Getting Table Struct with TMySqlServer:TableStruct()
hmgchang
Has thanked: 16 times
Been thanked: 11 times
Post by hmgchang »
Dear Masters,
REef. to this :
* MySql Harbour Contribution Library
CLASS TMySQLRow: Every single row of an answer
	DATA  aRow
		A single row of answer
	DATA  aDirty
		Array of booleans set to .T. if corresponding field of aRow has
		been changed
	DATA  aOldValue
		If aDirty[n] is .T. aOldValue[n] keeps a copy of changed value
		if aRow[n] is part of a primary	key
	DATA  aOriValue
		Original values ( same as TMySQLtable:aOldValue )
	DATA  aFieldStruct
		Type of each field
	DATA  cTable
		Name of table containing this row, empty if TMySQLQuery returned
		this row
	METHOD	New(aRow, aFStruct, cTableName)
		Create a new Row object
	METHOD   FieldGet(cnField)
		Same as clipper ones, but FieldGet() and FieldPut() accept a
		string as
	METHOD   FieldPut(cnField, Value)
		Field identifier, not only a number
	METHOD   FieldName(nNum)
	METHOD   FieldPos(cFieldName)
	METHOD   FieldLen(nNum)
		Length of field N
	METHOD   FieldDec(nNum)
		How many decimals in field N
	METHOD   FieldType(nNum)
		Clipper type of field N
	METHOD   MakePrimaryKeyWhere()
		Returns a WHERE x=y statement which uses primary key (if
		available)
CLASS TMySQLQuery: Every single query submitted to MySQL server
	DATA  nSocket
		Connection handle to MySQL server
	DATA  nResultHandle
		Result handle received from MySQL
	DATA  cQuery
		Copy of query that generated this object
	DATA  nNumRows
		Number of rows available on answer NOTE MySQL is 0 based
	DATA  nCurRow
		I'm currently over row number
	DATA  lBof
	DATA  lEof
	DATA  lFieldAsData
		Use fields as object DATA. For compatibility
		Names of fields can match name of TMySQLQuery/Table DATAs,
		and it is dangerous. ::lFieldAsData:=.F. can fix it
	DATA  aRow
		Values of fields of current row
	DATA  nNumFields
		How many fields per row
	DATA  aFieldStruct
		Type of each field, a copy is here a copy inside each row
	DATA  lError
		.T. if last operation failed
	METHOD   New(nSocket, cQuery)
		New query object
	METHOD   Destroy()
	METHOD   End()
	METHOD   Refresh()
		ReExecutes the query (cQuery) so that changes to table are
		visible
	METHOD   GetRow(nRow)
		Return Row n of answer
	METHOD   Skip(nRows)
	METHOD   Bof()
	METHOD   Eof()
	METHOD   RecNo()
	METHOD   LastRec()
	METHOD   GoTop()
	METHOD   GoBottom()
	METHOD   GoTO(nRow)
	METHOD   FCount()
	METHOD   NetErr()
		Returns .T. if something went wrong
	METHOD   Error()
		Returns textual description of last error and clears ::lError
		Length of field N
CLASS TMySQLTable: A query without joins; Insert() e Delete() rows are allowed.
NOTE: it's always a SELECT result, so it will contain a full table only if
SELECT * FROM ... was issued
	DATA  cTable
		Name of table
	DATA  aOldValue
		Keeps a copy of old value
	METHOD   New(nSocket, cQuery, cTableName)
	METHOD   GetRow(nRow)
	METHOD   Skip(nRow)
	METHOD   GoTop()
	METHOD   GoBottom()
	METHOD   GoTo(nRow)
	METHOD   Update(oRow, lOldRecord, lRefresh)
		Gets an oRow and updates changed fields
	METHOD   Save()
	METHOD   Delete(oRow, lOldRecord, lRefresh)
		Deletes passed row from table
	METHOD   Append(oRow, lRefresh)
		Inserts passed row into table
	METHOD   GetBlankRow( lSetValues )
		Returns an empty row with all available fields empty
	METHOD   SetBlankRow()
		Compatibility
	METHOD   Blank()
	METHOD   Refresh()
		available)
CLASS TMySQLServer: Every available MySQL server
   DATA  nSocket
	Connection handle to server (currently pointer to a MYSQL structure)
   DATA  cServer
	Server name
   DATA  cDBName
	Selected DB
	DATA  cUser
		User accessing db
	DATA  cPassword
		His/her password
	DATA  lError
		.T. if occurred an error
	DATA  cCreateQuery
	METHOD   New(cServer, cUser, cPassword)
		Opens connection to a server, returns a server object
	METHOD   Destroy()
		Closes connection to server
	METHOD   SelectDB(cDBName)
		Which data base I will use for subsequent queries
	METHOD   CreateTable(cTable, aStruct,cPrimaryKey,cUniqueKey,cAuto)
		Create new table using the same syntax of dbCreate()
	METHOD   DeleteTable(cTable)
		Delete table
	METHOD   TableStruct(cTable)
		Returns a structure array compatible with clipper's dbStruct()
		ones
	METHOD   CreateIndex(cName, cTable, aFNames, lUnique)
		Create an index (unique) on field name(s) passed as an array of
		strings aFNames
	METHOD   DeleteIndex(cName, cTable)
		Delete index cName from cTable
	METHOD   ListDBs()
		Returns an array with list of data bases available
	METHOD   ListTables()
		Returns an array with list of available tables in current
		database
	METHOD   Query(cQuery)
		Gets a textual query and returns a TMySQLQuery or TMySQLTable
		object
	METHOD   NetErr() INLINE ::lError
	METHOD   Error()
	METHOD   CreateDatabase( cDataBase )
		Create an New Mysql Database
	METHOD   sql_Commit()
		Commits transaction
	METHOD   sql_Rollback()
		Rollbacks transaction
	METHOD   sql_Version()
	Server version as numeric
I tried to get the table struct by the oServer:TableStruct( cTable) method... but always
return an empty array / {}. Pls advise where have i make mistake, or any other ways
to have the infos ? ( at mysql command line i can use DESCRIBE table... but i dont know
how to get the info into the program...
TIA
best rgds,
Chang
Just Hmg It !
Has thanked: 252 times
Been thanked: 305 times
You can pass on the 'Describe...' query to the sql server the same way you are sending any other 'select...' query.
