HFCL (Hmg Forum Component Library)
Source code related resources
Has thanked: 85 times
Been thanked: 184 times
Re: HFCL (Hmg Forum Component Library)
sudip wrote:
Roberto Lopez wrote:
sudip wrote:It runs fine. :)
Thanks a lot.
Do you have any plan to include ComboSearchBox control in next version of IDE? We are waiting for this :)
Its already done!!! :)
The way to add an user component to IDE is the creation of a '.uci' file containing properties and events for that control.
'combosearchbox.uci' is included in the attachment.
Thanks a lot Master Roberto. I am not sure where I did wrong, but when I try to change form, most of the properties of ComboSearchBox control are vanished. Moreover I cannot see any property/method in the property window when I select ComboSearchBox control.
I want to learn where I am doing mistakes.
Thank you very much again for ComboSearchBox.uci.
Please, try with 2.8.6g IDE.
Has thanked: 5 times
Been thanked: 5 times
Hello Master Roberto,
Thanks a lot! I am using the same version. Now I found ComboSearchBox control in User Component combo box.
When I want to view codes from View -> Form code menu it shows only:
* Harbour MiniGUI IDE Two-Way Form Designer Generated Code
* (c)2004-2009 Roberto Lopez <harbourminigui@gmail.com>
* http://harbourminigui.googlepages.com
DEFINE WINDOW TEMPLATE AT 181 , 348 WIDTH 516 HEIGHT 402 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "Hello World" ICON NIL MAIN CURSOR NIL ON INIT Nil ON RELEASE Nil ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR Nil NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
    DEFINE COMBOSEARCHBOX combosearchbox_1
        ROW    60
        COL    170
        WIDTH  140
        HEIGHT 20
    END COMBOSEARCHBOX
As I know little about how to use user component, I am not sure about it (I mean when I try to open .fmg file with a text editor, I found lots of properties for COMBOSEARCHBOX there.)
Please don't mind, I am asking this query as I want to learn it. And sorry for my novice queries. :(
kesisim
Post by kesisim »
esgici wrote:Thanks a lot Maestro :D
Merhaba Esgici
İsmini bilmediğim için bu şekilde hitap ettim. Özür dilerim. Bir Clipper sevdalısıyım. Bende Çıktığından bu yana Minigui kullanıyorum. Üretmiş olduğun Csbox kontrolu güzel bir uygulama yalnız bir hatası var. Aynı Pencerede 2 adet farklı şekilde kullanıldığında bu kontrol önceden tanımlanmış şeklinde bir hata vererek çıkıyor. Bildirmeyi görev bildim.
Fazla ingilizcem iyi değil bu nedenle sana yazdım.
Hüseyin Aydın.
h.aydin42@gmail.com
I've tested again and I've not found any problem.
Are you using the current IDE version?
bobypoz
Post by bobypoz »
Here is my little contribution
   // SERBIAN    \    CROATIAN
   private msgarr := {"Nema ništa za štampu!",;
                   "Nijedan štampač nije instaliran!",;
                   "Čarobnjak za štampu",;
                   "Kreator izveštaja",;
                   "Kolone",;
                   "Nazivi kolona",;
                   "Širina (mm)",;
                   "Kliknite dva puta na kolonu kako biste je označili da li je štampati ili ne.",;
                   "Veličina kolone sa tekstom",;
                   "Ukupna širina :",;
                   "Izvan",;
                   "Naslov 1",;
                   "Naslov 2",;
                   "Naslov 3",;
                   "Podnožje (futer) 1",;
                   "Osobine izveštaja",;
                   "Veličina slova",;
                   "Duži tekst",;
                   "Prelom linija",;
                   "Skratiti",;
                   "Numeracija strana",;
                   "Isključeno",;
                   "Vrh",;
                   "Dno",;
                   "Linije tabele",;
                   "Kolona",;
                   "Red",;
                   "Centar strane",;
                   "Vertikalno",;
                   "Strana / Štampač",;
                   "Orijentacija",;
                   "Pejzaž",;
                   "Portret",;
                   "Štampač: ",;
                   "Veličina strane",;
                   "Širina strane",;
                   "Visina strane",;
                   "Margine (mm)",;
                   "Vrh",;
                   "Desno",;
                   "Levo",;
                   "Dno",;
                   "Štampaj",;
                   "Otkaži",;
                   "Dobrodošli u čarobnjak za štampu",;
                   "Izabrali ste više kolona nego što staje u štampu!",;
                   "Morate izabrati štampač!",;
                   "Štampač ne može biti izabran! Proverite vezu sa štampačem.",;
                   "Strana br.. :",;
                   "Veličina :",;
                   "Završeno",;
                   "Veličina kolona koje nisu tekstualne ne može biti izmenjena!",;
                   "Konstante za ravnjanje teksta nisu ispravne.",;
Has thanked: 100 times
Been thanked: 182 times
bobypoz wrote:Here is my little contribution
                   "Kolone",;
                   "Nazivi kolona",;
                   "Širina (mm)",;
                   "Ukupna širina :",;
                   "Izvan",;
                   "Naslov 1",;
                   "Naslov 2",;
                   "Naslov 3",;
                   "Veličina slova",;
                   "Duži tekst",;
                   "Prelom linija",;
                   "Skratiti",;
                   "Isključeno",;
                   "Vrh",;
                   "Dno",;
                   "Linije tabele",;
                   "Kolona",;
                   "Red",;
                   "Centar strane",;
                   "Vertikalno",;
                   "Orijentacija",;
                   "Pejzaž",;
                   "Portret",;
                   "Štampač: ",;
                   "Veličina strane",;
                   "Širina strane",;
                   "Visina strane",;
                   "Margine (mm)",;
                   "Vrh",;
                   "Desno",;
                   "Levo",;
                   "Dno",;
                   "Štampaj",;
                   "Otkaži",;
                   "Strana br.. :",;
                   "Veličina :",;
                   "Završeno",;
Good ! This is so good !
Thank you to help for multi languages.
