Obtaining Selection
Has thanked: 411 times
Been thanked: 120 times
Obtaining Selection
Hi All
Is there a way ( if so sample(s) ) to obtain user's "selected item(s)" from LISTBOX and/or GRID :?:
PS: Without using OnDblClick event.
Has thanked: 249 times
Been thanked: 301 times
I think I don't get your point.
Now, we are getting the selected item(s) from the value property of the particular grid. Isn't it?
rathinagiri wrote: Now, we are getting the selected item(s) from the value property of the particular grid. Isn't it?
Hi Rathi
Not quite.
When MULTISELECT is off (default) and VALUE is a single numeric, VALUE property alway updates properly by system while user changes current item into LISTBOX or GRID. In this case we can always obtain user's selection via VALUE property.
When MULTISELECT is on, VALUE property must be a numeric array. In this case user can select single or multiple items into control ( LISTBOX / GRID ) by using almost every selection keystrokes ( up/down keys with shift/ctrl combinations ) and mouse movements (with again shift/ctrl combinations ) except Ctrl-A.
Unfortunately in this second case VALUE array does not update internally by system and we cannot obtain user selection(s).
At least I can't succeed :(
gfilatov
Has thanked: 43 times
Been thanked: 539 times
Post by gfilatov »
esgici wrote:...
Esgici,
Kindly try the following working sample:
* Harbour MiniGUI Hello World Demo
* (c) 2002-2004 Roberto Lopez <harbourminigui@gmail.com>
#include "minigui.ch"
	DEFINE WINDOW Win1 ;
		WIDTH 400 ;
		HEIGHT 400 ;
		TITLE 'Hello World!' ;
		DEFINE LISTBOX LIST1
			ROW	10
			COL	10
			WIDTH	100
			HEIGHT	110
			ITEMS	{ '01','02','03','04','05','06','07','08','09','10' }
			MULTISELECT .T.
		END LISTBOX
		DEFINE BUTTON BUTTON1
			ROW	10
			COL	150
			CAPTION	'Get Selected Items'
			ACTION	SelectTest()
			WIDTH	150
		END BUTTON
	ACTIVATE WINDOW Win1
Procedure SelectTest
local x, n_for, n_pos
local a_result := win1.list1.value
if len( a_result ) == 0
   return
end
x := ''
for n_for=1 to len( a_result )
   n_pos := a_result[ n_for ]
   x += str(n_for) + ": "+ win1.list1.item( n_pos ) + chr(13)
next
msginfo( x , 'Selected item(s): ' + alltrim( str( len( a_result ) ) ) )
Has thanked: 85 times
Been thanked: 184 times
gfilatov wrote:
esgici wrote:...
Esgici,
		WIDTH 400 ;
		HEIGHT 400 ;
			ROW	10
			COL	10
			WIDTH	100
			HEIGHT	110
			MULTISELECT .T.
		END LISTBOX
			ROW	10
			COL	150
			ACTION	SelectTest()
			WIDTH	150
		END BUTTON
   return
end
x := ''
next
Esgici,
This is a very simple and clear sample.
Basically, a multiselect grid 'value' property returns a numeric array containing the positions of selected items.
To obtain the content of a row, you must use the 'item' property using the position as argument.
Remember that 'item' returns an array containing as much elements as columns have the grid.
If you want a specific cell content, you must use the 'cell' property.
ie:
win1.grid1.cell(nRow,nCol)
will give you the content of the cell located at nRow, nCol.
Roberto.
Thanks Grigory and Roberto
My fault was adding a VALUE <aValues> statement into LISTBOX/GRID definition :(
TIA
