeO>   : Font Size for option(s); default is windows default
             <aPosition>    : Position relative to the window / form
                              NIL/EMPTY : will be defaulted to : { 0, 0 }
                              Numeric : will be defaulted to : { <this number>, 0 }
                              Array :  may be included 1 to 3 elements :
                                  1° : relativity base: 1: Desktop, 0: parent window/form;  default : 0
                                  2° : If element count is 2, Position code:
                                          0 : Center
                                          1: Up left
                                          2: Up cent
                                          3: Up right
                                          4: Center left
                                          5: Center right
                                          6: Down left
                                          7: Down center
                                          8: Down right
                                          default : 0 ( Center )
                                        else, If element count is 3, this number will be treated as row number
                                              for upper left corner of message box AND
                                  3° Column number for upper left corner of message box
             All parameters may be given as strings (character type). In this case arrays elements may
             be separated by CRLF or double semicolon (';;') for strings arrays and by comma (',') for
             numeric arrays. Expressions must be specified in their exact form.
   Return : <nResult> : Number of option selected;
                        When message box closed without selection ( Esc / Alt-F4 ), zero.
   History :
             2008.07 : First Release
FUNC MsgExtended( ;                          // Message Extended
               acMsgLines,;  // Message Line(s)
               xTitle,;      // Tittle for Message box
               xOptions,;    // Options
               aBackColor,;  // Back Color
               cFontNameM,;  // Msg. Font Name
               nFontSizeM,;  // Msg. Font Size
               aFontColorM,; // Msg. Font Color
               cFontNameO,;  // Opt. Font Name
               nFontSizeO,;  // Opt. Font Size
               xPosition  )  // Position relative to the window / form
   LOCA aMsgLines := {},;   // Message Lines
        aOptions  := {},;   // Options
        nRVal     :=  0,;
        nLinNo    :=  0,;
        c1Line    := '',;
        nOpts     :=  0,;
        c1Optn    := '',;
        nMxLnLn   :=  0,;  // Max Line Len
        nOptnCo   :=  0,;  // Option Count
        cLblNam   := '',;  // Label Name
        cbtnNam   := '',;  // Button Name
        nButRow   :=  0,;
        nLnLnPx   :=  0    // Message Line Length in pixel
   LOCA nRelBase  :=  0,;
        nMsBxRow  :=  0,;
        nMsBxCol  :=  0,;
        nPosCode  :=  0,;
        cPosCode  := '',;
        nBaseRow  :=  0,;
        nBaseCol  :=  0,;
        nBasHeig  :=  0,;
        nBasWidt  :=  0
   LOCA nMLineCo  :=  0,;         // Messages line count
        nMBxHeig  :=  0,;
        nMBxWidt  :=  0,;
        nMxBtnLn  :=  0,;         // Max Button length (in pixel )
        nBtn1Len  :=  0,;
        nBtnTotL  :=  5
   LOCA nMFontSiz :=  0,;
        nOFontSiz :=  0,;
        lVertOpts := .F.
   *  Defaulting parameters
   acMsgLines  := Emp2Nil( acMsgLines )
   xTitle      := Emp2Nil( xTitle )
   xOptions    := Emp2Nil( xOptions )
   aBackColor  := Emp2Nil( aBackColor )
   cFontNameM  := Emp2Nil( cFontNameM )
   nFontSizeM  := Emp2Nil( nFontSizeM )
   aFontColorM := Emp2Nil( aFontColorM )
   cFontNameO  := Emp2Nil( cFontNameO )
   nFontSizeO  := Emp2Nil( nFontSizeO )
   xPosition   := Emp2Nil( xPosition )
   DEFAULT acMsgLines  TO  {""},;
           xTitle      TO  Any2Strg( xTitle ),;
           xOptions    TO  {" Ok "},;              // aBackColor  TO  { 201, 215, 228 },;  //
           xPosition   TO  { 0, 0 }
   IF ISCHAR( aBackColor )
      aBackColor := ParsArStr( aBackColor , { CRLF, ',' } )
      IF LEN( aBackColor ) # 3
        aBackColor := NIL
        AEVAL( aBackColor, { | c1, i1 | aBackColor[ i1 ] := VAL( c1 ) } )
