How to Export to Excel
Has thanked: 293 times
Been thanked: 212 times
Do anybody know, how to export database to excel?
Regards, Marek
dhaine_adp
Been thanked: 3 times
Post by dhaine_adp »
I think the easiest way is to open MS Excel 2003 (I believed it would be the same procedure for MS Office 2007) and do:
1. File Open
2. then on file types select dBase files (*.dbf)
3. then select the file, and excel will open that file.
4. Then do save as: Microsoft Excel Workbook (*.xls)
However if the database is from two or more files you should use HB OLE to transfer the file and format them the way you like to be.
Danny
Manila, Philippines
Has thanked: 249 times
Been thanked: 301 times
You can use Harbour OLE also.
Kindly see \hmg\samples\ole\demo.prg
Many thanks for your answers,
Marek
To Rathinagiri:
I tried ole\demo.prg
It's very useful.
Can you tell mi if I can do it "silent" - without opening window with MS Excel?
Marek
I don't know. :( Let me try.
Can you help me how to open existing XLS sheet and write some data at the first empty cell in "A" column?
Don't you know where can I find something about using OLE and excel?
bruno
Post by bruno »
May be you can try using MiToprint library from jose miguel
http://www.embalajesterra.com/misdoc/ej ... NTOv23.zip
the library can export a database report to spreadsheet format
i think that a time ago Jose Miguel change to use Openoffice in place of Microsoft Office
In previous versions it use excel , may be I can find an old version for you, try it
Bruno
bruno
Post by bruno »
I have version 2.0 of MiTprinto if you like , let me know
and I send tou you by mail
Bruno
I think it doesn't have the library you mention.
Please send the code to connect to Openoffice as you mentioned.
Thanks in Advance.
