Calculate US Bank Holidays
RussBaker
Post by RussBaker »
I need to calculate US bank holidays to validate a deposit date in a form.
Before I re-invent the wheel or convert the following code to HMG, anyone have something like this already?
fill the list with holidays
' New Year's Day Jan 1
' Martin Luther King, Jr. third Mon in Jan
' Washington's Birthday third Mon in Feb
' Memorial Day last Mon in May
' Independence Day July 4
' Labor Day first Mon in Sept
' Columbus Day second Mon in Oct
' Veterans Day Nov 11
' Thanksgiving Day fourth Thur in Nov
' Christmas Day Dec 25
Below is some C Code I could borrow for the job.
Public Function getHolidayList(ByVal vYear As Integer) As List(Of Date)
    Dim FirstWeek As Integer = 1
    Dim SecondWeek As Integer = 2
    Dim ThirdWeek As Integer = 3
    Dim FourthWeek As Integer = 4
    Dim LastWeek As Integer = 5
    Dim HolidayList As New List(Of Date)
    '   http://www.usa.gov/citizens/holidays.shtml
    '   http://archive.opm.gov/operating_status_schedules/fedhol/2013.asp
    HolidayList.Add(DateSerial(vYear, 1, 1))
    HolidayList.Add(GetNthDayOfNthWeek(DateSerial(vYear, 1, 1), DayOfWeek.Monday, ThirdWeek))
    HolidayList.Add(GetNthDayOfNthWeek(DateSerial(vYear, 2, 1), DayOfWeek.Monday, ThirdWeek))
    HolidayList.Add(GetNthDayOfNthWeek(DateSerial(vYear, 5, 1), DayOfWeek.Monday, LastWeek))
    HolidayList.Add(DateSerial(vYear, 7, 4))
    HolidayList.Add(GetNthDayOfNthWeek(DateSerial(vYear, 9, 1), DayOfWeek.Monday, FirstWeek))
    HolidayList.Add(GetNthDayOfNthWeek(DateSerial(vYear, 10, 1), DayOfWeek.Monday, SecondWeek))
    HolidayList.Add(DateSerial(vYear, 11, 11))
    HolidayList.Add(GetNthDayOfNthWeek(DateSerial(vYear, 11, 1), DayOfWeek.Thursday, FourthWeek))
    HolidayList.Add(DateSerial(vYear, 12, 25))
    'saturday holidays are moved to Fri; Sun to Mon
    For i As Integer = 0 To HolidayList.Count - 1
        Dim dt As Date = HolidayList(i)
        If dt.DayOfWeek = DayOfWeek.Saturday Then
            HolidayList(i) = dt.AddDays(-1)
        End If
        If dt.DayOfWeek = DayOfWeek.Sunday Then
            HolidayList(i) = dt.AddDays(1)
        End If
    Next
    'return
    Return HolidayList
End Function
Private Function GetNthDayOfNthWeek(ByVal dt As Date, ByVal DayofWeek As Integer, ByVal WhichWeek As Integer) As Date
    'specify which day of which week of a month and this function will get the date
    'this function uses the month and year of the date provided
    'get first day of the given date
    Dim dtFirst As Date = DateSerial(dt.Year, dt.Month, 1)
    'get first DayOfWeek of the month
    Dim dtRet As Date = dtFirst.AddDays(6 - dtFirst.AddDays(-(DayofWeek + 1)).DayOfWeek)
    'get which week
    dtRet = dtRet.AddDays((WhichWeek - 1) * 7)
    'if day is past end of month then adjust backwards a week
    If dtRet >= dtFirst.AddMonths(1) Then
        dtRet = dtRet.AddDays(-7)
    End If
    'return
    Return dtRet
End Function
Has thanked: 411 times
Been thanked: 120 times
RussBaker wrote:I need to calculate US bank holidays to validate a deposit date in a form.
Hi Russ
We have a built-in function FT_EASTER; but only for Easter day, no other holidays; still may be useful to you.
In comp.lang.clipper forum there is a pretty old (2004) topic US holidays including a pseudo function and some discussion on the topic.
I hope you would write such function and all we are will be utilized :arrow:
dhaine_adp
Been thanked: 3 times
Post by dhaine_adp »
Here's a brute force HB implementation of the VB code you have mentioned on your post.