   IF ISCHAR( aFontColorM )
      aFontColorM := ParsArStr( aFontColorM , { CRLF, ',' } )
      IF LEN( aFontColorM ) # 3
         aFontColorM := NIL
         AEVAL( aFontColorM, { | c1, i1 | aFontColorM[ i1 ] := VAL( c1 ) } )
   IF ISCHAR( nFontSizeM )
      nFontSizeM := VAL( nFontSizeM )
   IF ISCHAR( nFontSizeO )
      nFontSizeO := VAL( nFontSizeO )
   IF ISNIL( cFontNameM ) .AND. !ISNIL( nFontSizeM )
      cFontNameM := "Arial"
   IF ISNIL( cFontNameO ) .AND. !ISNIL( nFontSizeO )
      cFontNameO := "Arial"
   nMFontSiz := MAX( MIN( IF( ISNIL( nFontSizeM ), 9, nFontSizeM ), 32 ), 8 )
   nOFontSiz := MAX( MIN( IF( ISNIL( nFontSizeO ), 9, nFontSizeO ), 32 ), 8 )
   IF !ISNIL( nFontSizeM )
      nFontSizeM := nMFontSiz
   IF !ISNIL( nFontSizeO )
      nFontSizeO := nOFontSiz
   aMsgLines := ParsArStr( acMsgLines, { CRLF, ";;" } )                  // Message lines
   nMLineCo := LEN( aMsgLines )
   AEVAL( aMsgLines, { | c1 | nMxLnLn := MAX( nMxLnLn, LEN( c1 ) ) } )   // Max Line Legth of Messages lines
   nLnLnPx :=  nMxLnLn * nMFontSiz * .8                                  // Messages line length by pixel
   * Buttons ( Options )
   aOptions := ParsArStr( xOptions, { CRLF, ";;" } )                // Options
   nOptnCo :=  LEN( aOptions )                                      // Options (buttons) Count
   lVertOpts := ( EMPTY( aMsgLines ) .AND. nOptnCo > 1 )
   AEVAL( aOptions,  { | c1 |  nBtn1Len := nOFontSiz * LEN( c1 ) * .8 + 10,;
                               nMxBtnLn := MAX( nMxBtnLn, nBtn1Len ),;
                               nBtnTotL += nBtn1Len } )
   * Form metrics
   IF lVertOpts
      nMBxHeig := 40 + ( nOptnCo * 4 * nOFontSiz )
      nMBxWidt := MAX( nMxBtnLn, 123 ) + 100 // !!! 123 : Min Window WIDTH !!!
      nMBxHeig := 40 + ( nMLineCo * 4 * nMFontSiz ) + ( nOFontSiz * 6 )
      nMBxWidt := MAX( MAX( nBtnTotL, nLnLnPx ), 123 ) + 10 // !!! 123 : Min Window WIDTH !!!
   ENDIF lVertOpts
   * Position of Message Box
   IF EMPTY( xPosition )
      xPosition := { 0, 0 }
   IF ISCHAR( xPosition )
      xPosition := ParsArStr( xPosition, { CRLF, ',' } )
   IF ISARRY( xPosition )
      AEVAL( xPosition, { | x1, i1 | xPosition[ i1 ] := IF( ISCHAR( x1 ), VAL( x1 ), 0 ) } )
      IF ISNUMB( xPosition )
         xPosition := { xPosition, 0 }
   nRelBase := xPosition[ 1 ]
   IF nRelBase < 1     // Parent ( Caller of f.MsgExtended() form/window
      nBaseRow :=  ThisWindow.Row
      nBaseCol :=  ThisWindow.Col
      nBasHeig :=  ThisWindow.Height
      nBasWidt :=  ThisWindow.Width
   ELSE                // Desktop
      nBasHeig :=  GetDesktopHeight()
      nBasWidt :=  GetDesktopWidth()
   ENDIF nRelBase < 1
   IF LEN( xPosition ) > 2
      nMsBxRow := nBaseRow + xPosition[ 2 ]
      nMsBxCol := nBaseCol + xPosition[ 3 ]
      nPosCode := xPosition[ 2 ]
      cPosCode := NTrim( nPosCode )
      IF cPosCode $ "123"             // Up line
         nMsBxRow :=  nBaseRow + 50
      ELSEIF cPosCode $ "678"         // Down lin
         nMsBxRow :=  nBasHeig - nMBxHeig - 10 + nBaseRow
      ELSE                            // Center Line
         nMsBxRow :=  ( nBasHeig - nMBxHeig ) / 2 + nBaseRow
      IF cPosCode $ "146"             // Left Column
         nMsBxCol :=  nBaseCol + 10
      ELSEIF cPosCode $ "358"         // Rigth Column
         nMsBxCol :=  nBaseCol + nBasWidt / 3 * 2
      ELSE                            // Center Column
         nMsBxCol :=  ( nBasWidt - nMBxWidt ) / 2 + nBaseCol
   ENDIF LEN( xPosition ) > 2
   DEFINE WINDOW frmMsgExtended ;
      AT     nMsBxRow, nMsBxCol ;
      WIDTH  nMBxWidt ;
      HEIGHT nMBxHeig ;
      TITLE  xTitle ;
      MODAL  ; //      NOSIZE ;
      NOSYSMENU ;
      BACKCOLOR aBackColor  // { 201, 215, 228 } { 24, 240, 223 }
      ON KEY ESCAPE ACTION frmMsgExtended.Release
      FOR nLinNo := 1 TO nMLineCo
         cLblNam := 'lbl_' + STRZERO( nLinNo, 2 )
         c1Line  := aMsgLines[ nLinNo ]
         DEFINE LABEL &cLblNam
            ROW       (nLinNo * 3 - 1 ) * nMFontSiz
            COL       0
            VALUE     c1Line
            WIDTH     nMBxWidt
            HEIGHT    nMFontSiz * 2
            FONTNAME  cFontNameM
            FONTSIZE  nFontSizeM
            FONTCOLOR aFontColorM
            CENTERALIGN  .T.
