Close All not Working
Jeff Stone
Has thanked: 3 times
Been thanked: 4 times
Post by Jeff Stone »
Hi Everyone,
I've been away from Harbour and HMG for awhile but decided that I wanted to make sure a VFP application we have could also work in HMG. At one point in our code we call "CLOSE ALL" to close all open tables and an alternate file. While I think the alternate file is closing, none of the tables are closing. I have tried replacing CLOSE ALL with CLOSE DATABASES but the tables all appear to stay open. I am using HMG 3.4.2 32bits on Windows 10 64, fwiw, and compiling the app through IDE. I have stepped through the code with the debugger and can see that the work areas are all open after the CLOSE statements are executed.
Has anyone else ever encountered this issue?
Thanks in advance,
Jeff
Has thanked: 1071 times
Been thanked: 193 times
Hi Jeff,
Are you sure the program reaches 'CLOSE ALL'?
Try to see what is opened just before you reach your CLOSE ALL
FOR x := 1 TO 55
	SELECT( x )
	IF !EMPTY( ALIAS(x) )
Serge Now Is The Happiest Time Of Your Life !
Jeff Stone
Hi Serge,
Thanks for the reply. I am sure that the program is reaching the CLOSE ALL statement. The program is bombing out 3 lines later after we reopen one of the Closed files and try to set a filter.
Jeff
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Has thanked: 73 times
Been thanked: 91 times
Post by Claudio Ricardo »
Hi... Maybe with Harbour function DbCloseAll () or if any db is locked: DbUnLockAll () before DbCloseAll ()
Has thanked: 293 times
Been thanked: 213 times
Try to call debugger to find problem. In my opinion it works
Has thanked: 267 times
Been thanked: 416 times
Network :?:
how "fast" did you re-open after CLOSE ALL :?:
you may have "SMB2-Workstation-Cache" Problem when work in Network and SHARE DBF
have a look at
c:\hmg.3.4.4\HARBOUR\contrib\hbxpp\wafuncx.c -> HB_FUNC( WorkSpaceList )
it will give you a Array of ALIAS which are "in use"
Jeff Stone
Thanks to everyone for the suggestions. I was running on a local drive and in the debugger. Close All wasn't working at all but DbCloseAll() worked! So, Claudio is the prize winner. Now I would like to understand why Close All did not work but DbCloseAll() did. Any thoughts?
Claudio Ricardo
Hi ... The same thing happened to me with "Seek" looking for a single record that matched,
the "Set Softseek Off" did not work and I accepted any similarity as if Softseek were On
Use Clientes New
Index On Name To Iname
Set SoftSeek Off
Seek cName
If Found ()	Etc. Etc.
In Harbour console app work same as Cli**er 5.2 but in HMG app not work correctly...
but...
Use Clientes New
If DbSeek (cName, .F.)	Etc. Etc.
Work fine... Possibly because I use Unicode.