Syntax in calling getHolidays()
aHolidays_ := getHolidays( 2015, .t. )    // 2nd parameter add asterisk to those holiday(s) that has been moved.
aHolidays_ := getHolidays( 2017 )          // no asterisk added
aHolidays_ := getHolidays()                   // Use current system date
function getHolidays( zYear, lMark )
   LOCAL aDates_ := ARRAY( 10 )
   LOCAL aElem_  := { 1, 5, 8, 10 }    // array offset (dates) that possibly needs to be moved, others not required
   LOCAL ii
   LOCAL lAsterisk := .f.
   IF PCOUNT() = 1 .AND. VALTYPE( zYear ) == "N"
      zYear := ALLTRIM( HB_NTOS( zYear ) )
      zYear := ALLTRIM( HB_NTOS( YEAR( DATE() ) ) )
   IF VALTYPE( lMark ) == "U"; lMark := .f.; ENDIF
   aDates_[  1 ] := CTOD( "01/01/" + zYear )          // New Year's Day Jan 1
   aDates_[  2 ] := getDate( 1, zYear,  3, "MON" )    // Martin Luther King, Jr. third Mon in Jan
   aDates_[  3 ] := getDate( 2, zYear,  3, "MON" )    // Washington's Birthday third Mon in Feb
   aDates_[  4 ] := getDate( 5, zYear,  4, "MON" )    // Memorial Day last Mon in May
   aDates_[  5 ] := CTOD( "07/04/" + zYear )          // Independence Day July 4
   aDates_[  6 ] := getDate( 9, zYear,  1, "MON" )    // Labor Day first Mon in Sept
   aDates_[  7 ] := getDate( 10, zYear,  2, "MON" )   // Columbus Day second Mon in Oct
   aDates_[  8 ] := CTOD( "11/11/" + zYear )          // Veterans Day Nov 11
   aDates_[  9 ] := getDate( 11, zYear,  4, "THU" )   // Thanksgiving Day fourth Thur in Nov
   aDates_[ 10 ] := CTOD( "12/25/" + zYear )          // Christmas Day Dec 25
   // Move holidays that falls on saturday to Fri; Sun to Mon
   FOR ii := 1 TO LEN( aElem_ )
      IF DOW( aDates_[ aElem_[ ii ] ] ) == 7  // Saturday
         aDates_[ aElem_[ ii ] ] -= 1
         IF lMark; lAsterisk := .t.; ENDIF
         ELSEIF DOW( aDates_[ aElem_[ ii ] ] ) == 1  // Sunday
            aDates_[ aElem_[ ii ] ] += 1
         /* Skip, do nothing. */
      **--> mark with asterisk those holidays that have been moved.
      **    Its value will become a character string.
      IF lAsterisk
         aDates_[ aElem_[ ii ] ] := "*" + DTOC( aDates_[ aElem_[ ii ] ] )
         lAsterisk := .f.
   RETURN aDates_
static function getDate( nMonth, cYear, nWkNo, cDOW )
   LOCAL dRetVal
   LOCAL dTarget
   LOCAL nWkCtr := 1
   dTarget := CTOD( ALLTRIM( HB_NTOS( nMonth ) ) + "/01/" + cYear )
   WHILE nWkCtr <= nWkNo
      IF LEFT( UPPER( CDOW( dTarget ) ), 3 ) == cDOW
         nWkCtr++
      dTarget++
   END
   dTarget--   // when the loop terminates, the date falls on the the following day so it has to be adjusted backward
   RETURN dTarget
Danny
Manila, Philippines
Has thanked: 291 times
Been thanked: 167 times
Nice coding, Thank you Mr. Danny
Holidays list can be maintained in like .ini file? and universally function can be used?
dhaine_adp
Hi BPD2000,
I took the question marks (usage) as a question. My answer is yes and no. Yes it can be put on .ini and no because different countries have their own unique set of holidays. However personally I don't put holidays on .ini file. I put them in a table and use mm/dd as a code. Sometimes holiday is mandated by president/gov't official as a Special Non-Working Holiday. In this regard users are able to add holiday or exclude/include in the calculation for a given fiscal year, bank transactions, check clearing, Time calculation, OT, night differential (shift workers), etc.
Danny
Manila, Philippines
bpd2000 wrote:Nice coding, Thank you Mr. Danny...
Thank you Danny for explanation
In India there is variable holidays declared every year and my idea was that any user can add / delete holidays date w/o
our intervention
