HB_ZipFile() & HB_UnZipFile()
Source code related resources
Has thanked: 411 times
Been thanked: 120 times
Re: HB_ZipFile() & HB_UnZipFile()
mustafa wrote:
Fri Mar 15, 2019 1:45 pm
Hello friends
We are still experimenting with the ZIP theme
Here you have a new delivery based on the sample
previous with some modifications in the Source Code
and an expansion in the Options Menu
Watch the sample, if it may interest you? :idea:
Thanks Mustafa :)
hmgchang
Has thanked: 16 times
Been thanked: 11 times
Post by hmgchang »
Hola Masters,
1. How to add/update files into existing zip file?
I backup files in zipfile, and only want to update only the changed files. Using hb_zipopen () will erase all the files in zip making the zipfile size to 0byte.
I cant find any function to open for append/update.
Pls advise n thanks a lot
Thks n rgd
Chang
Just Hmg It !
Has thanked: 193 times
Been thanked: 650 times
HB_ZIPFILE:HB_ZIPFILE()
Create a zip file
Syntax
HB_ZIPFILE( <cFile> , <cFileToCompress> | <aFiles>, <nLevel> , <bBlock>,<lOverWrite> ,<cPassword>,<lWithPath>,<lWithDrive>) ---> lCompress
Arguments
<cFile> Name of the zip file
<cFileToCompress> Name of a file to Compress, Drive and/or path can be used
<aFiles> An array containing files to compress, Drive and/or path can be used
<nLevel> Compression level ranging from 0 to 9
<bBlock> Code block to execute while compressing
<lOverWrite> Toggle to overwite the file if exists
<cPassword> Password to encrypt the files
<lWithPath> Toggle to store the path or not
<lWithDrive> Toggle to store the Drive letter and path or not
Returns
<lCompress> .t. if file was create, otherwise .f.
Description
This function creates a zip file named <cFile>. If the extension is ommited, .ZIP will be assumed. If the second parameter is a character string, this file will be added to the zip file. If the second parameter is an array, all file names contained in <aFiles> will be compressed.
If <nLevel> is used, it detemines the compression type where 0 means no compression and 9 means best compression.
If <bBlock> is used, every time the file is opened to compress it will evaluate bBlock. Parameters of bBlock are cFile and nPos.
If <lOverWrite> is used , it toggles to overwrite or not the existing file. Default is to overwrite the file,otherwise if <lOverWrite> is false the new files are added to the <cFile>.
If <cPassword> is used, all files that are added to the archive are encrypted with the password.
If <lWithPath> is used, it tells thats the path should also be stored with the file name. Default is false.
If <lWithDrive> is used, it tells thats the Drive and path should also be stored with the file name. Default is false.
hmgchang
Post by hmgchang »
This Mr. EDK....
I will try.
Thks n Eyes
Chang
Just Hmg It !
hmgchang
Post by hmgchang »
Hola Masters,
i tried hb_zipfile() and found :
1. With the lOverWrite set to .F., we may have two/more same filename in the zipfile.
2. It always create a new zipfile, this prevent us from adding files into an existing zipfile. ( this is my question is about).
3. It does not include subdir in the zipfile
4. It support the wildcard *.*
So,.. i still need any suggestion on how to add files to an existing zipfile without erasing the existing-files in the zipfile.
thks n rgds
Chang
Just Hmg It !
