Consulta por TAB control
claudiotedesco
Post by claudiotedesco »
Tengo armado un Tab Control con 4 solapas y quisiera que cuando se presiona un boton determinado se oculten 2 de las 4 solapas.
Eso es posible? si no es asi por lo menos desactivar las 2 solapas momentaneamente.
Gracias
Claudio
I have assembled a Tab Control with 4 flaps and would like when you press button is hide 2 of the 4 flaps. That's possible? If it is not at least momentarily off the 2 flaps.
Thanks
Has thanked: 85 times
Been thanked: 184 times
claudiotedesco wrote:Tengo armado un Tab Control con 4 solapas y quisiera que cuando se presiona un boton determinado se oculten 2 de las 4 solapas.
Gracias
Claudio
Thanks
That is not implemented yet, but something like this could be useful.
The following sample, disables page 3:
 * Copyright 2008 Roberto Lopez <harbourminigui@gmail.com>
#include "minigui.ch"
Local aRows [20] [3]
Public nTabValue := 1
	aRows [1]	:= {'Simpson','Homer','555-5555'}
	aRows [2]	:= {'Mulder','Fox','324-6432'}
	aRows [3]	:= {'Smart','Max','432-5892'}
	aRows [4]	:= {'Grillo','Pepe','894-2332'}
	aRows [5]	:= {'Kirk','James','346-9873'}
	DEFINE WINDOW Form_1 ;
		WIDTH 640 HEIGHT 480 ;
		TITLE 'Harbour MiniGUI Demo' ;
		MAIN
		DEFINE MAIN MENU
			DEFINE POPUP 'Test'
				MENUITEM 'Get Button Caption' ACTION MsgInfo ( Form_1.Tab_1(1).Button_1.Caption )
				MENUITEM 'Set Button Caption' ACTION Form_1.Tab_1(1).Button_1.Caption := 'New'
				SEPARATOR
				MENUITEM 'Get Grid Header' ACTION MsgInfo ( Form_1.Tab_1(4).Grid_1.Header(1) )
				MENUITEM 'Set Grid Header' ACTION Form_1.Tab_1(4).Grid_1.Header(1) := 'New'
				SEPARATOR
				MENUITEM 'Set Grid Cell' ACTION Form_1.Tab_1(4).Grid_1.Cell(1,1) := 'New'
				MENUITEM 'Get Grid Cell' ACTION MsgInfo ( Form_1.Tab_1(4).Grid_1.Cell(1,1) )
				SEPARATOR
				MENUITEM 'Show Button' ACTION Form_1.Tab_1(1).Button_1.Show()
				MENUITEM 'Hide Button' ACTION Form_1.Tab_1(1).Button_1.Hide()
			END POPUP
		END MENU
		DEFINE TAB Tab_1 ;
			AT 10,10 ;
			WIDTH 600 ;
			HEIGHT 400 ;
			VALUE 1 ;
			TOOLTIP 'Tab Control';
			ON CHANGE Test()
			PAGE 'Page 1'
			      @ 100,250 BUTTON Button_1 CAPTION "Test" WIDTH 50 HEIGHT 50 ACTION MsgInfo('Test!')
			END PAGE
			PAGE 'Page &2'
				DEFINE RADIOGROUP R1
					ROW	100
					COL	100
					OPTIONS	{ '1','2','3' }
					VALUE	1
				END RADIOGROUP
			END PAGE
			PAGE 'Page 3'
				@ 100,250 SPINNER Spinner_1 ;
				RANGE 0,10 ;
				VALUE 5 ;
				WIDTH 100 ;
				TOOLTIP 'Range 0,10' ;
				ON CHANGE PlayBeep()
			END PAGE
			PAGE 'Page 4'
				@ 50,50 GRID Grid_1 ;
					WIDTH 200 ;
					HEIGHT 330 ;
					HEADERS {'Last Name','First Name','Phone'} ;
					WIDTHS {140,140,140};
					ITEMS aRows ;
					VALUE 1
			END PAGE
		END TAB
	Form_1.Center
	Form_1.Activate
procedure Test
	If This.Value == 3
		This.value := nTabValue
	EndIf
	nTabValue := This.Value
claudiotedesco
Hola Roberto
Te agradezco por tu ayuda.
Lo voy a implementar.
Gracias
Claudio
