Using relationship
NickSteel
Using relationship
Post by NickSteel »
If I have:
Select 0
Use BBB alias BBB
Index on Field01 to BBB
Select 0
Use AAA alias AAA
Index on Field01 to AAA
Set Relation to AAA->Field01 Into BBB
Go Top
Do While !Eof()
Total := Total + if(BBB->Date01 = AAA->Date01 .AND. BBB->Field02>0 ,1,0)
Skip
Enddo
What is the easiest way to check if I have a BBB for each AAA during the Do While loop without seeking? Can I use FOUND() within the line? If so, how?
dhaine_adp
Been thanked: 3 times
Post by dhaine_adp »
Hi Nick,
Try to adopt the code below into your source code, maybe it can help.
** Use ORDSCOPE()
function Main()
LOCAL nTotal := 0
PRIVATE cPrimeKey := ""   // must be declared as private
Select 0
Use BBB alias BBB
Select 0
Use AAA alias AAA
dbselectarea( "BBB" )
dbgotop()
while .not. eof()
   cPrimeKey := BBB->Field01
    dbselectarea( "AAA" )
    ORDSCOPE( 0, "&cPrimeKey" )
    ORDSCOPE( 1, "&cPrimeKey" )
    dbgotop()  // go top is required here
    while .not. eof()
       nTotal += if(BBB->Date01 = AAA->Date01 .AND. BBB->Field02>0 ,1,0)
       dbskip()
    end
    BBB->dbskip()
end
Danny
Manila, Philippines
Has thanked: 100 times
Been thanked: 182 times
According this, I think what you are needing is to know how many records are with same date in both files and in BBB->Field02 must be different than zero.
Remembering all command in dBase, I should try this:
Count to Total for (BBB->Date01 = AAA->Date01 .AND. BBB->Field02>0)
I did not teste, so I not sure if gonna works but try and in other cases you can use Count command without any filter (filters normally become having/slow process) and also do not need index files too. But take in count that you need to process up the dbfs files.
IMO, if this information is frequently used, you need to be recorded at same time you are inputing data.
Has thanked: 411 times
Been thanked: 120 times
NickSteel wrote:If I have:
Select 0
Use BBB alias BBB
Select 0
Use AAA alias AAA
Go Top
Do While !Eof()
Skip
Enddo
You don't need FOUND(), try this loop :
Do While !Eof()
     Total := 0
     WHILE BBB->Date01 = AAA->Date01
           Total += IF( BBB->Field02>0  ,1,0)
           BBB->(DBSKIP())
    ENDDO
    ? "Count of", AAA->Field01, Total
    Skip
Enddo
Note : This is a Harbour issue, not HMG.
Hi Nick
esgici wrote:... try this loop :
What about result ?
If unsuccessful, if you will post a little data we can make more search.
NickSteel
Post by NickSteel »
I finally used (after trial and error):
tot1=tot1+if( ! BBB->(EOF()),1,0)
