HMG 3.0.40, print preview problem
Source code related resources
majkll_ns
Post by majkll_ns »
I have problem using
SELECT PRINTER DIALOG TO print_ok PREVIEW
which gives:
Error BASE/2022 Argument error: ALLTRIM
Called from ALLTRIM(0)
Called from STRZERO(743)
I use and propose this solution:
in HMG\SOURCE\h_controlmisc.prg add
* Mkl to avoid error in printer previewrefresh
* replace strzero with this
* also replace in include\i_print.ch
Function sstrzero ( m_num, m_len )
private m_s, m_v
m_v:=m_num
if type('m_v')<>'N'
m_num:=0
m_s:=replicate('0',m_len)+alltrim(str(m_num))
m_s:=right(m_s,m_len)
return m_s
and replace all strzero with sstrzero in HMG\SOURCE\h_controlmisc.prg and HMG\INCLUDE\i_print.ch.
Then, create obj directory under HMG and use Makehmg.bat from HMG\SOURCE
You should have new libhmg.a in HMG\Lib
After this all compiled program work fine.
salamandra
DBs Used: DBF, MySQL, SQL
Has thanked: 209 times
Been thanked: 20 times
Post by salamandra »
:) Hi majkll_ns ,
I use HMG 3.0.40 and work fine for me ;)
Be sure that "print_ok" it´s a logical value...
[]´s Salamandra
majkll_ns
Post by majkll_ns »
salamandra wrote::) Hi majkll_ns ,
[]´s Salamandra
I try that in a first place, but no result.
print_ok (lsuccess in demos) don't have to be defined. Command create it. To be sure I put print_ok:=.t. before it.
I locate problem in strzero(). If parameter given to strzero isn't defined or is a wrong type - it generates error. If I see it good, there are two things which can cause problem: seconds() and logic to deal with printing odd and even pages. I couldn't resolve it, so I change it in a described way.
And yes, and this take me great amount of time, same code which generate problem I put in separate program, just with part for generating one page and - it work just fine! And error in application. My solution can be marked as workaround. What is real cause I don't know.
If one ever face this as I do - try proposed solution :)
Has thanked: 411 times
Been thanked: 120 times
Hi
The <hmg>\SAMPLES\PRINT\filledrectangle\demo.prg has a function that achieve this task with no problem :
Procedure PrintTest4()
Local i
Local lSuccess
	SELECT PRINTER DIALOG TO lSuccess PREVIEW
	If lSuccess == .T.
		PrintDoc()
		MsgInfo('Print Finished')
	EndIf
If you give your code segment that cause the problem we will work on it.
