Draw Text
Has thanked: 411 times
Been thanked: 120 times
Draw Text
Hi
I have a .zip file named "drawtext.zip" contains
- test.prg
- c_graph.c
- i_graph.ch
- h_graph.prg
and noted as:
Draw Text in Window (alternate to overlapping label control definition)
10 KB rathinagiri_s 07/16/2003
If I understand rigthly, it modify HMG core library sources ( bad news ) and
give as result @ ..,.. SAY command usage (good news).
There may be a possibility for revive that ? ( by the rigth way of course )
Has thanked: 248 times
Been thanked: 300 times
It is very old one. I will try with the new version and come with @.... Say syntax.
Thank you Esgici.