         END LABEL
      NEXT nLinNo
      IF lVertOpts
         nButRow  := nOFontSiz * 2
         nButRow := nMBxHeig - 40 - nOFontSiz * 3
      ENDIF lVertOpts
      nBtnSpac := INT( ( nMBxWidt - nBtnTotL ) / ( nOptnCo + 1 ) )
      n1BtnCol := nBtnSpac
      FOR nOpts := 1 TO nOptnCo
         c1Optn   := aOptions[ nOpts ]
         cbtnNam  := 'btn_'  + STRZERO( nOpts, 2 )
         nBtnWidt := INT( nOFontSiz * ( LEN( c1Optn ) ) * .8 + 10 )
         IF lVertOpts
            n1BtnCol := ( nMBxWidt - nBtnWidt ) / 2
         ENDIF lVertOpts
         DEFINE BUTTON &cbtnNam
            ROW         nButRow
            COL         n1BtnCol
            CAPTION     c1Optn
            ACTION      { || nRVal := VAL( RIGHT( this.name, 2 ) ),  frmMsgExtended.Release }
            WIDTH       nBtnWidt
            HEIGHT      nOFontSiz * 2 + 4
            FONTNAME    cFontNameO
            FONTSIZE    nFontSizeO
            CENTERALIGN .T.
         END BUTTON
         IF lVertOpts
            nButRow += nOFontSiz * 3
            n1BtnCol += nBtnWidt + nBtnSpac
         ENDIF lVertOpts
      NEXT nOpts
   END WINDOW // frmMsgExtended
   ACTIVATE WINDOW frmMsgExtended
RETU nRVal // MsgExtended()
    f.Any2Strg() : Covert any type data to string
    Syntax       : Any2Strg( <xAny> ) -> <cString>
    Argument     : <xAny> : A value in any data type
    Return       : <cString> : String equivalent of <xAny>
    History      :
                   7.2006 : First Release
FUNC Any2Strg( xAny )
   LOCA cRVal  := '???',;
        nType  :=  0,;
        aCases := { { "A", { | x | "{...}" } },;
                    { "B", { | x | "{||}" } },;
                    { "C", { | x | x }},;
                    { "M", { | x | x   } },;
                    { "D", { | x | DTOC( x ) } },;
                    { "L", { | x | IF( x,"True","False") } },;
                    { "N", { | x | NTrim( x )  } },;
                    { "O", { | x | ":Object:" } },;
                    { "U", { | x | "" } } }
   IF (nType := ASCAN( aCases, { | a1 | VALTYPE( xAny ) == a1[ 1 ] } ) ) > 0
      cRVal := EVAL( aCases[ nType, 2 ], xAny )
RETU cRVal // Any2Strg()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._
   f.ParsArStr() is a sub-function of f.MsgExtended().
   Purpose : Pars Lines of an array
   Syntax  : ParsArStr( <aArray>, <aDelim> ) => <aParsed>
   Parameters : <aArray> : Array to parse
                <aDelim> : Delimiter(s)
   Return : <aParsed> : Parsed verison of <aArray>
   History :
FUNC ParsArStr(;                                    // Pars Lines of an array
                aArray, aDelim )
   LOCA nDelm  :=  0,;
        cDelm  := '',;
        nLiNo  :=  0,;
        c1Lin  := '',;
        aTemp  := {},;
        a1Arr  := {},;
        nPosNo :=  0,;
        aRVal  := {}
   DEFAULT aDelim TO { CRLF }
   IF !ISARRY( aArray )
      aArray := { Any2Strg( aArray ) }
   IF !ISARRY( aDelim )
      aDelim := { Any2Strg( aDelim ) }
   FOR nDelm := 1 TO LEN( aDelim )
      cDelm := aDelim[ nDelm ]
      FOR nLiNo := 1 TO LEN( aArray )
         c1Lin  := aArray[ nLiNo ]
         a1Arr  := {}
         IF ISCHAR( c1Lin ) .AND. !EMPTY( c1Lin )
            WHILE ( nPosNo := AT( cDelm, c1Lin ) ) > 0
               AADD( a1Arr, LEFT( c1Lin, nPosNo - 1 ) )
               c1Lin := SUBS( c1Lin, nPosNo + LEN( cDelm ) )
            ENDDO
            IF !EMPTY( c1Lin  )
               AADD( a1Arr, c1Lin )
         ENDIF ISCHAR( c1Lin ) .AND. !EMPTY( c1Lin )
         AEVAL( a1Arr, { | c1 | AADD( aTemp, c1 ) } )
      NEXT nLinNo
      aRVal := ACLONE( aTemp )
      aTemp := {}
   NEXT nDelm
RETU aRVal // ParsArStr()
* end of MsgExtended.prg; function itself and two sub-functions.
