Entering numericals via num pad in Germany
fredmr
Post by fredmr »
Hi folks,
first of all a big "thank you" to the developers of HMG and all other involved people !!!
Currently I'm trying to solve a problem associated with a german characteristic:
In Germany numeric values have the decimal separator ',' and not '.' like in most
parts of the world. The german thousands separator is "." and not "," like usual.
Example:
in Germany: 1.234.567,89
in USA: 1,234,567.89
So german keyboard have a ',' on the num pad instead of '.'
I'm now playing around with textboxes and its inputmask parameter: When I
define the appropiate texbox property als numeric, I have to use the international
way of entering values, for example via inputmask "999.00". Germans are not
able to use the ',' of their num pads. :-(
When I define the textbox as a character based one I'm able to define an
inputmask like "999.999,99" but I'll have to eval any of such textboxes and to
convert those strings into numericals... :-(
Is there any solution for this behaviour ? Is it possible to tell HARBOUR to use
the german separators ? 'Set Language To German' doesn't seem to work for
this situation...
Thank you in advance,
Fred...
fredmr
Post by fredmr »
Hi again,
seeing that noone can help has taken me to have a look into the
user components example. When trying to compile 'demo.prg'
in 'C:\HMG\SAMPLES\USER_COMPONENTS' I get the following
errors:
Harbour 1.0.0 Intl. (Rev. 9175)
Copyright (c) 1999-2008, http://www.harbour-project.org/
Compiling 'demo.prg'...
demo.prg(22) Error E0030 Syntax error: "syntax error at '.'"
demo.prg(23) Error E0030 Syntax error: "syntax error at '.'"
demo.prg(24) Error E0030 Syntax error: "syntax error at '.'"
demo.prg(25) Error E0030 Syntax error: "syntax error at '.'"
demo.prg(34) Error E0030 Syntax error: "syntax error at '@'"
Compiling module 'MyButton.Prg'...
5 errors
No code generated
gcc: demo.c: No such file or directory
gcc: no input files
gcc: demo.o: No such file or directory
C:\HMG\SAMPLES\USER_COMPONENTS\demo.c konnte nicht gefunden werden
C:\HMG\SAMPLES\USER_COMPONENTS\demo.o konnte nicht gefunden werden
So what's wrong with this example ?
TIA,
Fred...
gfilatov
Has thanked: 43 times
Been thanked: 551 times
Post by gfilatov »
fredmr wrote:...
errors:
Fred,
Take a look for readme.txt at your folder C:\HMG\SAMPLES\USER_COMPONENTS:
HMG USER COMPONENTS SAMPLE
To run this sample, please add the following text to c:\hmg\include\usrinit.ch
#define BASEDEF_MYBUTTON
#xcommand @ <row>,<col> MYBUTTON <name> ;
OF <parent> ;
CAPTION <caption> ;
ACTION <action> ;
_DefineMyButton(<"name">,<row>,<col>,<caption>,<{action}>,<"parent">)
#undef BASEDEF_MYBUTTON
And ADD the following to c:\hmg\include\i_usrsoop.ch without leaving blank
lines between the text currently in that file and this.
#define SOOP_MYBUTTON ;;
#xtranslate <Window> . \<Control\> . Disable => Domethod ( <"Window">, \<"Control"\> , "Disable" ) ;;
#xtranslate <Window> . \<Control\> . Enable => Domethod ( <"Window">, \<"Control"\> , "Enable" ) ;;
#xtranslate <Window> . \<Control\> . Handle => GetProperty ( <"Window">, \<"Control"\> , "Handle" ) ;;
#xtranslate <Window> . \<Control\> . Handle := \<v\> => SetProperty ( <"Window">, \<"Control"\> , "Handle" , \<v\> ) ;;
#undef SOOP_MYBUTTON ;;
I hope that give you an ideas.
Has thanked: 252 times
Been thanked: 305 times
Please give your code also. Then only we can see what would be the error.
fredmr
Post by fredmr »
Thank you !
It bas been my fault: I didn't change the usrinit.ch
I didn't carefully read the readme.txt :-(
Currently there's no source code; I only wanted to see
the example, but due to the missing include I couldn't
work.
Thank you again,
Fred...
